question - Diesel Truck Forum - TheDieselGarage.com
Thread Details Posted by BigRed6.7CTD, this thread has received 1 replies and been viewed 653 times.
post #1 of 2 (permalink) Old 02-22-2009, 03:42 AM Thread Starter
question
I was wondering if it is normal for my truck with all of the deletes being done to do the egr surge thing and blow a couple of white puffs of smoke out?
2007.5 Ram 3500 4x2 QC
6 speed manual
Edge Attitude with/ Juice
MP-8
S&B Cold Air Intake
4" TBE Flo-Pro
DPF delete
Egr and Egr Cooler delete
Black Tec Mafia #19
BigRed6.7CTD is offline
post #2 of 2 (permalink) Old 02-23-2009, 06:02 PM
Built Not Bought
SOOTBANDIT's Avatar
Images: 9
Hey Big if you did not take the butterfly valve of the intake horn and if you have your edge setup to clear codes on startup it will get a surge and a few puffs of white/blueish smoke out on startup. I just dont clear my codes on startup and it does dont do this at all i know now you are thinking why does it do it when codes are cleared i dont know. But nothing to worry bout 20,000mi deleted im going to take the bulb out lol no seriously as long as the check engine light doesnt start flashing while its running your fine if it starts to flash its prob going to gernade be a good show lol.
Clear codes on startup with butterfly valve still in= smoke and surge on startup
Not set to clear on startup with butterfly valve still in= no smoke except black. Hopes this helps
Military Quote Of The Year
SOOTBANDIT is offline
The Following User Says Thank You to SOOTBANDIT For this addition to TDG:
BigRed6.7CTD (02-23-2009)
Turbo Question(Tech Question) Liftedpsd 2003-2007 6.0L Power Stroke 7 09-16-2007 03:35 PM
Boost question, maybe MAP sensor question 6_Myles 1994-2003 7.3L Power Stroke 5 10-28-2006 12:42 AM
Edge Juice Question Question Jaadc01 General Ford Truck and Excursion 6 05-23-2006 12:40 PM
