Pulling power with reliability - Diesel Truck Forum - TheDieselGarage.com
Thread Details Posted by heavyhaller, this thread has received 18 replies and been viewed 1509 times.
post #1 of 19 (permalink) Old 02-09-2009, 11:44 PM Thread Starter
I pull an 18000lb 5er with my 06 f350 towboss (4:30s). I am thinking of changing to an 08 3500 dodge with 4:10 with an automatic trans. Will it pull my trailer reliably with more pulling power then my Ford and not over heat the engine or trans or high egt's. My Ford is rated to pull 18000 lb's and the Dodge 16000 lb's but I think they are under rated unless the frames are the weak link. What do you guys think.
heavyhaller is offline
post #2 of 19 (permalink) Old 02-09-2009, 11:53 PM
Ghost
Phily's Avatar
Well you can't beat a Ford frame. But I'd trust the Engine and Transmission more in the Dodge. If you do a 3500 get the chassis and cab with the Aisin. Haven't heard much bad about either Automatic behind the 6.7 but I imagine the Aisin is built to last a few thousand miles.
Phily is offline
The Following User Says Thank You to Phily For this addition to TDG:
heavyhaller (02-10-2009)
post #3 of 19 (permalink) Old 02-09-2009, 11:58 PM
Built Not Bought
SOOTBANDIT's Avatar
Images: 9
The frames on the newer dodges are fully boxed. I could be wrong but i believe the fords are c channeled.
Military Quote Of The Year
SOOTBANDIT is offline
The Following User Says Thank You to SOOTBANDIT For this addition to TDG:
post #4 of 19 (permalink) Old 02-10-2009, 12:05 AM
I agree with BIGBADDODGE that is the only difference I have seen as far as frames go. The powertrain area is a major difference, the cummins adds better mileage and better all around power.
2007.5 Ram 3500 4x2 QC
6 speed manual
Edge Attitude with/ Juice
MP-8
S&B Cold Air Intake
4" TBE Flo-Pro
DPF delete
Egr and Egr Cooler delete
Black Tec Mafia #19
BigRed6.7CTD is offline
The Following User Says Thank You to BigRed6.7CTD For this addition to TDG:
post #5 of 19 (permalink) Old 02-10-2009, 12:15 AM
Ghost
Phily's Avatar
I don't know either way, I can't even afford a test drive in a newer truck.
But in the past Fords just had some of the strongest frames out there.
Phily is offline
post #6 of 19 (permalink) Old 02-10-2009, 12:26 AM
Built Not Bought
SOOTBANDIT's Avatar
Images: 9
heavyhauler if you do end up getting the 3500 dodge you will be extremely happy with the way it pulls plus factory exhaust brake and the power diff between the 6.0 and the 6.7 stock for stock the 6.0 wont hold a candle to the 6.7 in my opinion
post #7 of 19 (permalink) Old 02-10-2009, 12:43 AM
MART5.9's Avatar
Rated, rated rated ya right ! I`d use my own esperience and ``head`` before looking at what is on paper! Use to have a truck 7000 lbs rated and the thing was dying and hard to drive safely with 5500lbs! One thing I know for sure is the 6.7L is way overkill for any pick-up frame so; for pulling don`t worry. Secondo I would really feel better pulling 18 000lbs with a 6.7L than anything else on the market. One safety feature that makes a huge difference when pulling real heavy loads is the exhaust brake. Towing capacity on based on frame on one side but on braking power too. I almost never use the brakes exept for the last 10 feet at a stop sign pulling 12 500 lbs and heavier you are harder the exhaust brake will work. The 6.7 has it`s full torque at 1500rpm wich makes it such a low revs engine, nice and smooth and relax to pull with!
2006 3500 mega cab SLT auto.
Diamond eye turbo back, S&B cold air intake,62mm turbo, billet tranny, smartyJR....
Proud to now participate to global warming
EGR and DPF are the worst CRAP ever and the worst is still to come.....UREA !
MART5.9 is offline
The Following User Says Thank You to MART5.9 For this addition to TDG:
post #8 of 19 (permalink) Old 02-10-2009, 12:49 AM
stillcrazyinlaw's Avatar
Images: 3
My experience with both.
My best buddy has a 1 ton ford with a 6.0 don't know the gears. It struggles with a 12,000 lb bumper pull toy hauler. It will tow it but not comfortably.
My 07 3500 mega W/6.7 cummins will pull that same trailer like its not there. 70 up a 6% grade is too easy.My 36' fifth wheel toy hauler weighs 13,500 empty when loaded ?? The dodge pulls it easy and the exhaust brake works great. I'm not a ford fan so I'm probably a little bias but my truck pulls better than his ford and handles the weight better hands down.
my .02
Yulan
stillcrazyinlaw is offline
The Following User Says Thank You to stillcrazyinlaw For this addition to TDG:
post #9 of 19 (permalink) Old 02-10-2009, 01:03 AM
Ghost
Phily's Avatar
How many miles do you have on yours now?
Phily is offline
post #10 of 19 (permalink) Old 02-10-2009, 01:52 AM
MART5.9's Avatar
Close to 30 000 miles . By the way too bad you don`t live on this side of the border....Nice truck! I would be thinking about getting it! All the 2002 and older are rusted or dead uphere and I still think there`re the best looking trucks ever!
MART5.9 is offline
400 hp Reliability and Breakage genie144 General Ford Truck and Excursion 32 06-09-2007 11:41 PM
6.5 reliability ratherbestrokinthancummin 6.5L Diesel Engine 11 12-30-2006 11:22 AM
Power vs. Reliability bad_cummins 5.9L Cummins (1998.5-2002) 1 09-20-2006 05:00 AM
tranny reliability ratherbestrokinthancummin 5.9L Cummins (1998.5-2002) 4 08-05-2006 02:01 PM
Need pulling power Fantom3993 1994-2003 7.3L Power Stroke 12 09-11-2005 08:49 PM
