Cel - Diesel Truck Forum - TheDieselGarage.com
Thread Details Posted by C.S.Langanservices, this thread has received 3 replies and been viewed 523 times.
post #1 of 4 (permalink) Old 03-28-2009, 03:57 AM Thread Starter
Cel
can i use a SCT that i have left over from me last truck to pull codes off my new dodge?
C.S.Langanservices is offline
post #2 of 4 (permalink) Old 03-28-2009, 04:15 AM
ADMIN/MAFIA
neeltburn's Avatar
You dont need anything to pull codes...sit in the truck with the door closed and cycle the key 3 times w/o starting the truck..on the third time leave it in the run position. the codes (if there are any) will pop up in your odometer window..when it is complete it will say **done**...there is a code list with a sticky at the top of the 6.7 page.. I don't believe that the SCT will work but Im not 100% sure...hope this helps..
6.7L 68RFE 4wd
Yeah its stock.
Pac Brake Air Bags
On Board Air
Optima Redtop 34Rs
2010 John Deere 2305
9-11-2001 NEVER FORGET
neeltburn is offline
post #3 of 4 (permalink) Old 03-28-2009, 11:22 AM
depends on what sct and what it was made to work on, it could but it all depends on what you have, if it is a cortex or flashpaq it should.
2007.5 Ram 3500 4x2 QC
6 speed manual
Edge Attitude with/ Juice
MP-8
S&B Cold Air Intake
4" TBE Flo-Pro
DPF delete
Egr and Egr Cooler delete
Black Tec Mafia #19
BigRed6.7CTD is offline
post #4 of 4 (permalink) Old 03-28-2009, 05:27 PM Thread Starter
thanks
