Fuel Additive? - Diesel Truck Forum - TheDieselGarage.com
Thread Details Posted by neeltburn, this thread has received 33 replies and been viewed 4683 times.
post #1 of 34 (permalink) Old 01-17-2009, 03:07 AM Thread Starter
ADMIN/MAFIA
neeltburn's Avatar
Fuel Additive?
Guys,
I still have the EGR and DPF :. Its been really cold here for Southern Indiana, the low last night hit -1. I stopped using addivtive when I had sooting probs last summer. The question I have is, is there any DPF safe additive that wont soot up the truck. For now I have just been keeping the fuel tank full(to prevent condensation) I just don't want to keep running the risk of gelled fuel. any Ideas as Im not to hip on getting yet another turbo or loosing warranty just yet. I know its a lot colder when some of you guys are.
6.7L 68RFE 4wd
Yeah its stock.
Pac Brake Air Bags
On Board Air
Optima Redtop 34Rs
2010 John Deere 2305
9-11-2001 NEVER FORGET
neeltburn is offline
post #2 of 34 (permalink) Old 01-17-2009, 01:31 PM
fuzzy's Avatar
First off, why would this get moved to the general section. No other general dodge trucks have egr's, and dpf's, so it belongs in the 6.7 section. But all I can tell you is I started to run Howes. One quart treats 125 gallons, and I put one quart to 25 gallons, and filled my filters full with it. While the truck was high idling in the driveway, it turned the pretty white snow, black with soot. I had never noticed that before. Point is, I know I overkilled the additive, but I was glad I'm missing a few things. I would think a good 60/40 blend would keep you good without additive, but then your putting alot of trust in where your getting your fuel.
fuzzy is offline
post #3 of 34 (permalink) Old 01-17-2009, 01:35 PM
MART5.9's Avatar
I don`t think a good fuel conditionner has anything to do with plugged DPF and I rather get the DPF change 10 times under warranty than having a frozen fuel line and break down on the side of the road with temperature below -10. I`ll never get my butt frozen for Chrysler
One thing I can tell, is that when you`ve done the delete it takes forever for the truck to warm up but hey, that`s the only negative side I found so far about the delete!
2006 3500 mega cab SLT auto.
Diamond eye turbo back, S&B cold air intake,62mm turbo, billet tranny, smartyJR....
Proud to now participate to global warming
EGR and DPF are the worst CRAP ever and the worst is still to come.....UREA !
MART5.9 is offline
post #4 of 34 (permalink) Old 01-17-2009, 04:10 PM
2nd Gen Guru
Mopar1973Man's Avatar
I would say 2 cycle oil... But you can't use that...:
I've been down to -20*F and never had a single issue with gelling or freezeing of fuel yet.
I do not suggest anyone with DPF or 2007 or newer vehicle even trying 2 cycle oil...
Mopar1973Man is offline
post #5 of 34 (permalink) Old 01-17-2009, 05:29 PM
CrowsSynthetics's Avatar
Send a message via Yahoo to CrowsSynthetics
Post Diesel particulate filters
Originally Posted by neeltburn View Post
Guys,
Here is an additive that is compatible with the diesel particulate filters.
AMSOIL Diesel Concentrate is recommended for use with all types of heavy- and light-duty, on- or off-road and marine diesel engines. Recommended mix ratio is one oz. of additive per five gallons of fuel. Use with every new tank of fuel for the best performance and protection against fuel pump wear, injector wear and injector deposits. Compatible with all types of exhaust emission systems such as diesel particulate filters (DPFs). Add Diesel Concentrate to fuel before storage. Excellent for use with AMSOIL Cetane Boost and AMSOIL Cold Flow Improver. This diesel fuel additive complies with the federal low sulfur content requirements for use in diesel motor vehicles and non-road engines.
