fuel problem? - Diesel Truck Forum - TheDieselGarage.com
Thread Details Posted by BigRed6.7CTD, this thread has received 5 replies and been viewed 799 times.
post #1 of 6 (permalink) Old 06-28-2009, 12:52 AM Thread Starter
fuel problem?
Hey guys havent been on here in awhile but I need some help. My truck is doing fine except for a code coming up saying low fuel pressure on the rail. I had run across this awhile back it seemed to go away and now it is back. The truck doesn't stumble or sputter but I am wondering if the replacement plug I ordered for the fuel rail is the culprit? Any help u guys can provide would be appreciated
2007.5 Ram 3500 4x2 QC
6 speed manual
Edge Attitude with/ Juice
MP-8
S&B Cold Air Intake
4" TBE Flo-Pro
DPF delete
Egr and Egr Cooler delete
Black Tec Mafia #19
BigRed6.7CTD is offline
post #2 of 6 (permalink) Old 06-28-2009, 04:18 PM
Built Not Bought
SOOTBANDIT's Avatar
Images: 9
Did you shim the fuel rail? If not that could be your prob. If not say yourself from ahveing to replace the cp3 and get a fuel system. I just shimmed my rail and i havent thrown a code for any fuel issue yet but i might one day.
Military Quote Of The Year
SOOTBANDIT is offline
post #3 of 6 (permalink) Old 06-29-2009, 02:36 AM Thread Starter
I didn't pull apart the original plug, I ordered one from kevin that I understood was ready to go I am thinking it may just be a replacement rail plug. I am going to have the original one shimmed and swap it out and see if it fixes it, I hope so because the other alternatives aren't cheap if something else is wrong. So send out a small prayer for me and the "Big Red Machine" will let ya know what I find out tomorrow.
6 speed manual
MP-8
S&B Cold Air Intake
4" TBE Flo-Pro
DPF delete
Black Tec Mafia #19
post #4 of 6 (permalink) Old 06-29-2009, 04:03 AM
Built Not Bought
SOOTBANDIT's Avatar
Images: 9
i think that should do it for ya
post #5 of 6 (permalink) Old 06-30-2009, 02:44 AM Thread Starter
ok found out the replacement plug i installed is a plug only not a relief valve therefore no ability to shim. I also found out the cp3 is just not able to keep up with what the mp8 can ask for so i down the level to about 50% I tried it out on half on the way home and had no issues just how it goes for my truck i guess.
6 speed manual
MP-8
S&B Cold Air Intake
4" TBE Flo-Pro
DPF delete
Black Tec Mafia #19
post #6 of 6 (permalink) Old 06-30-2009, 01:06 PM
Built Not Bought
SOOTBANDIT's Avatar
Images: 9
Do you still have your oringinal plug? If so shim it and put it in. The MP-8 and power puck should be no diff. I can run mine on 100% and level 6 but i get worried sometimes so i back it off to bout 85-90%
fuel problem????? topflight250 1994-2003 7.3L Power Stroke 1 05-25-2009 03:05 AM
Fuel Pressure Problem? Lift problem? Going on long trip this weekend! JaredMTFD 5.9L Cummins (1998.5-2002) 4 01-24-2007 03:35 PM
fuel problem??? blackcloudCTD95 5.9L Cummins (1998.5-2002) 1 11-29-2006 02:00 AM
Fuel Problem (Probably) Greyhorse Medium and Heavy Duty 5 06-16-2006 09:11 PM
