P2262 & B1790 CELs - Diesel Truck Forum - TheDieselGarage.com
Thread Details Posted by 4rcFed, this thread has received 19 replies and been viewed 3601 times.
post #1 of 20 (permalink) Old 04-13-2009, 06:44 PM Thread Starter
Super Moderator
4rcFed's Avatar
Images: 12
Thumbs down P2262 & B1790 CELs
Well, I had a check engine light a few weeks ago come on during the weekend, but went off before Monday (before I could get it to the dealer).
But it is back....and it starts!
Took it in today and it has a P2262 and B1790. So we'll see what happens from here!
(should I have sold that '97 PSD of mine?!?!?!!!!)
2008 Dodge 2500 Mega Ram, SLT, Powered by a little 'ol 408 cubic inch six cylinder!!!
Chrysler's warranty = Not worth the paper it is printed on!!!
Gone, but not forgotten!!!
1997 FORD F-250 HD
7.3L, XLT, Off-Road Package
3.55's, E4OD, 4wd, Dana 60 swap, 3" Sky RSK, 315/70/17's on Racelines.
4rcFed is offline
post #2 of 20 (permalink) Old 04-14-2009, 01:19 AM
fuzzy's Avatar
How many miles? The 2262 is the turbo. Could be soot, but if you don't have many miles, it's more than likely just needs flashed. Never heard of the other one, doesn't the B stand for body? Did they tell you what it was?
fuzzy is offline
post #3 of 20 (permalink) Old 04-14-2009, 01:27 AM
Built Not Bought
SOOTBANDIT's Avatar
Images: 9
B1790 Autolamp Sensor Input Circuit Failure thats what i found for it
Military Quote Of The Year
SOOTBANDIT is offline
post #4 of 20 (permalink) Old 04-14-2009, 01:28 AM
Built Not Bought
SOOTBANDIT's Avatar
Images: 9
When my truck threw the p2262 3 times i got a new turbo free of charge then came the deletes lol
post #5 of 20 (permalink) Old 04-14-2009, 01:35 AM
fuzzy's Avatar
Thanks. I guess B don't stand for body then.
I knew it wasn't a performance code though.
fuzzy is offline
post #6 of 20 (permalink) Old 04-14-2009, 01:37 AM
Built Not Bought
SOOTBANDIT's Avatar
Images: 9
No you were right i think i looked on the edge site and it said B was body but that sure is not a body code unless they tie it into it??? I found the code on google
post #7 of 20 (permalink) Old 04-14-2009, 01:46 AM Thread Starter
Super Moderator
4rcFed's Avatar
Images: 12
Originally Posted by fuzzy View Post
How many miles? ...........
Under 3,000!
I read alot about folks being told to use the EB more to avoid the issue. But something doesn't sit right with me that you have to do such a thing. It 'may' work, but doesn't sound right! The truck should operate fine without 'having' to do so.
Plus I'd like to see the full guts of the turbo and exhaust brake set-up to first grasp what is more beneficial. Using the exhaist brake must still put other components in a more wear situation too?!?! So which is "right?"
Working within the automotive industry, I just do too much working/discussing with various groups/designers, and components need to work good. If they don't, then resolve the issue. Driving with the EB on, or adding a drain plug is merely temporary. I want a long term fix.
B1790 was something like Trailer Tow Lamp Circuit Overcuurent.
1997 FORD F-250 HD
4rcFed is offline
post #8 of 20 (permalink) Old 04-14-2009, 01:50 AM
Built Not Bought
SOOTBANDIT's Avatar
Images: 9
I stand corrected i just looked at that site again they say they are GM codes my bad
post #9 of 20 (permalink) Old 04-14-2009, 03:09 AM
fuzzy's Avatar
Originally Posted by 4rcFed View Post
Under 3,000!
Since my truck was new, it's the second thing I do. First is start, second is turn on the exhaust brake on. Still do it, even deleted. If this makes sence, I'll try to explain it, but I'm not up on all the turbo talk.
The turbo has vains that slide. With all the soot that's being pushed back through the motor, those sliding vains want to get a build up of soot, and thus get stuck. So somehow using the exaust brake works those slides more, thus knocking the soot off before it gets all crusted on there. Now I agree it's kind of a joke, but running the brake doesn't hurt a thing. And if my turbo talk or wording is wrong, someone correct me, but that's basically what's happening in there. What they will probably do is clean the turbo, and give you the latest flash, which is helping. Awhile back flashes were just a joke, but I've read the newest ones are getting it better.
fuzzy is offline
post #10 of 20 (permalink) Old 04-14-2009, 03:44 AM
ADMIN/MAFIA
neeltburn's Avatar
Fuzzy you pretty much put it the same way I took it. with the exhaust brake on it forces the fins or veins on the VGT open and closed thus keeping them I believe open longer to let the soot out. I run mine all the time and another thing that can help from running it all the time is the extended life of the service brakes on our trucks. If I ever get another diesel down the road I will be putting an exhaust brake on it for sure.
6.7L 68RFE 4wd
Yeah its stock.
Pac Brake Air Bags
On Board Air
Optima Redtop 34Rs
2010 John Deere 2305
9-11-2001 NEVER FORGET
neeltburn is offline
