What would you do. - Diesel Truck Forum - TheDieselGarage.com
Thread Details Posted by jzee, this thread has received 29 replies and been viewed 2400 times.
post #1 of 30 (permalink) Old 04-10-2007, 10:01 PM Thread Starter
What would you do.
This is my first post. I have had 3 different diesels a 7.3 Non turbo ford, a 6.5 chevy. and a 6.0 Powerstroke. The 03 Powerstroke was and is a total dissappoint. Its in a 03 F350 Crew cab and has been a problem since day two. I am switching to a dodge and wondering if I should try the mew motor and tranny or stay with the 5.9. About a $2000 savings. I would only consider the new because its setup for the new fuel. I pull a 31 ft trailer (5600lbs) and use it daily in construction. Fuel mileage is my number one consern.What would you do.
jzee is offline
post #2 of 30 (permalink) Old 04-11-2007, 12:18 AM
Mafia #42
HighTQCummins's Avatar
Location: Valley Forge PA/West Long Branch NJ (college)
Send a message via AIM to HighTQCummins
Welcome to da garage. I would look for an 05 or 06 truck, so far I have heard a bunch of complaints about fuel mileage w/ the new 6.7. The 6.7's are supposed to have a very decent trans (6sp AISIN or 68re) maybe further down the road once they are main stream you can adapt one upto the 5.9. Power is supposed to be abundant w/ the 6.7's but you can always turn a 5.9 up a little if you need to.
Hank
TDG and the Mafia lives on
TDG B.O.M.B. Squad #5
My Truck:2007 Toyota Tacoma V6 4x4
Diesel is in my blood, I guess you can call it a disease, sadly there is no cure for it, it's my cross I must carry
HighTQCummins is offline
post #3 of 30 (permalink) Old 04-11-2007, 12:26 AM
The new motor is supposed to be ok (mpg is down but all of mpg is down due to emissions). The asian trans sounds promosing but unproven. I dont htink youd go wrong w/a 5.9 and 5spd if you can find it.
#23 Singles Club
thejdman04 is offline
post #4 of 30 (permalink) Old 04-11-2007, 02:45 AM
Iam kinda in the same boat. Got a 6.0 and hate it, looking at switching to the cummins. Would like the new engine and tranny but the 5.9 is looking better for fuel milage and proven.
07 3500 5.9 QC LB AT 4x4 Edge Additude w/hot unlock S&B intake 5" Magnaflow exhaust
Trucks Sold
93 F250 7.3 Turbo SC LB 5 Speed 4x4 XLT Stock
2006 F350 6.0 CC LB AT 4x4 King Ranch SCT etc
2003 F350 7.3 SC LB AT 4x4 XLT H2E and more
1993 F250 7.3 LB IDI 2wd 5 speed XL Pump turned up
ontherks is offline
post #5 of 30 (permalink) Old 04-11-2007, 04:17 AM
Less emissions = more power and better milage. Emissions on diesels is just dumb.
mckey73 is offline
post #6 of 30 (permalink) Old 04-11-2007, 04:53 AM
go with the 5.9l u wont be sorry:93C_peelo on:
86 1 tonhauler is offline
post #7 of 30 (permalink) Old 04-11-2007, 02:30 PM
Mafia #42
It AISIN. I h8 to correct you, but just so you know and when you are talking to someone else, you don't sound misinformed. But if you can find a 24v w/ a 5 speed that would be great because they are supposedly very very good on fuel. Do you need 4x4 or not? I've seen someone on here that just bought a 99 24v 2wd w/ 191K miles on it and is getting roughly 21mpg not towing anything.
Hank
post #8 of 30 (permalink) Old 04-11-2007, 09:35 PM
If you want an automatic tranny, I recommend the 6.7 with the 6-speed. The new motor is quieter and much more powerful.
If you like manual trannys, try to find a good deal on a 5.9.
sacgmc is offline
post #9 of 30 (permalink) Old 04-11-2007, 10:45 PM
I looked seriously at all 3 makers. It was probably going to be a Duramax for me until I heard about the new Dodge 6 speed. I had no interest in a 4 speed. I did as much due dilegence as possible: calculations, drove 4 speed, drove CC, even drove Ford. My new 3500 QC DRW just arrived, but I cannot fly out to get it for another 2 weeks. Picking it up from Futz Dodge in St. Louis. I will post MPG and update when it arrives. Need to get a gooseneck installed, then will be towing some with it.
jibber is offline
post #10 of 30 (permalink) Old 04-12-2007, 01:30 PM
Ditto,these are my thoughts exactly
2000 Dodge CTD 2500 4x4,Qcab SWB, 4.10 LSD,PDR cam,PDR twins,DonM 6,Edge Drag Comp,RASP fuel system,DTT trans,Blizzard 810,Sidewing plow,Trynex Vp8000,Sunnybrook 3310
John DiMartino is offline
