Mp-8 - Diesel Truck Forum - TheDieselGarage.com
Thread Details Posted by BigRed6.7CTD, this thread has received 21 replies and been viewed 2221 times.
post #1 of 22 (permalink) Old 02-06-2009, 02:25 PM Thread Starter
Mp-8
ok thinking about stacking the mp-8 with the edge, how difficult is the install and does it really give that much better power and mileage?
2007.5 Ram 3500 4x2 QC
6 speed manual
Edge Attitude with/ Juice
MP-8
S&B Cold Air Intake
4" TBE Flo-Pro
DPF delete
Egr and Egr Cooler delete
Black Tec Mafia #19
BigRed6.7CTD is offline
post #2 of 22 (permalink) Old 02-06-2009, 02:31 PM
Proud Texan
madville's Avatar
It is most definately worth it in my opinion. Hardest part is reaching the plug so you can hook up the box. Taking the valve apart and stuff isn't as difficult as people make it out to be.
Scooter
2008 Dodge Ram QC CTD 6.7L
Performance: Magnaflow straight 5" TBE, Industrial Injection Hybrid VGT, S&B CAI, H&S Performance XRT, Shibby EGR/EGR Cooler delete.
Exterior: Recon Smoked Cab lights, Windows tinted, Spray-in bedliner, Black nerf bars
Interior: Putco LED Dome lights, Alpine IVA-W505 Headunit, Marathon Realtree Camo Seat Covers
American Club #17
Singles Club #0
madville is offline
post #3 of 22 (permalink) Old 02-06-2009, 05:49 PM Thread Starter
so I will need the fuel rail plug?
6 speed manual
MP-8
S&B Cold Air Intake
4" TBE Flo-Pro
DPF delete
Black Tec Mafia #19
post #4 of 22 (permalink) Old 02-07-2009, 12:30 AM
fuzzy's Avatar
You need to shim the rail relief valve. I don't think you should put the plug in stacked with edge. Just running the mp-8 would be ok to use the plug, but stacked, I would shim it.
fuzzy is offline
The Following User Says Thank You to fuzzy For this addition to TDG:
BigRed6.7CTD (02-08-2009)
post #5 of 22 (permalink) Old 02-07-2009, 03:14 AM Thread Starter
is the plug kevin sells a shimmed version or is it something else? it says to be used in place of fuel rail shim provided with mp8. so i guess it is an altered plug that is already shimmed.
6 speed manual
MP-8
S&B Cold Air Intake
4" TBE Flo-Pro
DPF delete
Black Tec Mafia #19
post #6 of 22 (permalink) Old 02-07-2009, 05:38 PM
Proud Texan
madville's Avatar
If you are running just the MP-8 then the plug is ok. Keven will tell you the same thing, I know he spent hours on the phone convincing me on what the best routes to take are for any mods. If you are stacking then use the shims provided with the MP-8. It is not a hard mod to do. Just clean the floor wherever you are doing the shimming before you start, incase your pin pops out.
Scooter
American Club #17
Singles Club #0
madville is offline
The Following User Says Thank You to madville For this addition to TDG:
post #7 of 22 (permalink) Old 02-08-2009, 01:21 PM
Built Not Bought
SOOTBANDIT's Avatar
Images: 9
Ok so who can tell me the diff between just shimming the fuel release valve and stacking the mp8? Cause when you install the mp8 you shim the rail correct? Now lets say you dont install the mp8 and you just shim the fuel release valve. What are you gaining with either cause if i can shim the release valve and gain some extra why spend $400.
Military Quote Of The Year
SOOTBANDIT is offline
post #8 of 22 (permalink) Old 02-11-2009, 04:46 PM
if u just shim the rail u wont get anything out of it...... when u shim with the MP-8 the mp-8 increases rail pressure and the shim doesnt allow rail relief until a higher pressure than stock
kcpanages is offline
post #9 of 22 (permalink) Old 02-12-2009, 03:01 PM
rbisch's Avatar
You should be warned increasing rail pressure may cause injector damage. I do not believe there is a gauge available for the 6.7, at this time, that accurately measures rail pressure after you fool the ECM with a chip.
2007.5, dodge, mega cab, 6.7, 68rfe, 3.73, 4x4, dog box, EGR disabled, [email protected] 4" TBE, Edge Insight.
rbisch is offline
post #10 of 22 (permalink) Old 02-12-2009, 04:03 PM
Built Not Bought
SOOTBANDIT's Avatar
Images: 9
I wish big blue would chime in see what his take is to be honest kinda scared but you only live once lol
