Check engine light - Diesel Truck Forum - TheDieselGarage.com
Thread Details Posted by kc04, this thread has received 3 replies and been viewed 598 times.
post #1 of 4 (permalink) Old 06-20-2009, 09:00 AM Thread Starter
Its Cute Aint it!!
Check engine light
Ok my dad bought another edge today!! It already has the hot unlock. But I set it up to clear codes on start up and all that good stuff but the light wont clear. I went and tried to clear it manually but it still wont clear. Any ideas on ow to make everything clear. The only codes it pulling is low dpf pressure or something like that!
04 smarty beta 4.4 and mp-8 , superchip stickers on the windows. SOLD
Wifes 04.5 4x4 smarty and dr p box exhaust intake and new rubber 502-1162 as of 12-02-09 With mostly stock tranny. Suncoast converter and valve body.
Dad 08 swb 4x4 h&s 5in turbo back egr block edge hot unlock and crappy clutch
98 12v 5spd 4.10s bhaf, exhaust, fuel plate, 4k gsk, timing, pump mods, and 300s Studs, o-ringed head, 3 piece manifold and 5in KDP tabbed, 60lb springs, titanium keepers
Moms 03 6spd- intake, smarty jr!!
01 reg cab dually 4x4 5spd bhaf raptor 150 and comp box Farmboy 5in 2in steel spacers for the rear with 6 new 305s! injectors on the way!!!!!
kc04 is offline
post #2 of 4 (permalink) Old 06-20-2009, 12:31 PM
fuzzy's Avatar
Check the codes with truck key trick, instead of the edge. Maybe you have something else going on. If not, try key cycling 5 or 6 times. Just like you would if you were going to check for codes 3 times, but instead do it 5 or 6.
fuzzy is offline
post #3 of 4 (permalink) Old 06-20-2009, 03:23 PM
Built Not Bought
SOOTBANDIT's Avatar
Images: 9
If it is a P2454 it wont clear that all the time i have ran into this same problem. The best way i have found to sometimes make it go away is to drive a couple blocks then try clearing it again.
Military Quote Of The Year
SOOTBANDIT is offline
post #4 of 4 (permalink) Old 06-21-2009, 05:47 PM Thread Starter
Its Cute Aint it!!
K thanks guys ill try cycleing the key and see what it does.
kc04 is offline
Check engine light Fat Kid 6.7L Cummins (2007.5-2011) 7 04-19-2008 03:03 AM
check engine light 08powersmoke 2008-2010 6.4L Power Stroke 12 12-13-2007 12:40 AM
Check engine light Jamison 5.9L Cummins (1998.5-2002) 14 09-15-2007 02:25 PM
Check engine light BobandPat 2003-2007 6.0L Power Stroke 16 08-07-2006 07:13 PM
Check Engine Light comissnd 1994-2003 7.3L Power Stroke 9 08-04-2006 04:33 AM
