Need help on EGR removal - Diesel Truck Forum - TheDieselGarage.com
Thread Details Posted by your nightmare, this thread has received 13 replies and been viewed 2484 times.
post #1 of 14 (permalink) Old 08-21-2009, 12:46 AM Thread Starter
Redneck with some Bling
your nightmare's Avatar
Images: 1
I know some of you have gutted you DPF and some were stolen
Can you get the electronic foolers with out getting them with a kit? (pipe) I gutted my DPF Truck ran great for a few days then DPF warnings started it's full and needs service I cannot clear 1 code 1451 differential presure diferance to low any ideas? Truck has a big loss of power now I will try to re-flash ECM I ran a test 1/4 mile and was at 14.5 -15 today lost all power
2007 Dodge 2500 Mega cab Laramie fully loaded (love my heated seats in the winter) 6.7L
Banks cold air intake w/super scoop techni-cooler
wishing someone would steal my DPF Holly crap it fell off the other day
EGR stealth kit on
SMARTY OMG love it
6" stacks
Klienn Train horns 156.9db Get out of my way or you will pee yourself
HID projector headlights Custom grill with 7" EURO lights ("can you see me now")
37x14.5x20 NITTO TG HELO rims
6" TGC W/ pure porformance long arm kit
6" ATLAS rear springs
Rides like a 1500
to all military members MARINE
http://www.youtube.com/watch?v=9jYwzk-G4Q8
http://www.youtube.com/watch?v=Dx3Qkjljk4o
your nightmare is offline
post #2 of 14 (permalink) Old 08-21-2009, 01:40 AM Thread Starter
Images: 1
Update
I have reloaded program and I still have the code and no power I would get a good haze behind me when I was WOT now just a puff at low rpm my truck aks like it is stock again
EGR stealth kit on
SMARTY OMG love it
6" stacks
Rides like a 1500
post #3 of 14 (permalink) Old 08-21-2009, 02:21 AM
ADMIN/MAFIA
neeltburn's Avatar
Thats really what is weird about our trucks, some guys and "get away with" doing a dpf delete as you have done and it work fine. Others yourself included in this category will end up in limp mode which is what I assume is the case with your truck as you have stated a loss of power. I am not 100% how to get the truck out of limp mode. You can possiblly add the sims into you harness to fool the ECM into thinking everything is running correctly. I am not sure of what Ohm sims are needed for each sensor but I do believe that someone one here can point you in the right direct. I would tend to beleive that if you fool the truck into making it see "normal" perimeters that it would come out of limp mode. but there may be something that needs to be reset.
6.7L 68RFE 4wd
Yeah its stock.
Pac Brake Air Bags
On Board Air
Optima Redtop 34Rs
2010 John Deere 2305
9-11-2001 NEVER FORGET
neeltburn is offline
your nightmare (08-21-2009)
post #4 of 14 (permalink) Old 08-21-2009, 05:33 AM Thread Starter
Images: 1
I downloaded the extras for my programer and it has a load senser in it 43% thats it Last night i was about 95 mph in the 1/4 mile today 73 I have the following codes p242f, p244a, p1451 this is the one I cannot delete
EGR stealth kit on
SMARTY OMG love it
6" stacks
Rides like a 1500
post #5 of 14 (permalink) Old 08-22-2009, 02:47 AM
fuzzy's Avatar
Run a 330 resistor across the 2 pins in all 3 plugs that would normally plug into the egt theromcouplers in the exhaust. You can't just run the pipe with nothing fooling the computer. Just those resistors are not enough anymore either but it would of got u by a little longer than a day. If I were you, I'd sell the superchips, and get a smarty or xrt. That is by far the easiest way, and then you don't need any of the foolers.
fuzzy is offline
The Following User Says Thank You to fuzzy For this addition to TDG:
your nightmare (08-22-2009)
post #6 of 14 (permalink) Old 08-22-2009, 07:10 AM Thread Starter
Images: 1
Try to get my hands on a banks but getting tired of all the bullchit with them I think I have lost respect for them
Right now everything is hooked up I have tride to disconnect the bat for 1 hr but cant reset computer out of limp mode
But yes I will be ordering a smarty this weekend xrt to much smoke good for tailgaters but not daily driving
EGR stealth kit on
SMARTY OMG love it
6" stacks
Rides like a 1500
post #7 of 14 (permalink) Old 08-23-2009, 08:08 PM
fuzzy's Avatar
Once you get your smarty, maybe talk to Bob, or even Marco isn't that hard to get a hold of. They may be able to help you get out of limp mode, but other than that, you might have to see a dealer to get out.
fuzzy is offline
post #8 of 14 (permalink) Old 08-29-2009, 05:44 AM Thread Starter
Images: 1
SMARTY is on!!!!!!!
I love this thing
I about chit myself when I got on it at 60mph hit 100mph and said WOW that was quick no mass amounts of smoke I like that just enough to get tailgaters off my ***
Well the smoke of maybe it is the power and I just walk away
EGR stealth kit on
SMARTY OMG love it
6" stacks
Rides like a 1500
post #9 of 14 (permalink) Old 09-05-2009, 08:33 AM
6.7L Man Van
-lenny-'s Avatar
Right on, I'm wanting to throw a Smarty on my truck and do the deletes. Glad to hear you got everything worked out. Keep us posted, more info is always better!
08 MC 3500 68RFE
Mostly Stock
-lenny- is offline
post #10 of 14 (permalink) Old 09-05-2009, 11:59 PM Thread Starter
Images: 1
Lenny go to the wait is over thread have a vid of the truck on the dyno It smake a little bit more than on the dyno if you stomp it at low speed were is brooks I was just in edmonton today still at airport now
EGR stealth kit on
SMARTY OMG love it
6" stacks
Rides like a 1500
dp removal 99_stroker 1994-2003 7.3L Chips & Tuners Forum 1 03-25-2008 03:47 PM
Rim removal 33bigdog General Ford Truck and Excursion 1 10-24-2006 11:04 AM
oil pan removal GotSmoke? 1994-2003 7.3L Power Stroke 2 08-25-2006 03:48 PM
EGR Removal Notorious6.0 2003-2007 6.0L Power Stroke 2 10-24-2005 07:12 PM