Bill
2003 F250 FX4 SUPERCAB SPORT XLT 7.3 PSD
Amsoil 3000 5w 30 ,Amsoil EaAU Air Filter ,Amsoil Pre filter-EaPF13,
Amsoil Dual Remote By-pass BMK-16A, Amsoil ATF & Transfer case, Amsoil 75w-140 fluid front & rear end, Amsoil Antifreeze Fluid
Edge with Attitude, 4" Turbo Back Exhaust,
5" SS Tip
, Transmission Magnefine filter, Sportman Tonneau Cover & Bush Fender Flairs
Now in the stable a new Black 2009 Jetta Sedan TDI
CrowsSynthetics is offline
post #6 of 34 (permalink) Old 01-17-2009, 10:04 PM Thread Starter
ADMIN/MAFIA
neeltburn's Avatar
I have heard that it does take longer to warm up with deletes. I still have a little while before I can do them. But so far so good this winter. When do you guys start to see gelling (Temp). Thanks guys lots of experience out there I appreciate the info.
Mopar Man, Yeah 2 cycle would not be good with this motor. Its kinda picky on what you feed it. I know there is fuel around here not to run and others it runs better than great on. I guess Ill keep giving it what it likes , and not give it what it doesn't.
6.7L 68RFE 4wd
Yeah its stock.
Pac Brake Air Bags
On Board Air
Optima Redtop 34Rs
post #7 of 34 (permalink) Old 01-17-2009, 10:39 PM
fuzzy's Avatar
I didn't gel until -15, and should mention that it geled in my remote located filters. What pi$$es me off, is that my fuel alone is supposed to be good to -20.
fuzzy is offline
post #8 of 34 (permalink) Old 01-17-2009, 11:18 PM
Diesel Recovery Emergency Fuel Treatment
This product just came out a few mouths ago.
If you live in cold climates it might be something to have in your tool box.
AMSOIL Diesel Recovery (DRC) is an emergency diesel fuel treatment that dissolves the wax crystals that form when diesel fuel has surpassed its cloud point. Diesel Recovery liquefies gelled diesel fuel and thaws frozen fuel filters, avoiding costly towing charges and getting diesels back on the road.
Fast Fuel Recovery
Diesel applications operating in extremely cold environments face some unique challenges. As the temperature drops, wax naturally found in diesel fuel begins to form crystals. The point at which wax crystals form is known as the cloud point. These wax crystals can eventually clog the fuel filter and starve the engine of fuel, preventing it from starting or even stalling out a running engine.
AMSOIL Diesel Recovery quickly dissolves gelled fuel to allow the operator to continue driving with minimal downtime. Diesel Recovery separates the molecular bonds of wax crystals that have agglomerated in diesel fuel. It thaws frozen fuel filters and reduces the need for a new filter, saving oney and preventing an inconvenient trip to an auto parts store.
Quickly Dissolves Gelled Fuel
Thaws Frozen Fuel Filters
Performs Well in ULSD, Off-Road & Biodiesel
Alcohol-Free
Non-Corrosive
5" SS Tip
post #9 of 34 (permalink) Old 01-17-2009, 11:31 PM
fuzzy's Avatar
Fast Fuel Recovery
Alcohol-Free
Non-Corrosive
So if your filters are geled, do you have to take them off an put some of this in, or can you just dump this in the tank?
fuzzy is offline
post #10 of 34 (permalink) Old 01-18-2009, 12:20 AM
Here is the instructions
Recommendations
One 30oz. bottle of Diesel Recovery treats 30 gallons of fuel. When encountering a gelled fuel system, AMSOIL recommends taking the following steps for maximum effectiveness:
Remove the existing fuel filter.
The filter can be reused, or a new filter can be installed.
Fill the replacement fuel filter with AMSOIL Diesel Recovery.
Install the replacement filter.
Add the remaining Diesel Recovery to the fuel tank.
Start the engine and allow the fuel system to circulate until full power has been restored.
5" SS Tip
Tags
amsoil diesel concentrate
oil as a fuel additive? dumpin96 1994-2003 7.3L Power Stroke 51 02-23-2014 09:16 AM
Fuel additive for increased MPG? Snow 5.9L Cummins 12 Valve (1994-1998.5) 23 01-19-2010 03:26 PM
Fuel additive powerstroke7.3 1994-2003 7.3L Power Stroke 7 12-02-2007 12:56 AM
Fuel additive? wpboyce Duramax 2006-2007(LBZ & LLY) 2 07-08-2007 10:45 AM
Best fuel additive for my 7.3? jebsurf 1994-2003 7.3L Power Stroke 46 06-09-2007 01:10 PM
