Oil changes - Diesel Truck Forum - TheDieselGarage.com
Thread Details Posted by neeltburn, this thread has received 30 replies and been viewed 1953 times.
post #1 of 31 (permalink) Old 07-22-2009, 10:21 PM Thread Starter
ADMIN/MAFIA
neeltburn's Avatar
Oil changes
Guys my oil change reminders keep going off sooner. I and running premium blue 15W40 and fleet guard filters with little idle time. I called my deal, cummins and dodge and they have no clue. I think I should be getting more than 2500mi per oil change. Can they reset or change a sensor? What ideas do you have? Cummis seems to think the service interval can be change or it is misreading something. My solution is doing deletes sooner than later.
6.7L 68RFE 4wd
Yeah its stock.
Pac Brake Air Bags
On Board Air
Optima Redtop 34Rs
2010 John Deere 2305
9-11-2001 NEVER FORGET
neeltburn is offline
post #2 of 31 (permalink) Old 07-23-2009, 01:31 AM
Dodgefarmer's Avatar
If it is a sensor, which one?? As I understand they are multiple sensors involved in determining when oil changes are done. It is based on load, idle time, temperture of engine, rpms, mileage and ??? All these factors and others are used to compute when oil changes are needed.
I get my oil changed every 6000 miles and never see the oil change message.
singles club # 198
Dodgefarmer is offline
post #3 of 31 (permalink) Old 07-23-2009, 02:01 PM Thread Starter
ADMIN/MAFIA
neeltburn's Avatar
Im at a loss guys it only been 2500 miles since I changed it last. Can the oil really be ready to be changed.
6.7L 68RFE 4wd
Yeah its stock.
Pac Brake Air Bags
On Board Air
Optima Redtop 34Rs
post #4 of 31 (permalink) Old 07-23-2009, 10:46 PM
Still kickin
Flopster843's Avatar
Just reset the oil change indicator. I don't rely on that thing anyway. I change my oil when I decide I want to change my oil.
Turn ignition to ON but do not start.
Press accelerator pedal to the floor and back 3 times within 10 seconds. (I found that one second down, one second up, one second down, etc. seems to work the best)
Turn ignition switch to OFF.
It may be necessary to repeat this procedure until you get the timing right.
John
08 6.7 QC SB 4x4 "hand-shaker" edition, De-Badged, EGR Delete, TTT Mirrors, Auto Exhaust Brake, etc.
All details and instructions --> www.CarboniteCummins.com
Successfully blew up three 6.0s before moving up in the food chain.
Flopster843 is offline
post #5 of 31 (permalink) Old 07-24-2009, 05:25 AM Thread Starter
ADMIN/MAFIA
neeltburn's Avatar
this is what I ended up doing...I think Im going to start running 5000 between or should I only go to 4000?
6.7L 68RFE 4wd
Yeah its stock.
Pac Brake Air Bags
On Board Air
Optima Redtop 34Rs
post #6 of 31 (permalink) Old 07-24-2009, 11:31 AM
dodgefarmer2's Avatar
i changed my oil at 10,000 miles and my thingy come on at 11,000 so i just reset it, at 13,000 now hasn't come on yet.
08 dodge 3500 dually, quad cab, inferno red,6.7, 4x4, 6sp auto, rhino lined bed, b&w gooseneck turnover ball,full length fiberglass running boards (color matching),reese hitch.
MEMBER THE DUALLY CLUB #75
MEMBER THE AMERICAN CLUB #41
10,055,000.00 points approximately
dodgefarmer2 is offline
post #7 of 31 (permalink) Old 07-24-2009, 05:19 PM Thread Starter
ADMIN/MAFIA
neeltburn's Avatar
From what I am seeing, everybody's reminder is coming on at different intervals. My dealer said that I can run 5k between oil changes. so I think thats what Im gonna do. My next question is can the reminder be turned off to never come one, I know it doesnt take long to reset.
6.7L 68RFE 4wd
Yeah its stock.
Pac Brake Air Bags
On Board Air
Optima Redtop 34Rs
post #8 of 31 (permalink) Old 07-24-2009, 07:30 PM
Kummins's Avatar
My suggestion is when your light comes on go get an oil integrity test. AMSOIL sells one that you can do in your garage. This will tell you if the problem is really your oil or a sensor.
06 2500 Quadcab SLT
Billet Tranny
BD with Crazy Larry
Quadzilla Boost Fooler
S&B Intake
MBRP all the way back and "High Flow Cat"
6" Lift, 35" Toyo MT's, 20" Incubus wheels
Some Audio Goodies Too
MAY 2008 TDG Truck of the Month
Kummins is offline
post #9 of 31 (permalink) Old 07-25-2009, 05:54 AM Thread Starter
ADMIN/MAFIA
neeltburn's Avatar
I am looking into this. I may go a head and change it this time and run the used oil through the test.
6.7L 68RFE 4wd
Yeah its stock.
Pac Brake Air Bags
On Board Air
Optima Redtop 34Rs
post #10 of 31 (permalink) Old 07-29-2009, 12:56 PM
Hey man, don't worry about that little light, just come up with some kind of a schedule and change it when you want to, since I've gutted my truck my light hasn't come up once and it used to come on about every 3000 miles or so.
07 2500 Mega Cab 6.7L 4X4 :givemebeer
bigtruck is offline
