chip/programer - Diesel Truck Forum - TheDieselGarage.com
Thread Details Posted by 7.3 4x4 power, this thread has received 20 replies and been viewed 4017 times.
post #1 of 21 (permalink) Old 07-07-2009, 11:26 PM Thread Starter
singles club 213!!!
7.3 4x4 power's Avatar
chip/programer
what would be the best chip or programer to run im stock all but the egr unplugged and want something that wont leave a "footprint" on it
thanks
08 DODGE crew cab long bed sxt 6.7 4x4 g56 w/ gray interior camo covered seats and dash 33 bfg km2's ranch hand front bumper and head ache rack, rhino lined bed and fuel transfer tank with bmc tool box dpf deleted egr unplugged runnin on an edge (show truck)
88 FORD four door long bed 7.3 4x4 fresh rebuild on engine 5 speed with banks turbo straight piped 3'' turbo back with 5 '' tip 5% tint all around also a b&w trailer hitch with 95 stroker front seat and 95 front clip(rebuilding)
08 FORD single cab ranger 2wd 3.2 auto stock (work truck)
93 DODGE super cab long bed 5.9 auto w/ muffler cut out(work truck)
02 DODGE super cab dually 2wd 5.9 cummins auto W/ banks exhaust and k&n air raid pushing 35 psi(oil field weed spray truck)
04 DODGE four door short bed 2wd 5.9 6 speed all but 1 cat cut out i think(haulin truck)
01 YAMAHA raptor 660 k&n filter single carb\ conversion kit and full fmf exhaust someday cam and piston(favorie toy) !!
08 CAN AM renegade 800 stock all but a k&n
7.3 4x4 power is offline
post #2 of 21 (permalink) Old 07-07-2009, 11:34 PM
fuzzy's Avatar
Some sort of pressure box is about your only choice. MP-8, or Power Puck. Everything else will leave some sort of trace, and I'm sure if they ever could see your rail pressure has been over stock psi they'd know you had a pressure box too. Not to much is untraceable. As far as best programmers, it would be Smarty and XRT. Both leave footprints though.
fuzzy is offline
post #3 of 21 (permalink) Old 07-07-2009, 11:41 PM
Im not sure if you have it or not but on the newer cummins the ECM is locked thus you cant use a chip you would have to use a programer like edge/banks. An the not leaving a foor print is a joke I was talking to a mechanic that I know that works for the dodge dealer an he said they can see any chip or programer you put in your truck if they look hard enough. Im not sure how your dealer is with mods but I know the dealer here you can run a programer an unless it causes major damage with the DPF then they will do warranty work so no big deal here.
Excavation Guy is offline
post #4 of 21 (permalink) Old 07-08-2009, 12:12 PM
I installed a Superchip Cortex programmer in my truck a little over a week ago. It has 4 programs in it for the 6.7. XS Economy/ Tow/ Performance/ Extreme. I have driven it around in all but the Extreme. I have it on the XS Economy program right now and on the hiway get over 20 MPG, 16-17 in town. It runs better than the stock computer setting, even in the Economy setting and will tow maximum load in all settings except the Performance program. If I have to take it to the dealer for anything. I will set it back to stock. Superchip recommends this, because the dealers tend to install the latest program from the manufacturer when you bring in the truck for anything. If you don't put the stock program back in you will loose the Superchip program if it is still in the truck.
I gave $369 delivered on Ebay from an authorized Superchip dealer. Plus, I went with the Superchip programmer because it had a limited Engine/Transmission warranty.
Just my 2cents with 45 years of driving experience.
Plus, when you go to the dealer and your truck is all jacked up with big tires and loud exhaust. They are more likely to check your ECM footprint. If you are an old fart like me. I don't fit the profile of a HotRodder and they are less likely to try to dig through the footprint of the ECM if I do have a engine problem. It is one of those things that you have to decide what is best for you. I plan for this truck to outlast me. But, it really ran like a slug before I installed the programmer.
Good luck with whatever you decide on.
Dirty "OLE" Man
01, 2500, 4X4, CTD. All stock for now.
91, Jeep YJ, 408"SBC, 205TC, Dana60's,4:88's, 39"Pitbull Maddog's on Raceline Beadlocks.
http://i107.photobucket.com/albums/m...k/100_0837.jpg
http://i107.photobucket.com/albums/m...n/100_0840.jpg
Dirty "OLE" Man is offline
post #5 of 21 (permalink) Old 07-08-2009, 02:02 PM
Built Not Bought
SOOTBANDIT's Avatar
Images: 9
As long as the build date is before 03/09 you are fine it will not lock your ecm. The worst thing you can do to your dpf is run any programmer while its still under your truck.
Military Quote Of The Year
SOOTBANDIT is offline
post #6 of 21 (permalink) Old 07-08-2009, 03:21 PM
pretty much the new 6.7 is really nice but I wouldnt buy one new I would get one used an then mod it, but Id like to have a 12 or 24valve
post #7 of 21 (permalink) Old 07-08-2009, 03:26 PM
Built Not Bought
SOOTBANDIT's Avatar
Images: 9
Ya i would like to have one of each but if anyone wants to get a new one they better hurry or mods are going to be limited till they figure this ecm BS out. As far as the original poster these trucks are very reliable once you get the emissions bs off but there are some that have had good luck with stock form i personaly have had ZERO!!! problems since it has been deleted.
post #8 of 21 (permalink) Old 07-09-2009, 12:44 AM
ADMIN/MAFIA
neeltburn's Avatar
Just a quick question but has anyone heard of anyone running into a truck with a locked ECM or is it just a rumor? I personally would have to think that by now someone on here would have had this happen by now. Just wondering
6.7L 68RFE 4wd
Yeah its stock.
Pac Brake Air Bags
On Board Air
Optima Redtop 34Rs
2010 John Deere 2305
9-11-2001 NEVER FORGET
neeltburn is offline
post #9 of 21 (permalink) Old 07-09-2009, 01:12 AM
fuzzy's Avatar
Just from what I read everyone that has a 09, has had a build date before 4/09, and they are good to go. I don't think it's a rumor though, and anyone with a build date after 4/09 I don't think has even tried. From what I read H&S has been working on it, and Marco has said bring it on. Not sure why or what they would be working on if it wasn't true. Just my thoughts.
fuzzy is offline
post #10 of 21 (permalink) Old 07-09-2009, 01:31 AM
ADMIN/MAFIA
neeltburn's Avatar
That is true Fuzzy, I guess time will tell. I just wondered if anyone on here had had trouble with it?
6.7L 68RFE 4wd
Yeah its stock.
Pac Brake Air Bags
On Board Air
Optima Redtop 34Rs
Chip/Programer? cummins kid 5.9L Cummins (1998.5-2002) 30 04-22-2009 06:55 PM
best chip or programer doob51 5.9L Cummins (2003-2007.5) 6 02-02-2008 11:35 PM
Chip/programer? dieselteel 5.9L Cummins (2003-2007.5) 1 12-01-2007 02:17 AM
programer or chip on my 7.3? Ponis 1994-2003 7.3L Chips & Tuners Forum 9 08-04-2006 08:26 PM
what type of chip/programer? StrokerAce 5.9L Cummins (2003-2007.5) 19 01-14-2006 04:34 PM
