smarty ? - Diesel Truck Forum - TheDieselGarage.com
Thread Details Posted by diesel71, this thread has received 5 replies and been viewed 1215 times.
post #1 of 6 (permalink) Old 09-15-2009, 10:22 PM Thread Starter
diesel71's Avatar
smarty ?
Need some help from you dodge guy"s I need to do a dpf delete on a customers 2007 dodge with a 6.7, we want to delete the dpf and keep stock programing. will the smarty tuner do this? or could you point me in the right direction thanks.
diesel71 is offline
post #2 of 6 (permalink) Old 09-16-2009, 04:56 AM
ADMIN/MAFIA
neeltburn's Avatar
I believe the HS XRT has stock tuning with "race exhaust" how ever I believe that all Smarty tunes add HP when using it. Is the a reason why he does not want the truck tuned?
6.7L 68RFE 4wd
Yeah its stock.
Pac Brake Air Bags
On Board Air
Optima Redtop 34Rs
2010 John Deere 2305
9-11-2001 NEVER FORGET
neeltburn is offline
post #3 of 6 (permalink) Old 09-16-2009, 06:08 PM Thread Starter
diesel71's Avatar
yes,he dont want any more power or a tune because it"s a work truck and differant people will be driving it. thanks for the help ill check out the hs xrt.
diesel71 is offline
post #4 of 6 (permalink) Old 09-16-2009, 07:23 PM
Built Not Bought
SOOTBANDIT's Avatar
Images: 9
if he dont want any other power adder just put a delete pipe on and unplug the cel light that would be the cheapest way. buying an xrt and not to use it would be a waste imo
Military Quote Of The Year
SOOTBANDIT is offline
post #5 of 6 (permalink) Old 09-16-2009, 11:31 PM Thread Starter
diesel71's Avatar
I thought if you did that it would go into regen and not come out of it?
diesel71 is offline
post #6 of 6 (permalink) Old 09-17-2009, 12:01 AM
Built Not Bought
SOOTBANDIT's Avatar
Images: 9
as long as you run the sims you will be fine
Smarty ?? dangerous196 5.9L Cummins (2003-2007.5) 2 03-09-2008 08:01 PM
smarty bob99 24 Valve Performance 10 02-29-2008 03:56 AM
Smarty S-06 3592788 Whats Been Sold 4 01-29-2008 01:23 AM
Smarty CumminsPower Supporting Vendors Forum 3 08-23-2007 10:17 PM
smarty xjjeep00 Whats Been Sold 3 08-14-2007 06:20 AM
