white smoke - Diesel Truck Forum - TheDieselGarage.com
Thread Details Posted by idahododge, this thread has received 7 replies and been viewed 3986 times.
post #1 of 8 (permalink) Old 06-24-2009, 02:17 AM Thread Starter
white smoke
I did my deletes and now the truck blows white smoke at start up about 3 times and then runs good has any body have this same stuff happen to them after the deletes ?
idahododge is offline
post #2 of 8 (permalink) Old 06-24-2009, 02:55 AM
fuzzy's Avatar
Did you delete egr too? I've heard of this with a dpf delete, and funtional egr. Other than that I'll get a little puff if it's sat for a week or two upon starting, but not if I start it everyday.
fuzzy is offline
post #3 of 8 (permalink) Old 06-25-2009, 03:34 AM Thread Starter
the egr is also deleted and it seems to blow white smoke every time I start my truck Im also running a dpf emulator kit , code free and has been code free as long as I wait 20 or 30 sec befor start up
post #4 of 8 (permalink) Old 06-26-2009, 07:53 PM
Built Not Bought
SOOTBANDIT's Avatar
Images: 9
Sounds like its doing what my edge does on startup if i clear the codes it will do a surge and puff some white until i blow the egr valve open then its done nothing to worry bout. Mine also puffs a little if i just start it up every morning i have watch the oil level no change so i dont worry bout it anymore runs like a champ
Military Quote Of The Year
SOOTBANDIT is offline
The Following User Says Thank You to SOOTBANDIT For this addition to TDG:
idahododge (06-27-2009)
post #5 of 8 (permalink) Old 06-28-2009, 02:56 AM
I bet u never took out the butterfly's from the intake plenum. I took them out of mine and that issue went away.
2007.5 Ram 3500 4x2 QC
6 speed manual
Edge Attitude with/ Juice
MP-8
S&B Cold Air Intake
4" TBE Flo-Pro
DPF delete
Egr and Egr Cooler delete
Black Tec Mafia #19
BigRed6.7CTD is offline
post #6 of 8 (permalink) Old 06-28-2009, 10:56 PM Thread Starter
your right I didnt take it out is there more than one ? how hard is it to get out I had some do my deletes for me
post #7 of 8 (permalink) Old 06-28-2009, 11:44 PM
fuzzy's Avatar
I think he's taking about the throttle valve butterfly, and you have that one out I think. White smoke is generally fuel, I wouldn't worry about it too much, but it could be an injector leaking, or losing pressure. I would think if it's losing pressure it would run pretty rough at startup, along with blowing some white smoke.
fuzzy is offline
The Following User Says Thank You to fuzzy For this addition to TDG:
idahododge (06-29-2009)
post #8 of 8 (permalink) Old 06-29-2009, 02:32 AM
All u have to do is take out the throttle blade in the plenum below where your egr was, it has two screws i think and can be stubborn the screws are sort of flatended on the very tip of them so the wouldn't back out from the factory. Mine did like u are saying the couple of white puffs of smoke and stumble for a sec but then it would clear up. Taking the butterfly out stopped that for me.
6 speed manual
MP-8
S&B Cold Air Intake
4" TBE Flo-Pro
DPF delete
Black Tec Mafia #19
The Following User Says Thank You to BigRed6.7CTD For this addition to TDG:
White smoke blue smoke low on coolant whats wrong littlebigrig6.0 2003-2007 6.0L Power Stroke 24 12-05-2009 11:11 PM
white smoke vs. black smoke DUMPIN99 1994-2003 7.3L Power Stroke 20 03-07-2008 11:01 PM
White Smoke fordfanatic69 2003-2007 6.0L Power Stroke 14 09-15-2007 05:25 AM
Can we say WHITE SMOKE. HydrillaHoundawg 2003-2007 6.0L Power Stroke 2 08-02-2006 03:12 PM
