washer pump??? - Diesel Truck Forum - TheDieselGarage.com
Thread Details Posted by SOOTBANDIT, this thread has received 11 replies and been viewed 1348 times.
post #1 of 12 (permalink) Old 10-11-2009, 09:05 PM Thread Starter
Built Not Bought
SOOTBANDIT's Avatar
Images: 9
washer pump???
Ok so nothing pisses me off more than when your window is dirty and you go to hit the switch for some washer fluid to come do its dirty work and nothing and to top it off its cold as **** outside!!!! I checked the fluid plenty there, seems to not be frozen stuck a metal hanger down in there and stirred it around no slush that i can see poured hot water on the nozzles severle times with no result. I can not hear my pump or motor kick on so im thinking electrical but i could be wrong any help would be greatly appreciated cause its getting old stopping at the gas station to wash my window.
Military Quote Of The Year
SOOTBANDIT is offline
post #2 of 12 (permalink) Old 10-12-2009, 02:06 AM
ADMIN/MAFIA
neeltburn's Avatar
Brandon,
I have had the lines not completely freeze but go to slush and no flow.. that could be what you have going on.
I would make sure you check the fuse or relay for the washer fluid spray. If it was working before the cold and snow I would believe that is your problem.
Also what kinda of washer fluid are you running? I run a rain-x all season that has Ice melt in it...it does seem to stop this from happening..Just a thought.
6.7L 68RFE 4wd
Yeah its stock.
Pac Brake Air Bags
On Board Air
Optima Redtop 34Rs
2010 John Deere 2305
9-11-2001 NEVER FORGET
neeltburn is offline
post #3 of 12 (permalink) Old 10-12-2009, 12:55 PM Thread Starter
Built Not Bought
SOOTBANDIT's Avatar
Images: 9
Originally Posted by neeltburn View Post
Brandon,
where is this relay or fuse cause i looked in my fuse box and didnt find one?? thanks Neel
post #4 of 12 (permalink) Old 10-12-2009, 02:25 PM
ADMIN/MAFIA
neeltburn's Avatar
Not sure on the truck... Did you look on the under side of the lid? I know they are listed there. I see what I can figure out this evening and shoot ya a text if I find it.
6.7L 68RFE 4wd
Yeah its stock.
Pac Brake Air Bags
On Board Air
Optima Redtop 34Rs
SOOTBANDIT (10-12-2009)
post #5 of 12 (permalink) Old 10-12-2009, 03:16 PM
PhilipR's Avatar
I had the same problem with my '98 last year...after it would sit in the sun for a few hours it would work again or the heat from the engine would soak through and melt the slush. The Rain X fluid worked for me as well too. I agree it is annoying.
-Phil-
PhilipR is offline
post #6 of 12 (permalink) Old 10-12-2009, 06:00 PM Thread Starter
Built Not Bought
SOOTBANDIT's Avatar
Images: 9
im going to park it in the sun over lunch hopefully it will thaw out called dodge $90 pump said no warranty if it is frozen
post #7 of 12 (permalink) Old 10-12-2009, 06:02 PM
PhilipR's Avatar
I bet that's what it is.....I went as far as pulling the line off to see if the pump was working....it did...I took a face full of washerfluid....yeah I wasn't thinking.
-Phil-
PhilipR is offline
post #8 of 12 (permalink) Old 10-12-2009, 06:34 PM
blacksmoke101's Avatar
mine isnt frozen man, it worked fine idk what kinda juice you used. (btw sorry about sat man i was out lol, and t well he was lests say busy)
HAD2000 cummins leveling kit 35s airdog 150 juice with attitude 4 inch exhaust 2009 6 speed Khaki smarty 5 inch tbe S&B CAI
http://i735.photobucket.com/albums/w...0621091940.jpg
blacksmoke101 is offline
post #9 of 12 (permalink) Old 10-12-2009, 08:54 PM
R.I.P. DAD
SEABEE08FX4's Avatar
Check the fuse.
R.I.P. TMCS (SS) Brooks R Newell, I will forever miss you.
OneBigAssMistakeAmerica
2008 F-250 FX4
NMCB-28, KICKIN BUTT SINCE 1942
American club member #40
FOSP Club # 1
My sense of humor is an acquired taste, if you dont like it....... ACQUIRE some taste.
SEABEE08FX4 is offline
post #10 of 12 (permalink) Old 10-12-2009, 10:23 PM Thread Starter
Built Not Bought
SOOTBANDIT's Avatar
Images: 9
Well after $13 at the wash and bout 80lbs of snow and ice and holding the switch in till she came out problem fixed i guess it just took it forever to come up the line.
Heated Windscreen Washer Turist Duramax 07.5-2010 (LMM) 1 04-19-2009 09:45 AM
Gov. washer mod nevrenufhp Dodge - Modification instructions, Product installs and Tech Articles 6 03-26-2008 04:59 AM
Washer Shim for gov. stubbified6bt 12 Valve Performance 8 03-05-2008 03:46 AM
Washer jug cjensen91910 Whats Been Sold 0 05-24-2007 05:46 PM
washer fluid res. relocation mckey73 General GM Truck Forum 0 04-24-2007 03:55 AM
