Max EGT? - Diesel Truck Forum - TheDieselGarage.com
Thread Details Posted by eby94, this thread has received 13 replies and been viewed 4981 times.
post #1 of 14 (permalink) Old 01-13-2009, 01:14 AM Thread Starter
Max EGT?
Just curious as to what the max egt some of you guys set your edge on. I dont want to burn the motor up, but wouild like to get everything out of it when I pull my horse trailer.
2007 3500 4x4
6.7l
dpf delete
egr delete
edge/attitude
eby94 is offline
post #2 of 14 (permalink) Old 01-13-2009, 01:21 AM
ADMIN/MAFIA
neeltburn's Avatar
I still have the NOx Cat and DPF and I see max EGTs of 1020s post turbo. I don't have edge or anything that not in my sig. if you fill out your signature with more info about your truck you may get a better answer, just something to think about so others know what all your running.
6.7L 68RFE 4wd
Yeah its stock.
Pac Brake Air Bags
On Board Air
Optima Redtop 34Rs
2010 John Deere 2305
9-11-2001 NEVER FORGET
neeltburn is offline
post #3 of 14 (permalink) Old 01-14-2009, 12:44 AM
fuzzy's Avatar
It's nothing for these trucks to spike 1400 to 1500 degrees. But I set it around 1250 to 1300 if your probe is in the manifold. If your probe is post turbo, I'd take 2-300 degrees off that.
fuzzy is offline
post #4 of 14 (permalink) Old 01-14-2009, 12:50 AM
MART5.9's Avatar
Depends on if you still have your EGR and DPF. But if you did all deletes don`t worryleave the alarm where it is(around 1350F I think) because you`ll never get upthere anyway. Before I did my deletes I had to programmed my EGT`s alarm way higher than that because I was getting around 1400F - 1450F while in regen and it gets highter than this for a fraction of a second if you EGR open`s while in regen....yes , I had rapids peaks of close to 1500F while in regen before I did my deletes. And if you want some numbers to motive yourself to go ahead on the deletes check this out....Now I get around 650F to 700F empty and around 900F to 1000F pulling 12 000lbs 5th wheel.
2006 3500 mega cab SLT auto.
Diamond eye turbo back, S&B cold air intake,62mm turbo, billet tranny, smartyJR....
Proud to now participate to global warming
EGR and DPF are the worst CRAP ever and the worst is still to come.....UREA !
MART5.9 is offline
post #5 of 14 (permalink) Old 01-14-2009, 02:54 PM
Proud Texan
madville's Avatar
Oddly, since I did the EGR delete I do spike to the 1350 alarm. Before It wouldn't come close, I think 1200 was max.
Scooter
2008 Dodge Ram QC CTD 6.7L
Performance: Magnaflow straight 5" TBE, Industrial Injection Hybrid VGT, S&B CAI, H&S Performance XRT, Shibby EGR/EGR Cooler delete.
Exterior: Recon Smoked Cab lights, Windows tinted, Spray-in bedliner, Black nerf bars
Interior: Putco LED Dome lights, Alpine IVA-W505 Headunit, Marathon Realtree Camo Seat Covers
American Club #17
Singles Club #0
madville is offline
post #6 of 14 (permalink) Old 01-14-2009, 03:22 PM
BigBlueDodge's Avatar
Mine hits 1500 pretty easy.
07 6.7
6 Inch lift
37-13.50 Nitto Mud Grapplers
XRT WOOO
Ts-mp8
S&B Intake
5 inch to 7 inch mitter cut stacks
egr all gone
2 10 inch mtx subs
Tint
Boost Fooler
Black Head and Tail lights
BigBlueDodge is offline
post #7 of 14 (permalink) Old 01-14-2009, 11:45 PM
MART5.9's Avatar
OUCH!
MART5.9 is offline
post #8 of 14 (permalink) Old 01-15-2009, 12:24 AM
fuzzy's Avatar
I think kmk has broke a 1800 degree gauge. Maybe it was only 1600, but still.
fuzzy is offline
post #9 of 14 (permalink) Old 01-15-2009, 12:30 AM
Ya its a bit high. o well.
07 6.7
6 Inch lift
XRT WOOO
Ts-mp8
S&B Intake
egr all gone
2 10 inch mtx subs
Tint
Boost Fooler
post #10 of 14 (permalink) Old 01-16-2009, 06:40 AM
I was hitting 1520-1530 at WOT.... after the AFE inter cooler tube I only got to 1480 once......... i have my edge set to defuel at 1500 and it hasnt backed down since i did the upgrade............ my egt probe is in the manifold
kcpanages is offline
