blue smoke - Diesel Truck Forum - TheDieselGarage.com
Thread Details Posted by elctricbluecummins, this thread has received 10 replies and been viewed 6197 times.
post #1 of 11 (permalink) Old 03-24-2009, 10:02 PM Thread Starter
blue smoke
sometimes when im not getting on it too hard my truck lags a little bit and it will blow a little puff of blue smoke does anyone elses do this
elctricbluecummins is offline
post #2 of 11 (permalink) Old 03-25-2009, 01:27 AM
fuzzy's Avatar
Usually a lighter colored smoke is a regen, but most would call it white. But I guess if your going into regen, something is wrong with your delete kit. Maybe set your edge to alert you of a regen, and you can see if that's it.
Could be because the egr is still on also. Dpf delete with a functional egr will smoke a little more, but usually just a little haze of black, which I guess could be confused as a blue. Maybe?????
fuzzy is offline
post #3 of 11 (permalink) Old 03-25-2009, 01:21 PM
Built Not Bought
SOOTBANDIT's Avatar
Images: 9
Like fuzzy said if all you did is unplug and install the plates the egr then it will puff a little blue/white smoke untill you drive a little ways. I know people hate to look at the cel nut put your edge to not clear codes on startup and it should take care of the problem.
Military Quote Of The Year
SOOTBANDIT is offline
post #4 of 11 (permalink) Old 03-25-2009, 09:46 PM
Kummins's Avatar
If you are in the higher setting on your Edge then what's happening is the truck is fueling hard when you step on it and causing the turbo to lag a bit and the puff of blue smoke. Mine 5.9L does this bad on Crazy Larry. I have to roll into the trottle from low RPM's.
06 2500 Quadcab SLT
Billet Tranny
BD with Crazy Larry
Quadzilla Boost Fooler
S&B Intake
MBRP all the way back and "High Flow Cat"
6" Lift, 35" Toyo MT's, 20" Incubus wheels
Some Audio Goodies Too
MAY 2008 TDG Truck of the Month
Kummins is offline
post #5 of 11 (permalink) Old 03-27-2009, 04:22 PM Thread Starter
im getting the egr delete done on monday so we'll see if that's it....I only run my edge on 3 at the highest because it slips my clutch so bad so I don't guess that's it but thanks everyone for your input ill tell yall what happens when I do the egr delete
post #6 of 11 (permalink) Old 03-28-2009, 12:26 AM
I have the same problem with smoke and mine is going into a regen by what the edge tells me, does that mean that my deletes are not working? my egr is gone but i didn't remove the butterfly's could that be causing it?
2007.5 Ram 3500 4x2 QC
6 speed manual
Edge Attitude with/ Juice
MP-8
S&B Cold Air Intake
4" TBE Flo-Pro
DPF delete
Egr and Egr Cooler delete
Black Tec Mafia #19
BigRed6.7CTD is offline
post #7 of 11 (permalink) Old 03-28-2009, 01:14 AM
fuzzy's Avatar
What kind of dpf delete do you have? Check your sims, maybe pull them out and clean them, (blow them out), put some electric grease on them and reinstall. I don't know what your running, but newer flashes have a regen counter or timer in them. If your truck don't see a regen in so many miles, or over some time period, it will go into regen. The newer delete kits have a regen timer reset in them to put that back to 0 everytime you start the truck. So if you have a newer flash, without the right electronics, it could be the problem. If none of those apply, then check your sims.
fuzzy is offline
The Following User Says Thank You to fuzzy For this addition to TDG:
BigRed6.7CTD (03-28-2009)
post #8 of 11 (permalink) Old 03-28-2009, 11:19 AM
ok so it may end up being a problem that I have to deal with right?, I will chech the sensors this weekend and let ya'll know.
6 speed manual
MP-8
S&B Cold Air Intake
4" TBE Flo-Pro
DPF delete
Black Tec Mafia #19
post #9 of 11 (permalink) Old 03-29-2009, 04:13 AM Thread Starter
I set my edge to alert me when it went into regen and it did last night it blew a ton of white smoke but then I drove it today and it was fine....so is my delete kit messed up or what
post #10 of 11 (permalink) Old 03-29-2009, 08:51 PM
fuzzy's Avatar
I'd say the same to you as I did to bigred6.7ctd. Check your sims, but it could be your flash and the kit your running. Does it seem like it's doing it every so many miles, or over a certain amount of drive time? Or is it out of the blue whenever it wants?
fuzzy is offline
White smoke blue smoke low on coolant whats wrong littlebigrig6.0 2003-2007 6.0L Power Stroke 24 12-05-2009 11:11 PM
blue smoke? imported_ditchdigger 2003-2007 6.0L Power Stroke 4 04-07-2008 01:43 AM
Got Blue Smoke *2GLAMIS* 2003-2007 6.0L Power Stroke 2 04-01-2008 01:20 AM
Blue smoke 94straightpiped 5.9L Cummins 12 Valve (1994-1998.5) 16 01-25-2008 02:40 AM
