Oil Change Light - Diesel Truck Forum - TheDieselGarage.com
Thread Details Posted by goatman1419, this thread has received 9 replies and been viewed 2172 times.
post #1 of 10 (permalink) Old 04-23-2009, 06:17 PM Thread Starter
Oil Change Light
Got a question does our oil change light come on because the oil is bad or is it on some kind of time interval. I know its not a mileage issue so I was just wondering do I change it cause its worn out our just press the gas pedal to the floor three times and go on my own schedule. Thanks guys
goatman1419 is offline
post #2 of 10 (permalink) Old 04-23-2009, 06:22 PM
BigBlueDodge's Avatar
Time interval is all. Nothing is wrong.
07 6.7
6 Inch lift
37-13.50 Nitto Mud Grapplers
XRT WOOO
Ts-mp8
S&B Intake
5 inch to 7 inch mitter cut stacks
egr all gone
2 10 inch mtx subs
Tint
Boost Fooler
Black Head and Tail lights
BigBlueDodge is offline
post #3 of 10 (permalink) Old 04-24-2009, 02:05 AM
Dodgefarmer's Avatar
It is based on time, mileage and and how hard it is driven. If you are towing heavy and working it hard it will sense it and shorten the oil change interval.
singles club # 198
Dodgefarmer is offline
post #4 of 10 (permalink) Old 04-24-2009, 05:00 AM
Kummins's Avatar
You can get an oil integrity test kit from Amsoil if you're intersted in knowing what your oil is really doing.
06 2500 Quadcab SLT
Billet Tranny
BD with Crazy Larry
Quadzilla Boost Fooler
S&B Intake
MBRP all the way back and "High Flow Cat"
6" Lift, 35" Toyo MT's, 20" Incubus wheels
Some Audio Goodies Too
MAY 2008 TDG Truck of the Month
Kummins is offline
post #5 of 10 (permalink) Old 04-26-2009, 05:19 AM
stillcrazyinlaw's Avatar
Images: 3
I'm not fully convinced that it is based on time. I recently changed my oil and the oil change thingy came on only 8 days later.The truck regened and the oil level went up as usual and I think that was it.
stillcrazyinlaw is offline
post #6 of 10 (permalink) Old 04-27-2009, 01:30 AM
ADMIN/MAFIA
neeltburn's Avatar
I thought it was based on viscosity and condition of the oil?
6.7L 68RFE 4wd
Yeah its stock.
Pac Brake Air Bags
On Board Air
Optima Redtop 34Rs
2010 John Deere 2305
9-11-2001 NEVER FORGET
neeltburn is offline
post #7 of 10 (permalink) Old 04-27-2009, 01:39 AM
Gone Fishin...
merlin5577's Avatar
+1, the computer takes a number of variables into account and then decides when to trigger the light. Time, Mileage, driving conditions, temperature, etc... all come into play.
-Robert.
My Fleet;
1997 GMC Suburban SLT 5.7L 4A
Reading material
I am an old Fart;
Toot-Toot
merlin5577 is offline
post #8 of 10 (permalink) Old 04-27-2009, 02:12 AM
Yea your right. All those variables all are factored in into how hard the oil is working (abused?) with other conditions all impacting how hard the oil having to work to protect the engine which translate to how much "life" is left in the oil.
I get my oil changed every 6000 miles because that is when my dealer does it for free for as long as I own the truck. At 6000 miles on the oil, I have yet to see the change oil warning come on. One time I went about 6500 miles and then the change oil light came on
singles club # 198
post #9 of 10 (permalink) Old 05-06-2009, 04:00 AM
How do you reset the oil light?
heavyhaller is offline
post #10 of 10 (permalink) Old 05-06-2009, 04:44 AM
Turn ignition on without starting. Then press throttle to floor slowly 3 times with in 10 seconds. Tat will turn off the oil change light.
singles club # 198
heavyhaller (05-07-2009)
tow haul light flashing trans temp pegging andcheck guage light comes on powermad 2003-2007 6.0L Power Stroke 12 05-16-2010 11:34 PM
Oil change required light Brutus the Grey 6.7L Cummins (2007.5-2011) 8 08-21-2007 04:12 AM
Door Ajar light wont go off nor will the dome light?? imported_99powerstroke 1994-2003 7.3L Power Stroke 10 03-14-2007 04:13 AM
Oil change/check engin light on Farmboy162005 2003-2007 6.0L Power Stroke 1 03-13-2007 03:41 PM
first oil change and fuel filter change? chvylac 2003-2007 6.0L Power Stroke 10 12-03-2006 08:26 AM
