egr questions - Diesel Truck Forum - TheDieselGarage.com
Thread Details Posted by BigRed6.7CTD, this thread has received 7 replies and been viewed 1382 times.
post #1 of 8 (permalink) Old 02-02-2009, 11:14 PM Thread Starter
egr questions
did the egr and cooler delete today and it surges a bit at start up but throws a check engine light constantly this won't send my truck into limp mode will it???
BigRed6.7CTD is offline
post #2 of 8 (permalink) Old 02-02-2009, 11:25 PM Thread Starter
is there anything else to worry about, I will live with the cel but just trying to think ahead will post what the codes are later.
2007.5 Ram 3500 4x2 QC
6 speed manual
Edge Attitude with/ Juice
MP-8
S&B Cold Air Intake
4" TBE Flo-Pro
DPF delete
Egr and Egr Cooler delete
Black Tec Mafia #19
post #3 of 8 (permalink) Old 02-03-2009, 12:13 AM
Let it all Ride
Eazydeezy's Avatar
When I had my truck I noticed the same thing. I did have my edge set to flash codes on start up so the light never bothered me. However when I first did it, I let the light come on a stay on for a day and my truck never once went into limp mode. You shouldn't have anything to worry about.
Dominic
Eazydeezy is offline
The Following User Says Thank You to Eazydeezy For this addition to TDG:
BigRed6.7CTD (02-03-2009)
post #4 of 8 (permalink) Old 02-03-2009, 12:43 AM
no mines been deleted for 15k miles no limp mode just cel. did you remove the buterfly valve out of the intake?
08 cummins 6.7, smarty 18 me , diablo power puck, [email protected] 4 inch turbo back,[email protected] custom air box,bod wastegate, egr and cooler mia, sb 3600 dd
mopar6.7 is offline
The Following User Says Thank You to mopar6.7 For this addition to TDG:
post #5 of 8 (permalink) Old 02-03-2009, 01:11 AM
fuzzy's Avatar
If you haven't removed the throttle body valve (butterfly), you might try to, and see if that takes care of your surging. The light is normal, and should be nothing to worry about.
fuzzy is offline
The Following User Says Thank You to fuzzy For this addition to TDG:
post #6 of 8 (permalink) Old 02-03-2009, 02:56 AM Thread Starter
no I didn't pull out the butterfly, the surges are barely noticable and go away within a min of startup.
6 speed manual
MP-8
S&B Cold Air Intake
4" TBE Flo-Pro
DPF delete
Black Tec Mafia #19
post #7 of 8 (permalink) Old 02-03-2009, 07:29 PM
Built Not Bought
SOOTBANDIT's Avatar
Images: 9
BigRed nothing to worry about i have put almost 20,000 on it since the deletes and no problem i also have not removed the valve that surge is a pain to live with but it goes right away in mine also but it only does it if the edge is set to clear codes on startup???? i just stare at that light now dont worry if something was going to gernade it would of done it already. That cel light is my go fast light lol
Military Quote Of The Year
SOOTBANDIT is offline
post #8 of 8 (permalink) Old 02-04-2009, 12:36 PM Thread Starter
I agree
CEL= Haul A**
6 speed manual
MP-8
S&B Cold Air Intake
4" TBE Flo-Pro
DPF delete
Black Tec Mafia #19
Three questions? cummins kid 5.9L Cummins 12 Valve (1994-1998.5) 10 02-02-2008 08:50 PM
Two questions re: 6.6 LMM wharf rat Duramax 07.5-2010 (LMM) 3 12-11-2007 11:05 AM
7.3 Questions Big Gray dodge 1994-2003 7.3L Power Stroke 8 11-04-2007 02:31 AM
Soon to buy an '04 6.0... Questions COTTS4x4 2003-2007 6.0L Power Stroke 6 04-10-2006 08:37 AM
First tow...tranny questions and chip questions 05TowBoss 2003-2007 6.0L Power Stroke 5 11-07-2005 11:17 PM
