p pumped 6.7 - Diesel Truck Forum - TheDieselGarage.com
Thread Details Posted by cat power, this thread has received 3 replies and been viewed 2085 times.
post #1 of 4 (permalink) Old 01-30-2009, 04:37 AM Thread Starter
smokin duramax
cat power's Avatar
p pumped 6.7
would it be possible to p pump a 6.7 and if so would it be better than a CR injection system ?
04 lb7 chevy 2500 Duramax Ext.CSB 4x4 6 speed
Engine : PPE 425 hp chip, Head stud kit, studded mains, dual cp3s, FASS, ATS Aurora 3000 & 5000 , and 5 inch straight pipe.
Transmission : zf6 , dual disc clutch , atlas II transfer case (daily driver)
88 s10 on a 1 ton frame , 350 .30 over 3/4 cam , afr 200cc heads , 800cfm thunder eldbrok , 14 bolt rear dana 60 front , np 205 with a munci m21 4speed tranny . 527 gears. dual radiaters sittin on 44s. ( TOY )
1987 CASE 1455B track loader / crawler loader
1997 CASE 1845C skid steer / bobcat
1990 CASE 580K 4x4 , turbo Backhoe
1968 CAT D9G dozer NEW WIDE TRACKS
1985 CAT D4H dozer High track
1993 CASE 1288 Track hoe / Excavator
1984 CAT D6D dozer
1987 GMC General tri axle dump , 855 cummins pump turned up, 4.88s 9 spd.
1986 GMC BRIGADIER single axle , 6v92 detroit pump turned up, 5.57s 9spd. custom goose neck, tool/welding Bed
1988 chevy C70 CC single dump , 8.3 cummins , 100# fuel plate 9 speed , 6.57s
1990 PETE 375 Dump quad axle , 3406B cat (dumpin the fuel ) , 18spd. 5.13s
2003 Chevy C5500 CC 4x4 duramax , 208wb. 6spd. 4.56s , long flatbed goose neck
300hp ppe chip , Fass, head studs , Aurora 3000, dual disc clutch , 5" straight pipe
cat power is offline
post #2 of 4 (permalink) Old 01-30-2009, 04:56 AM
Yeah. There are a few p-pumped 5.9 cr's, well used to be cr. I think people have this p-pump or nothing idea, but these common rails can make a ton of power. dual c3p's that are stock are 1,000hp + capable but with some modded units then it's really about getting the airflow. The CR injection system can do multiple injection events and allow for more precise fuel delivery.
There are a few guys out there with 6.7 cummins using the 5.9 electronics. Which allows for full use of the bigger stroke of the 6.7 without all the emissions components and electrical set-up. I know p-pump may seem awesome but the Common Rail set-up is still a great fuel system.
Ken
silvrcummns is offline
post #3 of 4 (permalink) Old 01-30-2009, 08:53 AM
Ghost
Phily's Avatar
This isn't a P Pump but it's still pure mechanical and it's a 12v 6.7.
Phily is offline
post #4 of 4 (permalink) Old 01-31-2009, 02:18 PM
although the P pump is quite the fueler... it has nothing on a CR and about 100 more parts to go bad
triton is offline
P-Pumped "Piston-Pump" Powerstroke imported_Stroker01 1994-2003 7.3L Power Stroke 84 02-15-2008 08:00 PM
P-pumped 3rd generation ctd18 5.9L Cummins (2003-2007.5) 33 12-16-2007 01:35 AM
rotary pumped DT466 nevrenufhp Medium and Heavy Duty 3 11-12-2006 01:36 PM
