Any known issues - Diesel Truck Forum - TheDieselGarage.com
Thread Details Posted by lilpooh, this thread has received 14 replies and been viewed 2118 times.
post #1 of 15 (permalink) Old 01-14-2009, 02:12 PM Thread Starter
lilpooh's Avatar
Any known issues
My buddies step son is in the market for a new diesel, I will be posting in all of the big 3 forums with this question, GIVE ANY KNOWN ISSUES WITH THE NEW TRUCKS. (EXAMPLE:6.0 head bolts stretching) THIS IS NOT A BASHING THREAD ALL BRANDS AND MODELS HAVE ISSUES.
2004 F350 CC DRW King Ranch
lilpooh is offline
post #2 of 15 (permalink) Old 01-14-2009, 02:52 PM
Proud Texan
madville's Avatar
I have yet to have any real issue with my 08. Never any problems before I started modifying and just ran better afterwards.
Scooter
2008 Dodge Ram QC CTD 6.7L
Performance: Magnaflow straight 5" TBE, Industrial Injection Hybrid VGT, S&B CAI, H&S Performance XRT, Shibby EGR/EGR Cooler delete.
Exterior: Recon Smoked Cab lights, Windows tinted, Spray-in bedliner, Black nerf bars
Interior: Putco LED Dome lights, Alpine IVA-W505 Headunit, Marathon Realtree Camo Seat Covers
American Club #17
Singles Club #0
madville is offline
The Following User Says Thank You to madville For this addition to TDG:
lilpooh (01-14-2009)
post #3 of 15 (permalink) Old 01-14-2009, 03:20 PM
Most problems you will find on the 6.7s are related to the emissions. I think that was mostly on the 07's although I have seen guys with 08's posting up similar problems. I know my 07 has had the dpf replaced, egr replaced, turbo cleaned, turbo replaced, o2 sensors rplaced, comp as been flashed about 6 times. I relate my problems to the truck having "new" technology. I have heard others complain about the weak stock clutches. My truck is stock so I have not noticed any problems with my clutch. As far as general maintenance problems go the only thing I can complain about is that whoever thought the new fuel filter set up was a good idea needs to go and lay in front of a bus. The old fuel filter was much easier to change. I have been looking to buy a small adolecent primate to make changing my fuel filter easier.
atlas59 is offline
The Following User Says Thank You to atlas59 For this addition to TDG:
post #4 of 15 (permalink) Old 01-14-2009, 03:24 PM
BigBlueDodge's Avatar
No problems here besides two drive lines i broke. Cuz of the lift though.
07 6.7
6 Inch lift
37-13.50 Nitto Mud Grapplers
XRT WOOO
Ts-mp8
S&B Intake
5 inch to 7 inch mitter cut stacks
egr all gone
2 10 inch mtx subs
Tint
Boost Fooler
Black Head and Tail lights
BigBlueDodge is offline
The Following User Says Thank You to BigBlueDodge For this addition to TDG:
post #5 of 15 (permalink) Old 01-14-2009, 03:52 PM
no problems stock, and none modified as of yet!
BigRed6.7CTD is offline
The Following User Says Thank You to BigRed6.7CTD For this addition to TDG:
post #6 of 15 (permalink) Old 01-14-2009, 03:55 PM
do you mean drive shafts? as in twisted or just a u-joint?
post #7 of 15 (permalink) Old 01-14-2009, 04:03 PM
The yoke that hooks to the transfer case on the front drive line broke.
07 6.7
6 Inch lift
XRT WOOO
Ts-mp8
S&B Intake
egr all gone
2 10 inch mtx subs
Tint
Boost Fooler
post #8 of 15 (permalink) Old 01-14-2009, 11:33 PM
the only problems i had was the egr valve had to be cleaned and the dpf replaced a few thousand miles ago . i think it was mostly due to the earlier ecm programming for the emmissions . as far as the truck and engine goes , i have had zero problems and love my truck . the cummins is a great engine and the straight six has about half as many moving parts as a v-8 .
started with 1996 2500 4x4 auto
then a 2004.5 2500 4x4
now have a 2007.5 6.7 4x4 3500 drw mega cab 3:73 rear G56
Georgia Dawg is offline
The Following User Says Thank You to Georgia Dawg For this addition to TDG:
lilpooh (01-15-2009)
post #9 of 15 (permalink) Old 01-15-2009, 05:16 AM
Dodgefarmer's Avatar
I have 40,000+ miles on mine. It is 100% stock and I have had ZERO problems. Not even as much as a cel. I do all sorts of driving from short trips to freeway driving and pulling a 36' 12,000lbs rv. To sum it up I am
singles club # 198
Dodgefarmer is offline
post #10 of 15 (permalink) Old 01-16-2009, 03:24 PM
rXr
Misplaced Alaskan
Most everything has been discussed at one time or another on the threads on the site. Take some time and look for yourself. You'll find some common complaints/concerns that keep popping up. If you ask you'll get a few with specific problems but reading the threads will give you a better idea and a much bigger picture on what to look for.
Good luck
ps Telling me your posting on the other threads feels like it's somehow going to be my problem if you buy the wrong truck...buy what you want. I don't care. You have to live with it.
2008 2500 HD Megacab 4X4 CTD, 6 speed Auto, Mineral Gray, SRW #143 - 28TB Tahoe Toy Hauler
Utility quads, 2 kids and one awesome (and patient) wife. Priorities not listed in order of importance
rXr is offline
New...with issues My66coupe 1994-2003 7.3L Power Stroke 5 10-24-2007 05:09 PM
466 issues RynL88 Medium and Heavy Duty 7 01-02-2007 02:25 PM
SCT ??/issues turbo lcc 2003-2007 6.0 Tuner Forum 2 05-15-2006 01:13 PM
egr issues jersey250 2003-2007 6.0L Power Stroke 10 01-29-2006 02:39 AM
Issues with a 96 sstockton 1994-2003 7.3L Power Stroke 3 11-30-2005 03:56 PM
