High EGT's - Diesel Truck Forum - TheDieselGarage.com
Thread Details Posted by eby94, this thread has received 18 replies and been viewed 1877 times.
post #1 of 19 (permalink) Old 02-14-2009, 03:55 AM Thread Starter
High EGT's
Drove into town tonight, coming back with cruise control set at 65, my egt's were around 1050+/-. Outside temp was about 43 degrees. Truck ran fine, no problems or codes with Edge setting on #1. Don't know if this was because of cold weather but any suggestions would be appreciated.
2007 3500 4x4
6.7l
dpf delete
egr delete
edge/attitude
eby94 is offline
post #2 of 19 (permalink) Old 02-14-2009, 04:09 AM
ADMIN/MAFIA
neeltburn's Avatar
First of where is you probe. Pre Turbo or Post Turbo? I generally see that temp 1000* but I assume its because of the the DPF in regen. With the delete what do you EGT's normally run?
6.7L 68RFE 4wd
Yeah its stock.
Pac Brake Air Bags
On Board Air
Optima Redtop 34Rs
2010 John Deere 2305
9-11-2001 NEVER FORGET
neeltburn is offline
post #3 of 19 (permalink) Old 02-14-2009, 12:12 PM Thread Starter
My probe is preturbo, this is the first time this has happened. Since I did all the deletes it usually ran on average about 650 +/-, but last night was extremely high for cruising speed and no boost
2007 3500 4x4
6.7l
dpf delete
egr delete
edge/attitude
eby94 is offline
post #4 of 19 (permalink) Old 02-15-2009, 02:16 AM
Built Not Bought
SOOTBANDIT's Avatar
Images: 9
My probe is in the downpipe and on level 6 on a long pull on a straight my edge has been up to 900-1000 my edge is set at 1100 but it never went off but i know my probe being post turbo im off bout 250 -300* havent had a problem yet im pretty sure they can handle the heat some sled pullers on here have had them hit 1500 i think. I also think bigblue has had fairly high egts. I think your safe just keep an eye out on it
Military Quote Of The Year
SOOTBANDIT is offline
post #5 of 19 (permalink) Old 02-15-2009, 11:23 AM
i have had mine hit 1400+ a number of times when i really hammer it. not sure as to why yours spiked that one time though. mine runs very consistent.
mastercaster is offline
post #6 of 19 (permalink) Old 02-15-2009, 11:26 AM
Built Not Bought
SOOTBANDIT's Avatar
Images: 9
eby94 was you going up any hills?? Also was it really windy cause mine has came up before for wind especially in wyoming. Any drag on the motor is going to make the egts climb some
post #7 of 19 (permalink) Old 02-15-2009, 01:01 PM Thread Starter
I was on level ground with no load and monitor showing 0 boost. My egts did not spike and go back down, they were at a constant 1050 +/- for about 10 miles until I got home. I let the truck idle for about 5 minutes and it only went down to about 600 degrees.
2007 3500 4x4
6.7l
dpf delete
egr delete
edge/attitude
eby94 is offline
post #8 of 19 (permalink) Old 02-15-2009, 01:09 PM
Built Not Bought
SOOTBANDIT's Avatar
Images: 9
what had it been getting down to before you shut it off before this episode?
post #9 of 19 (permalink) Old 02-15-2009, 01:17 PM
Built Not Bought
SOOTBANDIT's Avatar
Images: 9
Cause with me letting it cool down the lowest it got in a couple min was 275-300* now remember for me i add 200-250* for the probe position its been like that from day one so if i just cruise around town i and play a little then go home let it sit for 2 min then if i have been driving all day or hauling a load i let it go to 300* then shut it off
post #10 of 19 (permalink) Old 02-15-2009, 05:28 PM Thread Starter
Before this happened it would cool down around 350 +/-. Drove around today, outside temp aprox 48 degrees and everything was normal. I can not expain the other night, just drives me nuts when I can't figure something out
2007 3500 4x4
6.7l
dpf delete
egr delete
edge/attitude
eby94 is offline
High EGT'S GOFASORGOBROK 2003-2007 6.0L Power Stroke 7 04-17-2008 09:39 PM
High EGT'S Bcarriveau 2003-2007 6.0L Power Stroke 20 12-18-2007 10:57 PM
High EGT's? Superdutytd 2003-2007 6.0L Power Stroke 11 08-01-2007 03:07 AM
high egt's weebz90 5.9L Cummins (1998.5-2002) 9 05-19-2007 05:57 AM
High EGT's HillbillySD 2003-2007 6.0L Power Stroke 7 05-16-2006 05:09 PM
