6.7L Remote ByPass filters mods and remount - Diesel Truck Forum - TheDieselGarage.com
Thread Details Posted by 2007CumminZ, this thread has received 5 replies and been viewed 2983 times.
post #1 of 6 (permalink) Old 02-15-2009, 09:46 PM Thread Starter
Filters are mounted on 1/8" plate which will be mounted perminent to frame.
I used flex plastic conduit to protect oil lines. I also like the idea of running the hoses away from the turbo side of the engine which is much hotter.
Also be advised that this is not the way AMSOil recommends the install.
2007CumminZ is offline
post #2 of 6 (permalink) Old 02-16-2009, 01:02 AM
Maybe I don't understand but if that is oil filters then why didn't you block off the egr and stop all of the sooting and accomplish the same thing with less $$$?
2007.5 Ram 3500 4x2 QC
6 speed manual
Edge Attitude with/ Juice
MP-8
S&B Cold Air Intake
4" TBE Flo-Pro
DPF delete
Egr and Egr Cooler delete
Black Tec Mafia #19
BigRed6.7CTD is offline
post #3 of 6 (permalink) Old 02-16-2009, 02:11 AM
Kummins's Avatar
Big Red I've been looking at the same thing and would like to hear from more people doing this. In short these filters are supposed to filter particulates, like soot, that your regular oil filter can't. This accomplishes two things:
1 - Extends oil change intervals
2 - Protects your engine better
Apparently this is particluarly important when running tuners and other mods that can increase soot that get into in the oil. This doesn't apply to just EGR engines, it supposely effects all diesel engines.
06 2500 Quadcab SLT
Billet Tranny
BD with Crazy Larry
Quadzilla Boost Fooler
S&B Intake
MBRP all the way back and "High Flow Cat"
6" Lift, 35" Toyo MT's, 20" Incubus wheels
Some Audio Goodies Too
MAY 2008 TDG Truck of the Month
Kummins is offline
post #4 of 6 (permalink) Old 02-16-2009, 04:52 AM Thread Starter
This is my retirement truck. I plan on doing all I can to this truck to make it efficient as possible and stay friendly to the world we live in. If I can extend the amount of oil it uses and does less damage to the internal parts I am for it.
post #5 of 6 (permalink) Old 02-17-2009, 12:04 AM
ok , good to know something new...but I thought bottom line was all the sooting came from the egr and tune hence you get rid of the egr and the soot from the tune goes out the tailpipe?
6 speed manual
MP-8
S&B Cold Air Intake
4" TBE Flo-Pro
DPF delete
Black Tec Mafia #19
post #6 of 6 (permalink) Old 02-17-2009, 01:24 AM
CrowsSynthetics's Avatar
Send a message via Yahoo to CrowsSynthetics
This is a reply to several of your Questions
Soot Removal
AMSOIL has designed a new high-efficiency by-pass filter element that is also a soot removal device. AMSOIL Ea By-Pass Filters use a synthetic/cellulose sandwiched media. The inner layer of the element is composed of a highly efficient cellulose media covered with a full synthetic media outer layer. These filters remove 39 percent of soot contaminants less than one micron. Soot removal efficiency increases approximately 10 to 14 percent when the EaBP Filter is used in conjunction with a standard full-flow filter.
By-Pass Filtration Benefits
  • Dramatically Extended Drain Intervals
  • Improved Oil Cooling
  • Increased Filtration Capacity and Life
  • Increased Fluid System Capacity
  • Efficient Small Particle and Soot Removal
  • Significantly Extended Engine Life
  • Equipment Constantly Runs on Clean Oil
  • Increased Engine Efficiency
  • Remove Particles Less Than One Micro
Our OEM filter
AMSOIL Ea Oil Filters have the best efficiency rating in the industry. EaO Filters provide a filtering efficiency in accordance with industry standard ISO 4548-12 of 98.7 percent at 15 microns, while competitive filters containing conventional cellulose medias range from 40 to 80 percent efficiency.
And by the way clean install.
Bill
2003 F250 FX4 SUPERCAB SPORT XLT 7.3 PSD
Amsoil 3000 5w 30 ,Amsoil EaAU Air Filter ,Amsoil Pre filter-EaPF13,
Amsoil Dual Remote By-pass BMK-16A, Amsoil ATF & Transfer case, Amsoil 75w-140 fluid front & rear end, Amsoil Antifreeze Fluid
Edge with Attitude, 4" Turbo Back Exhaust,
5" SS Tip
, Transmission Magnefine filter, Sportman Tonneau Cover & Bush Fender Flairs
Now in the stable a new Black 2009 Jetta Sedan TDI
CrowsSynthetics is offline
Bypass oil filters huston General Ford Truck and Excursion 15 02-08-2008 06:02 PM
NEW Amsoil remote bypass 7.3 mattymx Whats Been Sold 1 01-15-2008 06:24 PM
Engine mods Vs tranny mods Squamish smoker 2003-2007 6.0 Tuner Forum 1 07-12-2007 01:44 PM
Bypass oil filters yamaman 2003-2007 6.0L Power Stroke 7 05-10-2007 11:18 PM
Egr Bypass Questions JSxFX4 2003-2007 6.0L Power Stroke 19 02-10-2007 12:19 PM
