Smarty DPF Delete? - Diesel Truck Forum - TheDieselGarage.com
Thread Details Posted by Rich, this thread has received 3 replies and been viewed 1511 times.
post #1 of 4 (permalink) Old 05-27-2009, 12:49 AM Thread Starter
Rich's Avatar
Smarty DPF Delete?
If you have a Smarty, what deletes are nessary? Do you still need to plug the EGR or remove the dampner in the elbow?
If you make your own DPF () is it nessary to just bore hole and make bungs so that the sensors 'see' something or do you still need to stick something in the sensors, OHM resistors?
Rich is offline
post #2 of 4 (permalink) Old 05-27-2009, 01:17 AM
Strokethis6.7's Avatar
Strokethis6.7 is offline
post #3 of 4 (permalink) Old 05-27-2009, 02:53 AM
CRAZY CANUCK
BriteWhiteRam's Avatar
as far as i know the Smarty6.7 is designed to work WITH the dpf, mads spent a lot of time making it work as painlessly as possible... thats only in the USA, if you were from canada, you could get the version that allows you to disable the dpf
Aaron the Crazy Canuck
Canadian Club Member #1
Singles Club member #186
Ridin Dirty Club #5
TDG TOTQ
BriteWhiteRam is offline
post #4 of 4 (permalink) Old 05-27-2009, 03:17 AM Thread Starter
Rich's Avatar
I see said the ME softwear. Yes, that is what I am refering to.
Where is Bob?
Rich is offline
Smarty?? bannon_500 5.9L Cummins (1998.5-2002) 3 05-01-2008 07:35 PM
Edge Juice, EGR Delete,SCT, Wheels & Tire, Liberator Egr Delete 760 PSD Whats Been Sold 3 04-22-2008 09:45 PM
cat-delete or muffler-delete Dual K20s 5.9L Cummins (2003-2007.5) 20 09-06-2007 09:49 PM
03-06 6.0L Cat Delete/Muffler Delete dfuser Supporting Vendors Forum 1 04-08-2007 09:07 PM
need a muffler delete pipe, and pushy pipe delete ~CrazyDiesel~ 2003-2007 6.0L Power Stroke 13 03-31-2006 11:56 PM
