Smarty Update? - Diesel Truck Forum - TheDieselGarage.com
Thread Details Posted by neeltburn, this thread has received 14 replies and been viewed 1287 times.
post #1 of 15 (permalink) Old 06-10-2009, 12:07 AM Thread Starter
ADMIN/MAFIA
neeltburn's Avatar
Smarty Update?
I know a few guys out there are running smarty. I was wondering if anyone had an update as to how its been preforming. Also is anyone running it with the EGR and DPF still in place and if so how is it. How are the S67mes doing on trucks with deletes...
6.7L 68RFE 4wd
Yeah its stock.
Pac Brake Air Bags
On Board Air
Optima Redtop 34Rs
2010 John Deere 2305
9-11-2001 NEVER FORGET
neeltburn is offline
post #2 of 15 (permalink) Old 06-10-2009, 01:24 AM
fuzzy's Avatar
Hey, I still love my smarty. There has now been 6 different "me" programs since it's release. 07me was the first, and it's the one I still currently run. 12me is the latest, and I got it on my computer, just not on my truck yet. Sounds like it's pretty good though. None have been bad, but 09 and 10 "me" started playing with boost fooling, and 09me had the turbo screaming loud. 10me toned down the whistle some, but I never liked the way the turbo would start to be fooled around 1500 rpms, and cruising at those rpms would make the turbo jump back and forth from being fooled and not being fooled. 12me sounds great. A little less boost fooling, and some excellent milage numbers are being reported. Maybe I'll load it this weekend, but I'm not driving my truck much lately. Oh and I shouldn't make it sound like they have tried all these different me programs. Marco has only released the 07me, and the 12me. Everything in between was sent to just certain testers for marco, and then they would get passed on thru email. The only two official releases from mads are 07, and 12me. But I still like mine. As for your other question, about a stock truck, WHAT'S THAT????
fuzzy is offline
post #3 of 15 (permalink) Old 06-10-2009, 01:41 AM Thread Starter
ADMIN/MAFIA
neeltburn's Avatar
thanks Fuzzy, Im debating about getting it and running it w/o deletes and then do deletes later but it may bite me in the warranty dept..just seeing how it was going...what kind of mileage numbers are you seeing..is your exhaust 4 or 5?
6.7L 68RFE 4wd
Yeah its stock.
Pac Brake Air Bags
On Board Air
Optima Redtop 34Rs
post #4 of 15 (permalink) Old 06-11-2009, 05:39 PM Thread Starter
ADMIN/MAFIA
neeltburn's Avatar
Fuzzy, quick question for you...are you seeing any codes with smarty? and what setting are you running while towing or do you changes settings at all...?
6.7L 68RFE 4wd
Yeah its stock.
Pac Brake Air Bags
On Board Air
Optima Redtop 34Rs
post #5 of 15 (permalink) Old 06-12-2009, 02:13 AM
fuzzy's Avatar
Still running the original 07me, and I do see codes once a week. Almost like clockwork, every friday I pop 2080, and 2084. From what I'm hearing though 12me, has all this worked out, and everyone is loving it. Wish I had more time to actually get loaded, so I could see for myself. I've only towed on sw3, and sw1, but I know guys that tow on sw7 with no problems. They carefully watch everything though. My last milage was 11.3 towing the camper at 75 mph.
fuzzy is offline
post #6 of 15 (permalink) Old 06-12-2009, 03:41 AM Thread Starter
ADMIN/MAFIA
neeltburn's Avatar
Sounds like a good deal.. I was thinking that SW3 would be the best for towing unless you used a tune without timming. Does it download to the truck smoothly? sorry for all the questions again but like I have said before I want to make sure I make the right choice. also fuzzy what exhaust are you running. 4 or 5 in TBE
6.7L 68RFE 4wd
Yeah its stock.
Pac Brake Air Bags
On Board Air
Optima Redtop 34Rs
post #7 of 15 (permalink) Old 06-13-2009, 01:25 AM
fuzzy's Avatar
Takes like 13 minutes to load off the computer onto the smarty, and like 5 or six minutes to load to the truck. It's pretty smooth really, and smarty will not load to your truck if there is a problem with the software. Say it didn't load off your computer right, and you try to load it to your truck. It won't do it, so as not to mess up your truck. It kind of stinks that you need to reload everytime you change the sw's, and even if you just want to turn up the torque, timing, or fueling within the same sw, you have to reload it. But still it only takes 5 or 6 minutes. Also if there is ever a problem while loading it to the truck, say you kick the obd2, and it comes unplugged. When you plug it back in Smarty will automatically help you put the stock tune back in, and then you can start to load again. It's pretty dummie proof, but can be a little confusing when downloading the software, and getting all you need on your computer, just to get it set up. USB drivers and all that stuff. You talked about putting it on a stock truck, and I think it would be fine. Marco has all of these tunes, even the "me" tunes nearly smoke free. So if any of you are looking for smoke, smarty is not for you. He has it all maximized for economy, and smooth power. Later on some race tunes will be coming out, and I would imagine there will be some smoke with them. I'm not saying sw7, and sw9 don't smoke at all, but not near as much as xrt. I love it. Oh and I think xrt is like a 15 to 20 minute load to the truck.
fuzzy is offline
post #8 of 15 (permalink) Old 06-13-2009, 02:18 AM Thread Starter
ADMIN/MAFIA
neeltburn's Avatar
thanks again fuzzy, I found the thread over at the cummins forum and have read a little bit of that although I have yet to join, I think all that did for me is to give me more questions. I think the power levels of smarty will suit my needs for than that of the xrt. Like I said before im not looking for big hp or lots of smoke just reliable performance and decent mileage.
6.7L 68RFE 4wd
Yeah its stock.
Pac Brake Air Bags
On Board Air
Optima Redtop 34Rs
post #9 of 15 (permalink) Old 06-13-2009, 04:20 PM
Built Not Bought
SOOTBANDIT's Avatar
Images: 9
I stil have no tmade up my mind if one day i will try the smarty or xrt? I know [email protected] is coming out very soon or it is already out but the black magic it is the same monitor as the PMT but it cost $1200 and if you already bought the xrt tuner and you have guages they are basically useless. The XRT tuner is not shift on the fly but the black magic(PMT)is but the will not get $1200 mr for that. I am not downing any of these 2 products but the edge may be dumb proof but stacked they are very lethal and i like my ability of shift on the fly. But who knows one smarty may be in the mail or xrt??????????
Military Quote Of The Year
SOOTBANDIT is offline
post #10 of 15 (permalink) Old 06-14-2009, 02:33 AM Thread Starter
ADMIN/MAFIA
neeltburn's Avatar
Is anyone on here running the XRT? I would also Like to hear any info about it as well..
6.7L 68RFE 4wd
Yeah its stock.
Pac Brake Air Bags
On Board Air
Optima Redtop 34Rs
new update?? jlake 6.7L Cummins (2007.5-2011) 0 01-20-2009 12:51 AM
SCT update 08F-250 2008-2010 6.4L Engine Tuner Forum 11 11-21-2007 10:13 PM
MPG update... jackedupF350 6.7L Cummins (2007.5-2011) 9 02-05-2007 11:32 PM
DP F5 update wftree General Ford Truck and Excursion 21 09-15-2006 03:44 AM
