Suggestions please - Diesel Truck Forum - TheDieselGarage.com
Thread Details Posted by 08White, this thread has received 4 replies and been viewed 1392 times.
post #1 of 5 (permalink) Old 03-12-2009, 12:44 AM Thread Starter
First Diesel
Suggestions please
I am new here and would like you guys, advise. I have a 08 with 6500 miles on it. I want some sound out of it? I have heard that you can cut the cats off and muffler, and run straight pipe all the way back. I have heard these and they sound ok Im confused on what I have to do with a 6.7. What do i need for exhaust? deletes? programmer? I need all the help i can get
Thanks in advance
08White is offline
post #2 of 5 (permalink) Old 03-12-2009, 02:16 AM
fuzzy's Avatar
http://www.badpracing.com/
http://www.hs-performance.com/default.aspx
http://www.dpf-r.com/productindex.php
Check those links out, and do lot's of searching and reading. So many ways to do it anymore it would take forever to post it all. The links are just a few companies that make kits.
fuzzy is offline
post #3 of 5 (permalink) Old 03-12-2009, 02:44 AM Thread Starter
First Diesel
ok i will check them out... thanks for posting anyone else?
08White is offline
post #4 of 5 (permalink) Old 03-17-2009, 02:46 AM
All of the Deletes (EGR/COOLER/DPF) can be done in a couple of hours with some basic tools, for less than $100. If all you do is get rid of the DPF and EGR, you will get a great sound, engine will breathe better, and you absolutely will notice a difference. (a 5' piece of 4" pipe, and some plates for the egr is all you need). I can include pictures if you would like.
hornet67 is offline
post #5 of 5 (permalink) Old 03-17-2009, 03:08 AM
fuzzy's Avatar
No resistors for fooling the computer??? Your gonna run into problems sooner, rather than later. It can still be done for cheap I agree, but you need to use some resistors between the egt wires. Not to mention the cel is always on, and the overhead says see dealer. Not calling you out hornet, but if yours is working with just a piece of pipe, well you got one special truck.
fuzzy is offline
Any Suggestions..... Gator-Bait 2003-2007 6.0L Power Stroke 6 03-20-2008 05:00 AM
Looking for suggestions on N14 KN4SX Medium and Heavy Duty 8 12-17-2007 02:12 PM
Looking for Suggestions jp39bfd 5.9L Cummins (1998.5-2002) 7 10-17-2006 11:17 AM
Mod suggestions Tornsteel 1994-2003 7.3L Power Stroke 3 04-18-2006 02:42 PM
Mod suggestions! cmkworm 2003-2007 6.0L Power Stroke 14 04-13-2006 04:55 PM
