6.7L Rail Pressure Gauges - Diesel Truck Forum - TheDieselGarage.com
Thread Details Posted by Michael, this thread has received 4 replies and been viewed 840 times.
post #1 of 5 (permalink) Old 03-06-2009, 09:32 PM Thread Starter
Supporting Vendor
As many people have probably learned, the 6.7L has a different rail pressure sensor than the 5.9L used. ISSPRO's Performax & EV² Rail Pressure gauge harnesses are "universal", allowing them to plug into either sensor. We now make the rail pressure gauges with the software for the 6.7L curve. The part number is the same as the old rail pressure gauges (in the various styles) but replacing "288" with "289". In other words, the EV² 6.7L Rail Pressure gauge in the white face/red pointer (factory match for 3rd gen Dodge) is R14289.
Regards,
Michael Pliska
ISSPRO Engineering Manager
1995 F350 PSD Crew Cab Dually, 271k miles
10 ISSPRO Prototype Performax™ gauges in Pillar & Overhead pods & sitting on dash, Tymar Intake, Gutted EBPV, Tymar 3x4" downpipe, Tymar 5" exhaust, Cat's hiding in the shed, Baby Swamps, Swamps tunes, Tricumulator springs and Accumulator Valve, Tru-Cool 4590 Trans Cooler, Lock-Right Locker
1998 S&S 9.5' slide-in camper
32' enclosed tag trailer with 2 drag cars (73 Vega Super-Gas & 74 Vega ET Super-Pro)
1992 GMC Typhoon, 1973 Chevy Blazer with Pontiac 400, 1973 Trans-Am 455
2000 VW Jetta TDI - Kerma tune, Der Chimera Stage II Clutch
NRA member and certified firearms instructor, GOA Life member, IDPA member
Michael is offline
post #2 of 5 (permalink) Old 03-06-2009, 10:31 PM
fuzzy's Avatar
Will it read accurate readings if your running a pressure box?
fuzzy is offline
post #3 of 5 (permalink) Old 03-06-2009, 10:47 PM Thread Starter
Supporting Vendor
Yup, just make sure you "stack" your pressure box harness on the ECU side, so that the ISSPRO harness is the one closest to the sensor.
Regards,
Michael Pliska
Michael is offline
post #4 of 5 (permalink) Old 03-07-2009, 12:10 AM
CSIPSD's Avatar
...Made in USA too...
CSIPSD is offline
post #5 of 5 (permalink) Old 03-10-2009, 02:13 AM
Super Moderator
4rcFed's Avatar
Images: 12
Michael, can I test one of those for 'ya!
2008 Dodge 2500 Mega Ram, SLT, Powered by a little 'ol 408 cubic inch six cylinder!!!
Chrysler's warranty = Not worth the paper it is printed on!!!
Gone, but not forgotten!!!
1997 FORD F-250 HD
7.3L, XLT, Off-Road Package
3.55's, E4OD, 4wd, Dana 60 swap, 3" Sky RSK, 315/70/17's on Racelines.
4rcFed is offline
Rail Pressure Gauges for LBZ/LMM Michael Duramax 07.5-2010 (LMM) 0 03-06-2009 08:38 PM
Rail Pressure chizwizdiz 5.9L Cummins (2003-2007.5) 5 01-12-2009 04:01 AM
isspro rail pressure smokeyourdiesel Supporting Vendors Forum 4 04-23-2008 10:09 PM
The Best Wat To Check Rail Pressure kylewilborn 5.9L Cummins (2003-2007.5) 1 12-31-2007 02:42 PM
Fuel rail pressure sensor turbo606 5.9L Cummins (2003-2007.5) 1 04-08-2007 03:34 AM
