Isspro Fuel Rail Pressure Gauge mounted - Diesel Truck Forum - TheDieselGarage.com
Thread Details Posted by 4rcFed, this thread has received 2 replies and been viewed 2793 times.
post #1 of 3 (permalink) Old 04-29-2009, 01:24 AM Thread Starter
Super Moderator
4rcFed's Avatar
Images: 12
Forgot to post up a few pics already...
Anyway, from curiosity of fuel rail pressures the 6.7s see, I mounted up an Isspro fuel rail pressure gauge. With wanting to keep the grab handle on the a-pillar, I opted for the SRT-10 a-pillar single gauge mount.
Here are a few pictures of it mounted:
2008 Dodge 2500 Mega Ram, SLT, Powered by a little 'ol 408 cubic inch six cylinder!!!
Chrysler's warranty = Not worth the paper it is printed on!!!
Gone, but not forgotten!!!
1997 FORD F-250 HD
7.3L, XLT, Off-Road Package
3.55's, E4OD, 4wd, Dana 60 swap, 3" Sky RSK, 315/70/17's on Racelines.
4rcFed is offline
post #2 of 3 (permalink) Old 04-29-2009, 03:38 AM
ADMIN/MAFIA
neeltburn's Avatar
How was the install process? Ill have to do a column pod but that doesn't seem to hard just wondering about the under the hood part?
6.7L 68RFE 4wd
Yeah its stock.
Pac Brake Air Bags
On Board Air
Optima Redtop 34Rs
2010 John Deere 2305
9-11-2001 NEVER FORGET
neeltburn is offline
post #3 of 3 (permalink) Old 04-29-2009, 04:33 PM Thread Starter
Super Moderator
4rcFed's Avatar
Images: 12
The install wasn't too bad, just depends on how neat you want it. I try to make mine look as factory as possible. The interior took longer for me, as I did the following:
INTERIOR
1. Removed the two bolts from the a-pillar garnish to remove it,
2. Transferred the sound deadening material to the new a-pillar garnish,
3. Transferred the bolt covers to the new a-pillar,
4. Routed the wiring behind the dash to the floor,
5. Removed the 'oval shaped' (plastic) firewall plug that is bolted to the firewall,
6. Drilled a small hole in that plastic cover,
7. Attached a ground to the dash reinforcement,
8. Robbed a 12V key-on power source from an unused wire harness plug underneath the dash,
9. And then tapped into the dimmer circuit to make the gauge light dim.
UNDER THE HOOD
1. Unplugged the factory rail sensor,
2. Inserted the Isspro pigtail,
3. Plugged one end into the sensor, and the other in the factory harness,
4. Carefully routed the gauge wiring towards the plastic plug plate,
5. Routed the wiring through the plug plate I previously drilled a hole in,
6. Routed that wiring up to the gauge and made the connections,
7. Secured any loose wiring,
8. Added a dab of silicone around the wires that ran through the plug plate (both sides).
Re-attached the a-pillar garnish inside the truck.
That is a rough run-down of what I did. If you have any questions, feel free to ask!
1997 FORD F-250 HD
4rcFed is offline
The Following 2 Users Say Thank You to 4rcFed For this addition to TDG:
neeltburn (04-30-2009), SOOTBANDIT (04-29-2009)
isspro rail pressure smokeyourdiesel Supporting Vendors Forum 4 04-23-2008 10:09 PM
Fuel Pressure Gauge & IssPro Pyro Circuit Box Cowboy Whats Been Sold 4 03-21-2008 10:15 PM
ISSPRO fuel pressure gauge jaguar 6.7L Cummins (2007.5-2011) 0 10-24-2007 11:42 PM
ISSPRO Fuel Gauge vj_m 5.9L Cummins (1998.5-2002) 12 07-13-2006 10:59 PM
Will a 6.0 run w/o the frame rail mounted fuel filter? imported_Arkapigdiesel 2003-2007 6.0L Power Stroke 14 04-01-2006 03:16 PM
