Pro's and Con's - Diesel Truck Forum - TheDieselGarage.com
Thread Details Posted by powerman, this thread has received 5 replies and been viewed 1912 times.
post #1 of 6 (permalink) Old 01-27-2009, 08:54 PM Thread Starter
Pro's and Con's
I am thinking about getting a new truck and want to know all the pros and cons of all the new trucks. I am going to make this thread on all three forums (ford, dodge, gm).
I am basically wanting to know about the issues that have been common with the new trucks and real world MPG. I do know more about the dodge's and ford's than the gms.
Dodge: 17+ mpg can be had, DPF get clogged up from idling...
Ford: a ton of 12/13 MPG trucks out there, radiator problems...
GM: ?
Those are the types of things I am looking for. If you want say what you think is great about each or bad about each.
powerman is offline
post #2 of 6 (permalink) Old 01-27-2009, 11:50 PM
fuzzy's Avatar
Dodge Pros:
CUMMINS
Factory Exhaust Brake
Did I say CUMMINS already?
I could go on but there's really no need. CUMMINS says it all.
Only con would be they have the most complex emissions systems. They are all having thier problems with emissions, but dodge has seemed to have the most. They have gotten alot better since the early 07.5's though. Plus they are easily defeated, and it can be done in many different ways, depending on how much money you want to spend.
fuzzy is offline
post #3 of 6 (permalink) Old 01-28-2009, 07:28 PM
pros : great truck with lots of power , CUMMINS engine , factory exhaust brake , and the dodge finally has a great transmission whether auto or manual .
cons : smog system ( but they seem to be giving much fewer problems now even the 07.5 like i have )
cummins engines have been around since the early 1900's and are used in a lot of commercial applications . the inline six cummins also has about 50% less moving parts as a comparable v-8 .
started with 1996 2500 4x4 auto
then a 2004.5 2500 4x4
now have a 2007.5 6.7 4x4 3500 drw mega cab 3:73 rear G56
Georgia Dawg is offline
post #4 of 6 (permalink) Old 01-28-2009, 07:31 PM
Built Not Bought
SOOTBANDIT's Avatar
Images: 9
Like Fuzzy CUMMINS says it all
Military Quote Of The Year
SOOTBANDIT is offline
post #5 of 6 (permalink) Old 02-03-2009, 04:19 PM
awesome truck with tons of power and just gobs of torque, besides when u do the deletes the mileage you get is far better compared to the competition.
Let alone the most impressive thing a CUMMINS!!!!!
2007.5 Ram 3500 4x2 QC
6 speed manual
Edge Attitude with/ Juice
MP-8
S&B Cold Air Intake
4" TBE Flo-Pro
DPF delete
Egr and Egr Cooler delete
Black Tec Mafia #19
BigRed6.7CTD is offline
post #6 of 6 (permalink) Old 02-03-2009, 06:39 PM
Ghost
Phily's Avatar
If you are thinking about a 6.7 I would highly recommend getting a 3500-4500-5500 chassis cab with the Aisin. It's built just as tough as the Allison. Maybe tougher, it does have a triple disk torque converter stock.
We could talk about Pros and Cons until our fingers bleed.
Phily is offline
SCT Livewire Help from the Pro's Fasteddie08 2008-2010 6.4L Engine Tuner Forum 6 01-16-2009 10:30 AM
pro's and con's betweem MBRP and just cut down pipe? 96stroker 1994-2003 7.3L Power Stroke 7 04-09-2008 03:15 PM
Pro's-Con's of AT 545 Intrailhunter Medium and Heavy Duty 4 04-07-2008 02:46 AM
need the pro's to pipe up!!!!!!!! TANK'S 250 2003-2007 6.0L Power Stroke 9 03-08-2006 03:09 AM
