Have a bad problem - Diesel Truck Forum - TheDieselGarage.com
Thread Details Posted by TeamTonkadodge, this thread has received 21 replies and been viewed 3005 times.
post #1 of 22 (permalink) Old 09-08-2009, 01:29 AM Thread Starter
TeamTonka
Send a message via MSN to TeamTonkadodge
Have a bad problem
I own an 08 dodge 2500 6.7l and jus recently put on an mbrp 5in. turbo back exhaust, smarty with m/e download and an afe stage II intake also an egr delete. My problem is that after putting all this on and running about 100 miles or so i would come to an idle and my turbo would gradually begin to whistle louder and louder all while still at a dead stop idle it would then get to a certain point and change the tone of the whistle and then my motor would begin idleing rough and rev up to almost 1000rpms... I began trying all sorts of things and still had the weird whistle until finally i pulled the fuse controlling the vgt and it stopped but my turbo took forever to spool up which was expected and my motor would still idel funny as it did before. It also threw a code for mass airflow sensor weak circuit so i narrowed it down to something with the vgt part of the turbo but have no idea how to permenantly fix it... as of right now the only thing i can do is change power levels on my smarty and stop the whistle temporarily. Ive asked everybody i know and have yet to come up with an answer so i was hoping yall couldgive me any kind of HELP!!!!
thanks
2002 3/4 ton CTD 4x4. 5 spd. jus straight piped for now. Want a edge programer.
"No Stoppin Team Tonka"
TeamTonkadodge is offline
post #2 of 22 (permalink) Old 09-08-2009, 01:54 AM
fuzzy's Avatar
Check your sensor in your new afe stage 2 intake tube. Make sure it's plugged in and installed correctly. I'd say that has to be it. Might need a new one, but since you just messed with it, check it all out first.
fuzzy is offline
post #3 of 22 (permalink) Old 09-08-2009, 02:04 AM Thread Starter
TeamTonka
Well i would agree with you on that but i had to replace the intake and exhaust with the stock parts to get some warranty work done and actually left it on for a while to see if it would do the same thing and it didnt which is what really confused me... but thanks for the advice
post #4 of 22 (permalink) Old 09-08-2009, 04:46 AM
after having my truck for 3 days and previously driving a older powerstroke, I just CAN'T UNDERSTAND why everyone wants to mod these trucks out. In stock form, the Cummins would run circles around my modified Ford Powerstroke.
JakeB is offline
post #5 of 22 (permalink) Old 09-08-2009, 06:51 PM
6.7L Man Van
-lenny-'s Avatar
Its simple really. Too much is never enough. I don't know if it is a disease or an addiction, or what, but whenever I get something that has an engine in it of some sort, I start looking for ways to change it. I guess maybe I like tinkering, or seeing what the hidden potential is. I can't do stock. Obviously, you've got to pay to play, and as long as you realize that, it can be a very enjoyable process, even when its not going quite right.
08 MC 3500 68RFE
Mostly Stock
-lenny- is offline
post #6 of 22 (permalink) Old 09-09-2009, 02:11 PM Thread Starter
TeamTonka
ttt
post #7 of 22 (permalink) Old 09-09-2009, 05:46 PM
Smarty Guru
are you sure that you are running R14ME software? When you plug the smarty in look quick at the screen to see the version number on the right side of the display. Have you changed any of the default settings?
Bob Wagner is offline
post #8 of 22 (permalink) Old 09-09-2009, 09:32 PM Thread Starter
TeamTonka
Im pretty sure i am running the me software... and i do go into the default settings to turn the dpf/egr off. I thought it might be something the smartys doin but im not sure yet... I dont know why the smarty would make the turbo do that after so many miles.
Has anybody ever heard of a problem like this?
post #9 of 22 (permalink) Old 09-09-2009, 11:10 PM
JacktheBear3's Avatar
I think the reason Bob is asking is because Regen will raise the idle.... Stanger things happen.
If you have too much build up in the VGT, would it spool at idle more? causing an issue with MAP, MAf and the fueling at idle ?
JacktheBear3 is offline
post #10 of 22 (permalink) Old 09-09-2009, 11:36 PM Thread Starter
TeamTonka
hey bob I looked at my smarty and I have R10ME software. is the R14ME software an update?
Ole JIm Problem Ole JIM 5.9L Cummins (Pre 1994) 6 04-29-2009 03:48 AM
ABS problem plowman61 5.9L Cummins 12 Valve (1994-1998.5) 12 03-27-2008 08:29 AM
big problem- need help!! vrsc 2003-2007 6.0L Power Stroke 8 09-14-2007 01:10 AM
1 new problem, 1 old problem, 1 problem fixed LOL Liftedpsd 2003-2007 6.0L Power Stroke 16 04-23-2007 12:13 PM
Fuel Pressure Problem? Lift problem? Going on long trip this weekend! JaredMTFD 5.9L Cummins (1998.5-2002) 4 01-24-2007 03:35 PM
