6 speed auto in tow/haul - Diesel Truck Forum - TheDieselGarage.com
Thread Details Posted by heavyhaller, this thread has received 2 replies and been viewed 633 times.
post #1 of 3 (permalink) Old 04-16-2008, 03:49 PM Thread Starter
Does the new 6 sp auto use all the gears when towing or does it lock out the OD gears?:
heavyhaller is offline
post #2 of 3 (permalink) Old 04-17-2008, 02:31 AM
T/H locks out OD
triton is offline
post #3 of 3 (permalink) Old 04-17-2008, 03:12 AM
Dodgefarmer's Avatar
The T/H mode will keep it out of over drive as long as you are accelerating or have a certain amount of load on the engine. When you get to your cruising speed and the load on engine and trans is light enough it will go into overdrive. The T/H mode just keeps it in each gear longer and keeps it out of OD longer until the load or torque input is reduced enough to allow it to get into OD.
singles club # 198
Dodgefarmer is offline
