fuel pressure problem? - Diesel Truck Forum - TheDieselGarage.com
Thread Details Posted by BigRed6.7CTD, this thread has received 19 replies and been viewed 1652 times.
post #1 of 20 (permalink) Old 03-18-2009, 01:46 AM Thread Starter
Ok, the other day I had the edge on 3 and the mp all the way up and I got on it hard in sixth and a warning to take my truck to the dealer for service came up and a mil code of low fuel rail pressure came up so what gives, I cleared the code and it hasn't come back up yet but I am wondering if I need to work on something, any help would be appreciated...
2007.5 Ram 3500 4x2 QC
6 speed manual
Edge Attitude with/ Juice
MP-8
S&B Cold Air Intake
4" TBE Flo-Pro
DPF delete
Egr and Egr Cooler delete
Black Tec Mafia #19
BigRed6.7CTD is offline
post #2 of 20 (permalink) Old 03-18-2009, 02:13 AM
fuzzy's Avatar
Start with the fuel filter maybe.
fuzzy is offline
post #3 of 20 (permalink) Old 03-18-2009, 02:17 AM
fuzzy's Avatar
Whoops didn't see the word "rail" in your post. I thought you said just low fuel pressure. Now I'm not sure. CP3 maybe??
fuzzy is offline
post #4 of 20 (permalink) Old 03-18-2009, 02:50 AM Thread Starter
could i have dead headed the rail under heavy load and it might need more fuel than it can give?
6 speed manual
MP-8
S&B Cold Air Intake
4" TBE Flo-Pro
DPF delete
Black Tec Mafia #19
post #5 of 20 (permalink) Old 03-18-2009, 03:36 AM
fuzzy's Avatar
Maybe. Just a question here, did you shim the relief plug when installing the mp-8? I'm not really sure what, or how it effects things, but have read some trucks don't like it if you don't. Or maybe something is leaking. I'm really just guessing here, but trying to help.
fuzzy is offline
post #6 of 20 (permalink) Old 03-18-2009, 04:03 AM
ADMIN/MAFIA
neeltburn's Avatar
sounds like your drained the rail..can you test things out by setting to stock and dogging on it see if it holds. the slowly work up with both chips to see what the truck likes? Others have ran this setup with good results so maybe fuzzy is on to something with the shim seems like they may be a starting place. just a thought. you could also install a rail press guage, I know a few vendors have them. let us know what you find out.
6.7L 68RFE 4wd
Yeah its stock.
Pac Brake Air Bags
On Board Air
Optima Redtop 34Rs
2010 John Deere 2305
9-11-2001 NEVER FORGET
neeltburn is offline
post #7 of 20 (permalink) Old 03-18-2009, 02:45 PM
BigBlueDodge's Avatar
Mine did this when i put the valve together wrong. The pin fell out of it.
07 6.7
6 Inch lift
37-13.50 Nitto Mud Grapplers
XRT WOOO
Ts-mp8
S&B Intake
5 inch to 7 inch mitter cut stacks
egr all gone
2 10 inch mtx subs
Tint
Boost Fooler
Black Head and Tail lights
BigBlueDodge is offline
post #8 of 20 (permalink) Old 03-19-2009, 02:59 AM Thread Starter
Nothing new was found on the truck to be missing or having problems but talked to a couple of local guys and they confirmed my thought about draining the rail and it won't change with the level I have the mp8 on meaning it will cause it to happen on a 0 setting because of the rail plug, the stock pump can't keep up with the rail now at wide open throttle. so I guess i need to be easy on her until i drop the coin into a better fuel system...
6 speed manual
MP-8
S&B Cold Air Intake
4" TBE Flo-Pro
DPF delete
Black Tec Mafia #19
post #9 of 20 (permalink) Old 03-19-2009, 03:23 AM Thread Starter
is there anyone else that is or has had the same problem and how did they fix it???
6 speed manual
MP-8
S&B Cold Air Intake
4" TBE Flo-Pro
DPF delete
Black Tec Mafia #19
post #10 of 20 (permalink) Old 03-25-2009, 07:47 PM
Running the rail dry,get an airdog150 or fass and that problem should go away.
throwing coal is offline
The Following User Says Thank You to throwing coal For this addition to TDG:
BigRed6.7CTD (03-28-2009)
Fuel pressure & overflow valve pressure Deeslfxr 5.9L Cummins (1998.5-2002) 4 01-09-2009 11:35 PM
oil pressure/wastegate problem biscuit_ford 1994-2003 7.3L Power Stroke 10 11-29-2007 05:23 PM
Setting fuel pressure regulator w/out a fuel pressure gauge hhrecovery 2003-2007 6.0L Power Stroke 17 04-02-2007 02:25 PM
Fuel Pressure Problem? Lift problem? Going on long trip this weekend! JaredMTFD 5.9L Cummins (1998.5-2002) 4 01-24-2007 03:35 PM
Autometer Fuel Pressure gauge problem FireMarshal3311 5.9L Cummins (1998.5-2002) 1 01-22-2007 02:06 AM
