quick ? - Diesel Truck Forum - TheDieselGarage.com
Thread Details Posted by stillcrazyinlaw, this thread has received 2 replies and been viewed 696 times.
post #1 of 3 (permalink) Old 02-28-2009, 01:41 AM Thread Starter
stillcrazyinlaw's Avatar
Images: 3
quick ?
I changed my oil today and the filter was only 1/2 full.????? Whats up with that?
Yulan
stillcrazyinlaw is offline
post #2 of 3 (permalink) Old 02-28-2009, 02:33 AM
fuzzy's Avatar
That's awesome, and nothing to worry about. I'm not real sure, but it has to do with where it's at, and instead of running all over when you loosen it, it drains back to the pan. I always crack mine a little loose and let it be for a little bit, then spin it off, and it never makes a mess. I read somewhere it has something to do with where it's at, and it's higher than something else. Not a real technical responce, cause I can't remember exactly what I read, but I think your fine.
fuzzy is offline
post #3 of 3 (permalink) Old 02-28-2009, 02:41 AM Thread Starter
Images: 3
Cool everything else seems to be fine so I won't worry about it.
quick topflight250 1994-2003 7.3L Power Stroke 1 01-31-2009 02:28 AM
Just a Quick Thanks to You All austin1972 1994-2003 7.3L Power Stroke 12 02-04-2008 05:04 AM
Need Help Quick! Redneck8505 Duramax 2001-2004 (LB7) 3 01-08-2008 02:15 AM
Need Help Quick!!!!!! imported_smokindodge12v 5.9L Cummins 12 Valve (1994-1998.5) 11 02-21-2007 03:50 PM
HELP Quick!!!! Muddin General GM Truck Forum 9 08-03-2006 03:32 PM
