Auto Tranny help - Diesel Truck Forum - TheDieselGarage.com
Thread Details Posted by BigBlueDodge, this thread has received 17 replies and been viewed 1513 times.
post #1 of 18 (permalink) Old 03-10-2009, 05:38 PM Thread Starter
BigBlueDodge's Avatar
Auto Tranny help
So i'm thinking my tranny is goin. It cant decide what gear it wants when im at higher speeds like sixty to ninety. I was just wonderin if anyone has had this happen or if anyone has some input on a good build for one.
07 6.7
6 Inch lift
37-13.50 Nitto Mud Grapplers
XRT WOOO
Ts-mp8
S&B Intake
5 inch to 7 inch mitter cut stacks
egr all gone
2 10 inch mtx subs
Tint
Boost Fooler
Black Head and Tail lights
BigBlueDodge is offline
post #2 of 18 (permalink) Old 03-11-2009, 04:33 AM
ADMIN/MAFIA
neeltburn's Avatar
I know easy roasted his trans and had it replace. As far as I know there is not a lot of choice for the 68rfe other than a stock replacement..
6.7L 68RFE 4wd
Yeah its stock.
Pac Brake Air Bags
On Board Air
Optima Redtop 34Rs
2010 John Deere 2305
9-11-2001 NEVER FORGET
neeltburn is offline
post #3 of 18 (permalink) Old 03-11-2009, 03:14 PM Thread Starter
Dang ha thats not good.
07 6.7
6 Inch lift
XRT WOOO
Ts-mp8
S&B Intake
egr all gone
2 10 inch mtx subs
Tint
Boost Fooler
post #4 of 18 (permalink) Old 03-11-2009, 04:47 PM
Born in the USA
patriot2500's Avatar
Send a message via AIM to patriot2500
Might want to check with Dave Goerand. I think he has stuff out for the new tranny, but am not 100% sure of that.
Tom
2004.5 Dodge 2500 QC/LB - Goerand 48RE, 4.10's, AFE Stage II, Magnaflow 5" TBE w/6" tip, Smarty TNT/REVO, PacBrake, ATS Manifold, ATS Triple Lok Commander, ISSPRO EGT, Trans, Boost on the pillar, FASS 150, 35X12.50 Toyo M/T's on '06 wheels, Mag/Hytec front/rear diff covers and trans pan, Full Recon Lighting, Prodigy Brake Controller, Silverstars, WeatherGuard Toolbox, BackRack, Kenwood Radio w/ 2 MTX Thunder 4500 subs, Sirius, CompuStar Alarm/Remote Start, Husky Floormats
Thanks to Kenny @ KTPerformance.net
2007 Honda Foreman 500 ES - Rack bag, gun racks, trailer hitch, Cycle Country plow, 27" ITP's on ITP Delta Steel Wheels
patriot2500 is offline
post #5 of 18 (permalink) Old 03-11-2009, 06:22 PM
Ghost
Phily's Avatar
That'd be the direction I'd head too.
Phily is offline
post #6 of 18 (permalink) Old 03-11-2009, 08:23 PM Thread Starter
Ok sweet will have to do that soon before it goes.
07 6.7
6 Inch lift
XRT WOOO
Ts-mp8
S&B Intake
egr all gone
2 10 inch mtx subs
Tint
Boost Fooler
post #7 of 18 (permalink) Old 03-16-2009, 09:20 PM
Kummins's Avatar
Is it slipping at all? I don't know about the 68re but the 48re is a gear huntin motha especially with power mods. Mine is no longer a stock tranny and the gear hunting is actually worse. It never knows what gear it wants to be in especially at higher speeds. It will shift in and out of overdrive. I finally just pushed the OD button off till I hit 85 then turn it on and let it shift. Works great for me and the EGT's stay lower with the pattern too.
I'm exaggerating a little but it is a common problem. When mine went it out is started slipping like crazy.
06 2500 Quadcab SLT
Billet Tranny
BD with Crazy Larry
Quadzilla Boost Fooler
S&B Intake
MBRP all the way back and "High Flow Cat"
6" Lift, 35" Toyo MT's, 20" Incubus wheels
Some Audio Goodies Too
MAY 2008 TDG Truck of the Month
Kummins is offline
post #8 of 18 (permalink) Old 03-17-2009, 12:59 AM
fuzzy's Avatar
X3, but I'm not sure on the 68 yet. Definatly worth a phone call to find out. I think suncoast has one, but I'm not sure it's built much better than stock.
fuzzy is offline
post #9 of 18 (permalink) Old 03-18-2009, 02:43 PM Thread Starter
I went down south last weekend and it was fine all the way down but on the way up it had a hard time goin past eighty five then it just stuck it fourth so i had to pull over and shut it off and restart it and it was fine after that. Its almost like it goes into limp home mode. But no engine light. The guys ive talked to here say the tranny is goin.
07 6.7
6 Inch lift
XRT WOOO
Ts-mp8
S&B Intake
egr all gone
2 10 inch mtx subs
Tint
Boost Fooler
post #10 of 18 (permalink) Old 03-19-2009, 12:26 AM
fuzzy's Avatar
That ain't good. Stuck in forth is a limp mode for the tranny I believe. Do you have a temp gauge, and what was it if you do? I know of one other guy that had the same issues just as your describing, and he needed a new tranny. He had 158,000 miles though, and pulled hard on everyone of them.
fuzzy is offline
tranny rebuild kits! need help asap tranny is shot...f'in dodge auto trans blksmk 5.9L Cummins 12 Valve (1994-1998.5) 5 12-26-2008 10:55 PM
auto tranny s.e Diesel Conversion 4 11-03-2007 12:53 AM
Need Auto Tranny 98-02 OFFRODEN 5.9L Cummins (1998.5-2002) 5 10-11-2006 11:08 PM
Auto tranny in a 95. FarmboyAC 5.9L Cummins 12 Valve (1994-1998.5) 2 12-14-2005 04:34 PM
03' Auto Tranny 2wd wideopen 5.9L Cummins (2003-2007.5) 4 10-27-2005 12:27 AM
