What is EGR and DPF - Diesel Truck Forum - TheDieselGarage.com
Thread Details Posted by 08White, this thread has received 2 replies and been viewed 718 times.
post #1 of 3 (permalink) Old 08-14-2009, 02:19 PM Thread Starter
First Diesel
What is EGR and DPF
Im just confused on what both do. Should I delete them? If so why? Been trying to decide on what to do and exactly how to do it. Cause I hae heard that if you delete both of these the truck will last longer....
If I delete the egr what does that do my truck? What gains?
Same question about DPF
Thanks guys, learning alot on here
08White is offline
post #2 of 3 (permalink) Old 08-14-2009, 02:44 PM
Built Not Bought
SOOTBANDIT's Avatar
Images: 9
I will go into more detail when you call today. But yes deleting both of these items on our trucks def increases the life of the truck. But some have had no problems with leaving everything on im just not goin to take that risk.
Military Quote Of The Year
SOOTBANDIT is offline
post #3 of 3 (permalink) Old 08-18-2009, 08:39 PM
Ghost
Phily's Avatar
The EGR you will see the most benefit by deletion. The EGR stands for Exhaust Gas Recirculation. It recirculates exhaust gas back into the engine. This introduces acids and other crap into the oil. And you can guess at all the bad things that follows this. Also being we talking about a diesel engine here, the EGR reduces power and increases fuel consumption. While causing more pollution in the CO, CO2, HC and Particulate matter areas. The EGR's only purpose is to reduce NOx emissions. (Which diesels have always been known to have issues with)
The DPF is a Diesel Particulate Filter it filters the particulate matter (soot) that comes from diesel engines, and being it's got a EGR on it, it has to actually work harder, than if it didn't have a EGR........
Phily is offline
The Following User Says Thank You to Phily For this addition to TDG:
08White (08-18-2009)
