Turbo replacement concerns - Diesel Truck Forum - TheDieselGarage.com
Thread Details Posted by droot, this thread has received 6 replies and been viewed 4130 times.
post #1 of 7 (permalink) Old 09-22-2009, 06:15 PM Thread Starter
My 08 2500 with 17k miles has been in a couple times for check engine lights. First time they performed software updates. The second time they are replacing the turbo. Is there anything I should be doing aside from just continuing to take it back each time I get a light? Should I be worried about the updates they performed or the new turbo they are putting on?
Once the warranty expires I plan on both deletes.
droot is offline
post #2 of 7 (permalink) Old 09-22-2009, 06:19 PM
Skyd Ram's Avatar
Do you have your EGR unplugged? It will trigger a code and you will loose a little power but it will increase your mileage and extend the life of your turbo substantially.
2010 CCSB Laramie Ram 2500 4x4
Powered By:
H&S/Shibby/Black Ops/Flo Pro
Suspended by:
Carli Suspension/Bilstein
2008 RCLB F250 XLT 6.4 Auto
Powered By:
H&S/Flo Pro/aFE
Suspended by:
Pure Performance/Carli/Bilstein
Skyd Ram is offline
post #3 of 7 (permalink) Old 09-22-2009, 06:46 PM Thread Starter
My truck is totally stock. I have not made any mods.
Would unplugging the EGR void warranty? Could I easily determine the codes thrown for the EGR unplug and others that might need attention?
droot is offline
post #4 of 7 (permalink) Old 09-22-2009, 07:22 PM
Built Not Bought
SOOTBANDIT's Avatar
Images: 9
I know you said you wanted to wait till warranty expires BUT i will say again you will not be dissapointed and will never go back again for a turbo issue or egr issue IF you do the deletes now im coming up on 40k since deletes were done and ZERO issues i do all my maintenance myself on my truck. You will love your truck even more and your truck will love you more also plus if you are worried bout warranty as long as you dont put a programmer on or chip or tuner they can not void your warranty over the exhaust as long as you put it back to stock before you go in for warranty BUT i will say it again you wont have to go back in again. any questions just ask. not trying to twist your arm into doing the deletes but if you want the best out of your truck you will HIGHLY consider doing this early. i was really concerned just like you when my truck started having turbo issues at 22k and egr codes etc....not going to lie i was almost half tempted to strike a match in the seat but now im happy as can be Good Luck wit whatever you decide to do
Military Quote Of The Year
SOOTBANDIT is offline
The Following User Says Thank You to SOOTBANDIT For this addition to TDG:
droot (09-23-2009)
post #5 of 7 (permalink) Old 09-22-2009, 07:29 PM Thread Starter
Thanks Soot. That's excellent info. I'll talk to some local moonlighting mechanics about these potential deletes and get their 2 cents also. I sure would like the extra power and lack of problems.
droot is offline
post #6 of 7 (permalink) Old 09-22-2009, 07:34 PM
Built Not Bought
SOOTBANDIT's Avatar
Images: 9
I wish everyone that had concerns could just borrow a modded 6.7 to actually get the seat of the pants that needed it cause i would bet a cold case of w.e. you drink that you would try to steal my truck . Like you said you hit it on the head all those headaches would be gone for good and you get extra power better mileage and the heads turn when they hear the EB come on in a straight piped 6.7
post #7 of 7 (permalink) Old 09-24-2009, 05:20 PM
Redneck with some Bling
your nightmare's Avatar
Images: 1
I had EGR codes too and they replaced my control valve and had to clean my cooler About the deletes they make a stelth kit that you can put in it goes under the intake valve and blocks the prot off I paid $25 for mine and that should not throw a code unpluging it will and then you will not know if something else goes wrong
2007 Dodge 2500 Mega cab Laramie fully loaded (love my heated seats in the winter) 6.7L
Banks cold air intake w/super scoop techni-cooler
wishing someone would steal my DPF Holly crap it fell off the other day
EGR stealth kit on
SMARTY OMG love it
6" stacks
Klienn Train horns 156.9db Get out of my way or you will pee yourself
HID projector headlights Custom grill with 7" EURO lights ("can you see me now")
37x14.5x20 NITTO TG HELO rims
6" TGC W/ pure porformance long arm kit
6" ATLAS rear springs
Rides like a 1500
to all military members MARINE
http://www.youtube.com/watch?v=9jYwzk-G4Q8
http://www.youtube.com/watch?v=Dx3Qkjljk4o
your nightmare is offline
Replacement Turbo fine69 2003-2007 6.0L Power Stroke 9 01-05-2009 10:16 PM
Turbo Replacement Don Stefanik 2003-2007 6.0L Power Stroke 4 03-06-2008 02:53 AM
replacement turbo RussK 1994-2003 7.3L Power Stroke 7 01-09-2008 02:21 PM
What are main concerns when overboosting stock turbo? Nazghul 5.9L Cummins (2003-2007.5) 7 11-30-2007 02:32 PM
Turbo replacement montauk 2003-2007 6.0 Tuner Forum 3 03-14-2007 07:20 PM
