smarty with dpf? - Diesel Truck Forum - TheDieselGarage.com
Thread Details Posted by NelsonDiesel, this thread has received 12 replies and been viewed 1256 times.
post #1 of 13 (permalink) Old 09-27-2009, 09:20 PM Thread Starter
NelsonDiesel's Avatar
smarty with dpf?
Is there an option to run the smarty with or without the dpf?
NelsonDiesel is offline
post #2 of 13 (permalink) Old 09-27-2009, 09:23 PM
Built Not Bought
SOOTBANDIT's Avatar
Images: 9
I believe there is but idk for sure. Why dont you just delete the dpf if you wanna run smarty?
Military Quote Of The Year
SOOTBANDIT is offline
post #3 of 13 (permalink) Old 09-28-2009, 02:03 AM
ADMIN/MAFIA
neeltburn's Avatar
The smarty is set to run on a DPF equipped truck as it is shipped to you. You will need to download the latest version of ME to run it w/o the DPF.
6.7L 68RFE 4wd
Yeah its stock.
Pac Brake Air Bags
On Board Air
Optima Redtop 34Rs
2010 John Deere 2305
9-11-2001 NEVER FORGET
neeltburn is offline
NelsonDiesel (09-28-2009)
post #4 of 13 (permalink) Old 09-28-2009, 02:16 AM Thread Starter
buying a used truck with an extended warranty. I would like to retain the warranty and then after it expires i can look into deleting.
just want the little extra a tuner can offer on the lower tunes but want to keep the truck stock for the most part.
post #5 of 13 (permalink) Old 09-28-2009, 03:06 AM
ADMIN/MAFIA
neeltburn's Avatar
The Smarty S67 is traceable, just a FYI if you are going to run it with your warranty. I would feel the dealer out to see if they are "mod friendly" before you risk loosing your warranty. Just a little heads up.
6.7L 68RFE 4wd
Yeah its stock.
Pac Brake Air Bags
On Board Air
Optima Redtop 34Rs
post #6 of 13 (permalink) Old 09-28-2009, 03:38 AM Thread Starter
hmmmm, i thought it was a unplug the battery to clear all info kind of deal?
Don't plan on higher then first or second setting. I'm a dmax guy and know that even the slightest tune on a stocker can make good improvements on driveability and mileage.
may just not go with a tuner for a bit then .....
post #7 of 13 (permalink) Old 09-28-2009, 04:09 AM
ADMIN/MAFIA
neeltburn's Avatar
I am going by mads web site and they say it is traceable...I am not sure how if a dealer can tell just my plugging in the starscan or what the deal is, but I know they say it leaves a footprint unlike the other versions. I just thought you would like to know.
6.7L 68RFE 4wd
Yeah its stock.
Pac Brake Air Bags
On Board Air
Optima Redtop 34Rs
post #8 of 13 (permalink) Old 09-28-2009, 05:09 PM
Skyd Ram's Avatar
The Smarty S-67 is definitely traceable. You will probably find a few dealers out there that will look the other way when it comes to deletes but they get kinda worked up about tuners. You could do an Edge Race Juice with attitude with a full TBE and EGR delete. You would then put the stcok junk back on if you had to go to the dealer for warranty work. Without the deletes you can plan on some dealer visits for sure.
2010 CCSB Laramie Ram 2500 4x4
Powered By:
H&S/Shibby/Black Ops/Flo Pro
Suspended by:
Carli Suspension/Bilstein
2008 RCLB F250 XLT 6.4 Auto
Powered By:
H&S/Flo Pro/aFE
Suspended by:
Pure Performance/Carli/Bilstein
Skyd Ram is offline
post #9 of 13 (permalink) Old 09-28-2009, 06:11 PM Thread Starter
i think i will give it a chance first. See how all this stuff works out. the truck has a new turbo on it as it is. supposed to be the newest design as found on the 2010 models ... not sure what all that is but i guess i will wait and see.
post #10 of 13 (permalink) Old 09-28-2009, 06:13 PM Thread Starter
what options do i have for a small increase whiole retainign all emissions?
i had planned on a dpf back and an S&B Intake but thats about the extent of it as of now ...
Smarty TST IgotTwins 5.9L Cummins (2003-2007.5) 4 03-06-2009 09:00 PM
smarty jr. GOAT 5.9L Cummins (2003-2007.5) 6 03-27-2008 09:25 PM
Smarty ?? dangerous196 5.9L Cummins (2003-2007.5) 2 03-09-2008 08:01 PM
Smarty CumminsPower Supporting Vendors Forum 3 08-23-2007 10:17 PM
smarty xjjeep00 Whats Been Sold 3 08-14-2007 06:20 AM
