egt to high - Diesel Truck Forum - TheDieselGarage.com
Thread Details Posted by SOOTBANDIT, this thread has received 13 replies and been viewed 1769 times.
post #1 of 14 (permalink) Old 03-30-2009, 10:29 PM Thread Starter
Built Not Bought
SOOTBANDIT's Avatar
Images: 9
egt to high
Ok so i was messing around with my truck the other night and decided that it was time to finally put my egt probe in the manifold and since i have been to lazy lol. So on level 6 and rowing through all the gears when i get to bout 70-80mph my alert for egt goes through the roof what gives i mean i hit 1500 easy and just let out of it. So what does everyone else run at wot on these 6.7? If im going to run down the track i dont want to have to feather it. I am putting an airdog 100 and hoping to have a water meth for it soon to for it so that should help a little but what else can i do to help keep this cool??? Thanks Pete
Military Quote Of The Year
SOOTBANDIT is offline
post #2 of 14 (permalink) Old 03-30-2009, 10:38 PM
fuzzy's Avatar
Can't help you much, because mine is post turbo. I've never seen over 900 post turbo, which I'm guessing might be 1200-1300 pre turbo. Are you sure your probe isn't actually touching the manifold?
fuzzy is offline
post #3 of 14 (permalink) Old 03-30-2009, 10:47 PM Thread Starter
Built Not Bought
SOOTBANDIT's Avatar
Images: 9
ya cause i drilled it out and tapped it and stuck it in and pulled it back a little ways to try to insure that it was not touching. I mean cruising around at 70 it runs about 800-900 its just when i hold it wide open in 6th gear bout 2800 rpm
post #4 of 14 (permalink) Old 03-30-2009, 11:19 PM
fuzzy's Avatar
Yeah well, I think they are probably about right. These things still run hotter than the 5.9's, esspecially at wot. Even with the deletes, when you pin it hard, the egts will shoot right up there. Just remember they are supposedly made to handle it, but I wouldn't stay at 1500 to long.
fuzzy is offline
The Following User Says Thank You to fuzzy For this addition to TDG:
SOOTBANDIT (03-31-2009)
post #5 of 14 (permalink) Old 03-31-2009, 06:08 PM
BigBlueDodge's Avatar
Mine is just like that even has got up to 1600 once.
07 6.7
6 Inch lift
37-13.50 Nitto Mud Grapplers
XRT WOOO
Ts-mp8
S&B Intake
5 inch to 7 inch mitter cut stacks
egr all gone
2 10 inch mtx subs
Tint
Boost Fooler
Black Head and Tail lights
BigBlueDodge is offline
The Following User Says Thank You to BigBlueDodge For this addition to TDG:
post #6 of 14 (permalink) Old 03-31-2009, 08:17 PM
Let it all Ride
Eazydeezy's Avatar
Dude, when I had mine in level 5 with out running propane, from a dig and up to 100 my egt's would go around 1550, and that was on level 5. I set my alarm to go off at 1600 after that and never heard it again. Edge sets there default alarms pretty low.
Dominic
Eazydeezy is offline
The Following User Says Thank You to Eazydeezy For this addition to TDG:
post #7 of 14 (permalink) Old 04-01-2009, 03:59 AM
ADMIN/MAFIA
neeltburn's Avatar
mine hits 1050 (i guess with regen) but I still have the dpf and egr..my probe is post turbo...
6.7L 68RFE 4wd
Yeah its stock.
Pac Brake Air Bags
On Board Air
Optima Redtop 34Rs
2010 John Deere 2305
9-11-2001 NEVER FORGET
neeltburn is offline
SOOTBANDIT (04-01-2009)
post #8 of 14 (permalink) Old 04-02-2009, 01:31 AM
Strokethis6.7's Avatar
ive had y egts around 1700 but i would rather blow my **** up before i loose to a duramax!!
Strokethis6.7 is offline
post #9 of 14 (permalink) Old 04-02-2009, 01:38 AM
H2o/meth works great and so does propane I actualy run a cryo unit on mine
The Following User Says Thank You to Strokethis6.7 For this addition to TDG:
SOOTBANDIT (04-02-2009)
post #10 of 14 (permalink) Old 04-02-2009, 02:24 PM
Let it all Ride
Eazydeezy's Avatar
HAHAHA! That's awesome!!!! Couldn't agree more!
Dominic
High Idle & High Idle Kicker... Mopar1973Man 5.9L Cummins (1998.5-2002) 4 12-25-2008 01:36 PM
High idle & 3 cyl triker888 5.9L Cummins (1998.5-2002) 9 03-10-2008 08:42 PM
rpm not going high enough exoticsrnw 5.9L Cummins 12 Valve (1994-1998.5) 3 03-07-2008 05:41 PM
High 7.3 hp dlopp Dyno Board 6 03-06-2008 10:59 PM
High egt help iwannagofast 5.9L Cummins (1998.5-2002) 12 11-24-2007 05:38 AM
