Problems - Diesel Truck Forum - TheDieselGarage.com
Thread Details Posted by SOOTBANDIT, this thread has received 6 replies and been viewed 1658 times.
post #1 of 7 (permalink) Old 10-14-2009, 01:57 PM Thread Starter
Built Not Bought
SOOTBANDIT's Avatar
Images: 9
Problems
Prbolems so my truck started acting funny yesterday afternoon after work so i figured it was nothing to serious cause it was still running. Then i notice that my edge did not want to clear any of my codes on startup so that got my attention. These are the codes..
1. P2454 DPF Pressure Sensor A Circuit Low
2. P242F DPF Restriction Ash Accumulation
3. P1451 DPF System Performance
Ok so i know i have had the 1st for a long time cause it always comes back from time to time, the 3rd i believe i have also had but it usually clears on startup both the 1st and 3rd should clear but they didnt. The 2nd has got me confused mt buddy got this code when he made his sensors himself and his would go into regen alot....well quess what my truck went into regen this morning on the way to work just spraying raw fuel down the highway this the first time this hasd happened in 2yrs since i put the deletes on why now??? . So i have been at work maybe 30min and have a few ideas to why this happened last night when i thought it was acting funny i took off my boost fooler seemed to help a little dont ask then i got to thinking that the foolers that were sent with my exhaust have finally bit the bullet and are junk???? Im going to crawl under at lunch and make sure none of them came undone and make sure the one on the tranny is still connected. Feel free to tell me what ya think i think i believe if it is the sensors i will just spend $600 on a xrt or smarty this week tired of fighting these stupid little codes.
Military Quote Of The Year
SOOTBANDIT is offline
post #2 of 7 (permalink) Old 10-14-2009, 02:44 PM
ADMIN/MAFIA
neeltburn's Avatar
Brandon......
Is there still snow out there? If so could the snow got in the connection and fried the sims....
Sounds like someone is getting a new tuner...
6.7L 68RFE 4wd
Yeah its stock.
Pac Brake Air Bags
On Board Air
Optima Redtop 34Rs
2010 John Deere 2305
9-11-2001 NEVER FORGET
neeltburn is offline
post #3 of 7 (permalink) Old 10-14-2009, 02:56 PM Thread Starter
Built Not Bought
SOOTBANDIT's Avatar
Images: 9
Originally Posted by neeltburn View Post
Brandon......
Fried sims or not im not spending more money on some silly sims even thought they are cheap. Snow is bascially gone roads are clear i never had problems last year...Now i guess its just a toss up XRT or Smarty i will not be running my puck it will be coming off also. I did not want to go down this road right now i was wanting to wait just a little bit but heck its just money right
post #4 of 7 (permalink) Old 10-14-2009, 03:15 PM
ADMIN/MAFIA
neeltburn's Avatar
I would say smarty....but I don't think you can go wrong with either. But I agree with moving on and not paying for more sims. I just hope it does not go into limp mode.
6.7L 68RFE 4wd
Yeah its stock.
Pac Brake Air Bags
On Board Air
Optima Redtop 34Rs
post #5 of 7 (permalink) Old 10-14-2009, 03:19 PM Thread Starter
Built Not Bought
SOOTBANDIT's Avatar
Images: 9
i dont think it i will...
post #6 of 7 (permalink) Old 10-14-2009, 05:36 PM
Let it all Ride
Eazydeezy's Avatar
I am lost as to what the hell the problem could be too. Maybe the edge could be having a problem too.
I don't think it will go into limp mode either. I think it would have already and I'm pretty sure your looking at soft codes.
Dominic
Eazydeezy is offline
post #7 of 7 (permalink) Old 10-14-2009, 05:39 PM Thread Starter
Built Not Bought
SOOTBANDIT's Avatar
Images: 9
I got a set of sims coming for it Fri, I have the old style that are prone to getting moisture in them so hopefully that will fix the issue i dont believe the edge is doing anything wrong i just think the sims are old and got wet...
24v problems.... blackcloudCTD95 5.9L Cummins (1998.5-2002) 7 05-29-2009 04:11 PM
big problems maybe? mayflower06 5.9L Cummins (1998.5-2002) 3 10-15-2007 11:24 PM
gp problems sinister7.3 7.3L and 6.9 IDI (Pre 1994) 17 09-18-2007 12:48 PM
Big Problems W/ 6.4l BLACK350SD 2008-2010 6.4L Power Stroke 32 09-11-2007 03:30 PM
Electrical problems/dash problems curtis2003 5.9L Cummins (2003-2007.5) 1 10-21-2006 08:27 AM
