Wheel fitment? - Diesel Truck Forum - TheDieselGarage.com
Thread Details Posted by BCMC, this thread has received 3 replies and been viewed 606 times.
post #1 of 4 (permalink) Old 04-14-2008, 10:01 PM Thread Starter
Wheel fitment?
Will Ford and GM 8 lug wheels fit on our Dodges? thanks
BCMC is offline
post #2 of 4 (permalink) Old 04-15-2008, 09:15 PM
not unless they're metric
triton is offline
post #3 of 4 (permalink) Old 04-16-2008, 01:24 AM
GM uses the same bolt pattern but they use a smaller hub diameter, 116mm vs. 121 or something like that so they can fit with some machining. I'm not sure when it was but ford went to a odd sized bolt pattern, like 8x200 i think which doesn't fit much of anything but ford.
07 Dodge 5.9 3500 DRW 4x4 QC 6spd:93C_peelo With a few mods.
catdude is offline
post #4 of 4 (permalink) Old 04-19-2008, 03:52 PM
Gm has same bolt pattern but hub bore is 117mm, Dodge is 122mm hub bore. Ford went to a 8 on 170mm when the superdutys came out.
2000 F-350 PSD srw 6" skyjacker coil-over w/ 37" BFG KM2 Mud Terrain, XD Series Hoss Wheels, Warn bumper with 15,000lb warn winch, swamps single shot f* mes, H2E turbo, wipeout headstuds, 3.5" H2E Downpipe to a 4" Diamond Eye exhaust, Boost-Pyro-Trans-Oil pressure Gauges, regulated return, modded idm, swamps tuned 6 position chip, Yukon 4.30 gears front and rear, Homemade Traction Bars, Dieselsites billet thermostat housing with 203 degree thermostat. PICS: http://community.webshots.com/myphot...ecurity=bLyrnM
jmiltier is offline
