road test article 6.7 - Diesel Truck Forum - TheDieselGarage.com
Thread Details Posted by KERR, this thread has received 32 replies and been viewed 2713 times.
post #1 of 33 (permalink) Old 01-17-2007, 03:29 PM Thread Starter
In this months ( well Feburary issue) of diesel power they have a write up on the 6.7 chassie cab with a Kmapheide Stake bed on it and it was an auto.
They said they put 1057 miles on the mileage ranged from 11.92 mpg to 9.81
They also went to the dyno and did 3 pulls.
256hp and 476 tq.
260hp and 509 tq
259hp and 500 tq
They said that dodge rates it at 305 hp and 610 lbtq...
anyway i dont know if you can look it up on line or not, if not its on page 122 of the February issus if your like me have to go to walkmart with the old lady
KERR is offline
post #2 of 33 (permalink) Old 01-17-2007, 03:35 PM
Dedicated Diesel Perv
The numbers I see there with what Dodge says they are rated at seem to be right in the ballpark. Terrible mileage figures though. That will be an interesting read whenever I receive my copy (I have to wait a few extra weeks to get my magazines :cry: )
2018 Ford F250HD 6.7L
MoparBob is offline
post #3 of 33 (permalink) Old 01-17-2007, 03:44 PM
Every truck dynos way under rated horsepower and nobody with a brand new Cummins ever see's good MPG brand new.
Smokem is offline
post #4 of 33 (permalink) Old 01-17-2007, 03:53 PM
256hp and 476 tq.
260hp and 509 tq
259hp and 500 tq
The mileage sounds like crap but they say it should improve when broke in, Ive got one ordered also with an auto and will put a 9' utility body on which when loaded with tools and equip will weigh much more than a flat bed, I only get 11 mpg now with my 95 2500 CTD with utility body, I thought the new truck would be better.
I don't know what to think about the dyno test numbers since they are always different from the manufacturer's rated power.
How do you guys more in the know interpret the dyno numbers?
gen4 is offline
post #5 of 33 (permalink) Old 01-17-2007, 03:57 PM
My truck did 190 on a chassy dyno, which I obvoiusly thought was really low. You wouldn't believe how many people think I'm pushing over 350. You'll notice the power increase, that 350 HP is rated at the flywheel. Just like every Cummins.
Smokem is offline
post #6 of 33 (permalink) Old 01-17-2007, 05:55 PM
'Ol Builder guy
Duke's Avatar
Just the opposite-the newer truck diesels are projected to get noticeably WORSE fuel mileage due to the EPA regs. They're also more powerful. More power takes more fuel. There's no getting around that unless you increase efficiency. Ford has gone to a twin turbo set-up. That increases efficiency by eliminating turbo lag. If there's less turbo lag, the driver will not need to push down on the go-pedal as hard, thereby using less fuel.
The highest mileage diesels will be the old N/A Ford diesels and the old 160HP Cummins with manual transmissions.
The dyno numbers make perfect sense since most automatics pull 15-20% of the flywheel power off the truck. 610TQ x 20% is 122TQ 610-122=488. 610TQ x 15% = 92. 610-92= 519TQ.
Duke is offline
post #7 of 33 (permalink) Old 01-17-2007, 06:41 PM Thread Starter
Sounds like they will be a nice turck... I have some friend looking for two new diesels but they want the 06 models. They will use them as baja race truks though...
I still have not seen a new 07 6.7 on a lot...
KERR is offline
post #8 of 33 (permalink) Old 01-17-2007, 07:38 PM
Jponder would throw a fit about that, his 2001 did 30 MPG. My 1998.5 does over 25MPG, mine needed a little motivation though, I don't know what Jponder did to his. I can see the IDI fords doing good on fuel, but I don't think there is much to room to work with vs. the DI Powerstrokes.
Smokem is offline
post #9 of 33 (permalink) Old 01-17-2007, 08:46 PM
'Ol Builder guy
Duke's Avatar
Fuel mileage is as much a component of the driver's ability to squeeze more MPG's out of the truck, the climate in which the truck is driven (flat, headwinds, etc.) as the type of engine. What you're failing to realize is that Joe blows truck might be driven in conditions that greatly affect fuel mileage compared to your conditions. Just one underinflated tire or 2 more stoplights would have a significant impact on MPG's
If you took all the types of truck diesels made, inserted them in the same body style truck, with same tires, wind resistance, weather conditions, same stretch of road driven by a computer, my bet is the IDI and early Cummins get the best fuel mileage.
Think about it.
Needless to say, the newer trucks with their higher outputs & more emmissions controls will suffer in the MPG dept.
Duke is offline
post #10 of 33 (permalink) Old 01-17-2007, 09:01 PM
Haulin' Azz
BROKER's Avatar
I'll dispute JPONDER claims . :smoke
BROKER is offline
