Rough Idle when cold - Diesel Truck Forum - TheDieselGarage.com
Thread Details Posted by fjo, this thread has received 10 replies and been viewed 3702 times.
post #1 of 11 (permalink) Old 05-26-2009, 06:40 PM Thread Starter
fjo
My truck just started idling rough when I first start it in the mornings. But after about 5 or 10 minutes, it is fine. I drive about 40 minutes to work then let it sit all day and when I get in it to go back home, it idles fine. It is just in the mornings that this is happening. Could it be fuel? My last two fill ups have been at a different station.
fjo is offline
post #2 of 11 (permalink) Old 05-26-2009, 07:53 PM
Kummins's Avatar
Is your intake heater still working?
06 2500 Quadcab SLT
Billet Tranny
BD with Crazy Larry
Quadzilla Boost Fooler
S&B Intake
MBRP all the way back and "High Flow Cat"
6" Lift, 35" Toyo MT's, 20" Incubus wheels
Some Audio Goodies Too
MAY 2008 TDG Truck of the Month
Kummins is offline
post #3 of 11 (permalink) Old 05-26-2009, 10:12 PM
terb is offline
post #4 of 11 (permalink) Old 05-27-2009, 08:12 PM
My 05 5.9 would do that when the air filter started getting dirty. I would change the filter and it would idle perfect when I cranked it up cold.
Dirty "OLE" Man
01, 2500, 4X4, CTD. All stock for now.
91, Jeep YJ, 408"SBC, 205TC, Dana60's,4:88's, 39"Pitbull Maddog's on Raceline Beadlocks.
http://i107.photobucket.com/albums/m...k/100_0837.jpg
http://i107.photobucket.com/albums/m...n/100_0840.jpg
Dirty "OLE" Man is offline
post #5 of 11 (permalink) Old 05-28-2009, 06:27 PM Thread Starter
fjo
Do you mean the jake brake? I have a 07.5 with the 6.7 .
fjo is offline
post #6 of 11 (permalink) Old 05-28-2009, 07:04 PM
Kummins's Avatar
No I mean the intake heater grid that is in the intake manifold. They help heat the air when the truck is cold and help it idle a little smoother until you get a little heat in the engine. You should here it making an electric arcing sound underneath the hood before it starts. Don't you have the little coil on your gauge panel where you turn the key to the ON position and wait for it to go off before starting?
Help me out here 6.7 guys don't you have this like the 5.9's do?
06 2500 Quadcab SLT
Billet Tranny
BD with Crazy Larry
S&B Intake
Kummins is offline
post #7 of 11 (permalink) Old 05-28-2009, 09:05 PM Thread Starter
fjo
Yes, the glow plug light. I make sure that light goes off before I start the truck and the truck starts right away, within a second or two of when I turn the key to start. It just seems to run a little rough for 5 minutes or so after that. It was just a coincidence that it seem to start doing that after the second fill up from a certain gas station.
Thanks for any ideas or solutions.
fjo is offline
post #8 of 11 (permalink) Old 05-28-2009, 09:37 PM
Kummins's Avatar
Well call what you like but these motors don't have glow plugs, just an intake heater. Can you here it actually working when your key is in the on position?
06 2500 Quadcab SLT
Billet Tranny
BD with Crazy Larry
S&B Intake
Kummins is offline
post #9 of 11 (permalink) Old 06-01-2009, 04:16 PM Thread Starter
fjo
Yes, it seems to working fine. What I did do this weekend, was reprime it, so to speak. In other words, touch the starter without starting it and then let the key go back to the run position to allow the fuel pump to cycle for 20 or 30 seconds. Just like when you change the fuel filter. For right now, that has seemed to work. I had changed the fuel filter not to long ago, but it is possible that I didn't prime enough. Well see.
Thanks for all of the suggestions.
fjo is offline
post #10 of 11 (permalink) Old 06-01-2009, 04:17 PM
Built Not Bought
SOOTBANDIT's Avatar
Images: 9
Is this truck stock?
Military Quote Of The Year
SOOTBANDIT is offline
For those with Factory Pilot Injection trying to diagnose rough idle/cold start PSDPlayer 2003-2007 6.0L Power Stroke 1 01-14-2010 08:40 PM
another weird idle ?, rough idle oh3_6oh 2003-2007 6.0L Power Stroke 3 01-09-2008 04:48 AM
cold start, rough idle fix billymac61 2003-2007 6.0L Power Stroke 8 11-23-2007 04:42 PM
Rough idle and smokes during cold start ups. bigbore 2003-2007 6.0L Power Stroke 8 08-03-2006 02:45 AM
03 6.0 very rough cold idle What gives? bgtony1 2003-2007 6.0L Power Stroke 17 02-20-2006 12:31 AM
