2009 6.7L issues - Diesel Truck Forum - TheDieselGarage.com
Thread Details Posted by cummins power, this thread has received 6 replies and been viewed 1259 times.
post #1 of 7 (permalink) Old 08-19-2009, 04:15 PM Thread Starter
Hot Rod Farm Boy
cummins power's Avatar
I turned 21
2009 6.7L issues
2009 Dodge 3500 6.7L Cummins 6 speed auto 4X4. Our dealer is awesome, they don't care if you remove emissions equipment, they will retain your warranty so long as you bring your rig back to them for service. So, Dad had them take off the cat and DPF. We got away without a tuner because one of the guys that works there is a Cummins genius, and he figured out that he could switch some diodes in the ECM around to make it run without the DPF etc but the check engine light would still be on. So I talked Dad into a Smarty S67 ME, the dealer put it on set on level 1. Now, you could just be driving down the road and it will start hazing black smoke. If you pop the throttle or let off for a second, it goes away. Its pretty sporadic, but we only noticed it when we were pulling our ski boat. My guess is we have to go get the ECM parts put back to stock. What does everyone else think? Sorry for the long post
Logan
Do Or Die Garage Experiment
cummins power is offline
post #2 of 7 (permalink) Old 08-19-2009, 04:47 PM
Built Not Bought
SOOTBANDIT's Avatar
Images: 9
what sdealer you talking bout the one in oregon or wyoming?
Military Quote Of The Year
SOOTBANDIT is offline
post #3 of 7 (permalink) Old 08-20-2009, 03:28 AM Thread Starter
Hot Rod Farm Boy
I turned 21
Oregon
Logan
The Following User Says Thank You to cummins power For this addition to TDG:
SOOTBANDIT (08-20-2009)
post #4 of 7 (permalink) Old 08-20-2009, 01:52 PM
Built Not Bought
SOOTBANDIT's Avatar
Images: 9
I will say the guys in Laramie are nicer than cheyenne on some things
post #5 of 7 (permalink) Old 09-08-2009, 01:33 AM
TeamTonka
Send a message via MSN to TeamTonkadodge
That used to happen to me all the time... What that is is the egr part of your motor. I did an egr delete and got rid of that problem. Hope this is helpful
2002 3/4 ton CTD 4x4. 5 spd. jus straight piped for now. Want a edge programer.
"No Stoppin Team Tonka"
TeamTonkadodge is offline
post #6 of 7 (permalink) Old 09-08-2009, 01:49 AM
fuzzy's Avatar
Ya, if that egr is still on there it's going to haze. I agree with this, but I would still have that guru reverse what ever he did.
fuzzy is offline
post #7 of 7 (permalink) Old 10-12-2009, 07:41 PM Thread Starter
Hot Rod Farm Boy
I turned 21
Kinda forgot about this thread. But we got the Smarty updated and put the ECM back to stock, and now we run it on level 3 instead of level 1. I'm not sure what version we had or what version is on it now, but it seems to have stopped the problem.
Logan
2009 4.5L Sub 4cstr All New 4.5L Duramax 39 08-22-2009 03:46 AM
New 2009 TDI CrowsSynthetics Euro-Diesels 29 08-01-2009 11:47 PM
New to TDG...Looking at a 2009 GMC reddnecc Duramax 07.5-2010 (LMM) 13 06-30-2009 02:02 AM
new 2009 DieselJr 6.7L Cummins (2007.5-2011) 2 06-01-2009 04:20 PM
First for 2009 squeeky The Parking Lot 2 01-01-2009 06:03 AM
