Code P245a - Diesel Truck Forum - TheDieselGarage.com
Thread Details Posted by atlas59, this thread has received 7 replies and been viewed 8625 times.
post #1 of 8 (permalink) Old 01-03-2009, 08:36 PM Thread Starter
Code P245a
The code page lists it as: EGR Cooler Bypass Control Circiut/Open. I was wondering what this meant. Is this the egr control default setting as in when the truck is just started and the egr is not being used, or is this something I need to get checked out. Truck is running normal and I only check codes when I change oil/filter or fuel filter.
atlas59 is offline
post #2 of 8 (permalink) Old 01-04-2009, 12:25 AM
fuzzy's Avatar
Any mods? Alot of people with the egr cooler delete get this code. I have had it a couple of times with just the egr delete. I've just cleared it, and it stays away most of the time. If you don't have any deletes, I think it means something in the cooler needs to be cleaned, and is sooted up. Don't quote me on that, but I think I read something on it somewhere before.
fuzzy is offline
post #3 of 8 (permalink) Old 01-04-2009, 02:12 AM Thread Starter
nope its all stock...i've had turbo cleaned then replaced, ive had all the egr crap replaced, and the whole exhaust replaced. no biggie like i said its running normal just trying to get more info.
atlas59 is offline
post #4 of 8 (permalink) Old 01-04-2009, 03:06 AM
fuzzy's Avatar
Yea, I think there's something in your egr cooler sooted up now. Not 100% sure though. That code with a cooler delete seems to be more active in cold conditions.
fuzzy is offline
post #5 of 8 (permalink) Old 01-11-2009, 03:47 PM Thread Starter
code cleared itself
atlas59 is offline
post #6 of 8 (permalink) Old 01-14-2009, 05:17 PM
fjo
Code Check?
Is there a way to check what codes you've had or they just pop up when something is not right with the system?
fjo is offline
post #7 of 8 (permalink) Old 01-14-2009, 06:36 PM
Proud Texan
madville's Avatar
Starscan tool can see past codes I believe.
Scooter
2008 Dodge Ram QC CTD 6.7L
Performance: Magnaflow straight 5" TBE, Industrial Injection Hybrid VGT, S&B CAI, H&S Performance XRT, Shibby EGR/EGR Cooler delete.
Exterior: Recon Smoked Cab lights, Windows tinted, Spray-in bedliner, Black nerf bars
Interior: Putco LED Dome lights, Alpine IVA-W505 Headunit, Marathon Realtree Camo Seat Covers
American Club #17
Singles Club #0
madville is offline
post #8 of 8 (permalink) Old 01-14-2009, 11:05 PM
fuzzy's Avatar
Check you codes with the key trick, here's how.
Get in truck, and shut all doors. Without starting it..................
key on
key off
key on
key off
key on and leave on. (Don't Start)
Do it fairly quick.
Look at the odometer. If there are codes it will bring them up like this.
------p245a--------, then it will keep going if there are more.
When it's done, it will do this.-------DONE--------.
If there are none at all it will just say, --------DONE--------.
Be sure and be ready to write them down, and you can check what they are with the sticky thread at the top of this section.
fuzzy is offline
6.7 Code Pages fuzzy 6.7L Cummins (2007.5-2011) 11 01-20-2015 03:06 AM
P2002 Code..... rrose 2008-2010 6.4L Power Stroke 18 08-25-2011 08:13 AM
DTC code list for 6.4L BeauxPete 2008-2010 6.4L Engine Tuner Forum 16 01-23-2010 09:20 PM
Code List bad1 Duramax 2001-2004 (LB7) 4 12-31-2008 11:10 AM
L20 strategy code Dr. Smoke 2008-2010 6.4L Engine Tuner Forum 4 12-25-2008 03:19 AM
