Siamese cylinders - Diesel Truck Forum - TheDieselGarage.com
Thread Details Posted by Smokem, this thread has received 39 replies and been viewed 6984 times.
post #1 of 40 (permalink) Old 03-28-2007, 03:25 PM Thread Starter
Siamese cylinders
Sorry to start a second thread, but I want to know as much about this beast if I buy one. The fact this engine has siamese cylinders does get if it the possiblility of making it more durable or not? I don't think cooling should be a issue with these engines considering they seem to over cool anyways. But I really don't know. Just wondering what anyone else thinks of the siamese cylinders.
Smokem is offline
post #2 of 40 (permalink) Old 03-28-2007, 04:01 PM
Mafia #42
HighTQCummins's Avatar
Location: Valley Forge PA/West Long Branch NJ (college)
Send a message via AIM to HighTQCummins
what are these siamese cylinders?
Hank
TDG and the Mafia lives on
TDG B.O.M.B. Squad #5
My Truck:2007 Toyota Tacoma V6 4x4
Diesel is in my blood, I guess you can call it a disease, sadly there is no cure for it, it's my cross I must carry
HighTQCummins is offline
post #3 of 40 (permalink) Old 03-28-2007, 04:10 PM Thread Starter
It's where coolant flow all the way around the cylinders because they are all connected. I don't know exactly for sure.
Smokem is offline
post #4 of 40 (permalink) Old 03-29-2007, 01:09 AM
Send a message via AIM to deere puller Send a message via Yahoo to deere puller
You mean like in a wet liner engine, they dont have liners do they?
deere puller is offline
post #5 of 40 (permalink) Old 03-29-2007, 01:16 AM Thread Starter
I don't know, I'm getting really lost now.
Smokem is offline
post #6 of 40 (permalink) Old 03-29-2007, 01:42 AM
Mafia #42
are wet sleeve what they use in big diesels? Now I am confused
Hank
post #7 of 40 (permalink) Old 03-29-2007, 02:01 AM
Mafia member 46
the ISC and bigger Cummins use a steel sleeve that is pressed into the cast block making it easier to rebuild. some are wet in the fact that they create the barrier between the cylinder and the waterjacket. but there are also others that are dry and have no contact with the coolant
the 5.9 and 6.7 are what they call a parent bore engine. the cylinders are part of the blocks casting like a gasser engine.
the 5.9 has water jackets cast into the engine all the way around each cylinder and the cylinders are not connected to each other along the length of the bore.
in the 6.7, each cylinder shares metal with the adjacent cylinder making them siamesed together. with a living animal dependant of how badly they are "siamesed" , one or both would die if they were separated since they are sharing parts. The same principle applies with the 6.7. Also due the the bores being siamesed there is no way to have a water jacket separating them so there will be spots in the cylinder walls that will be hotter that other areas, which can cause distortion of the cylinder walls and a loss of compression. If this is even going to be a concern with the 6.7 is yet to be known. I bet Cummins knows but they aint gonna' tell.
Current: '07.5 2500 QC/SB ETJ/68RFE, 4x4, Fabtech 6" lift, KMC XD "Diesel" 20x10 wheels, Pro Comp X all terrain 37x13.5R20 tires, BDog P Pup AFE, MegacannonII, H&S Gen 1 DPF Delete, EGR unplugged. Dynoed 361hp/677tq 20090220
SOLD!'03.5 3500 SRW QC Dynoed 2/11/06 457hp/1002tq
Scrappy is offline
post #8 of 40 (permalink) Old 03-29-2007, 01:04 PM
'Ol Builder guy
Duke's Avatar
Yes, wet sleeve designs are used in almost all big truck/equipment diesels. One of the smallest big truck diesels to employ them is the DT466. You can actually rebuild the engine due to liner, piston or ring failure without even pulling the motor off the mounts. You remove the pan to pull everything from the bottom and the top off right in the truck, then install new liners, pistons, rings, etc. The liners are pressed into the block
A 5.9L Cummins would have to be pulled out of the frame of the truck and "bench" rebuilt just like any gas engine since it's a parent bore diesel.
Duke is offline
post #9 of 40 (permalink) Old 03-29-2007, 01:29 PM
General Contractor
Not related but an aluminum block 350 is one gasser that has a dry sleve configuration. I think. All I know is we have one that is apart and you can see the sleve and how it is pressed into the block. currently rebuilding the motor.
:bow: 2005 Ford F-350 CC 4x4 Dually. Of course :agreed: 6.0 PSD with Torqueshift Tranny.
Big Black Beast. :evil:
ACC inc. is offline
post #10 of 40 (permalink) Old 04-03-2007, 12:53 AM
Mafia #42
Couldn't they rework the block so that there are no more siamese cylinders, maybe make it a little longer. How long do you think it would be until they start to notice this cyl. distortion?
Hank
