shift on fly speed - Diesel Truck Forum - TheDieselGarage.com
Thread Details Posted by SuperTaz, this thread has received 9 replies and been viewed 988 times.
post #1 of 10 (permalink) Old 11-02-2009, 07:14 PM Thread Starter
shift on fly speed
New to these forums, and I have a quick question.
I have an 08 dodge diesel with shift on the fly on the dash. How fast can I be traveling and shift into 4 HI?
My last dodge was on the floor and was not a Diesel so I need some help!
Thanks in advance!!
SuperTaz is offline
post #2 of 10 (permalink) Old 11-05-2009, 03:25 AM
stillcrazyinlaw's Avatar
Images: 3
I would think like any 4x4 to be nice to it and safe in bad weather the slower you are going when you shift it the better.
stillcrazyinlaw is offline
post #3 of 10 (permalink) Old 11-05-2009, 01:15 PM
Built Not Bought
SOOTBANDIT's Avatar
Images: 9
I have shifted on the fly at 40mph before no problems and have ran it up to 110mph no problems either but like last post said the slower the SAFER you will be.
Military Quote Of The Year
SOOTBANDIT is offline
post #4 of 10 (permalink) Old 11-05-2009, 01:53 PM Thread Starter
Agree
I agree with both you guys slower or barely rolling is best. I am just curious because in my last Dodge the manuel shift into 4wheel was on the floor and I could shift it up to 50mph no problem and always worked perfect and I had the truck for about 100k miles.
This is only an issue when I'm pulling the snowmobiles up North and you start seeing people drive off the road because of hitting slick spots. Sometimes you can't just slow down in time to shift it. Again rare, but happens about everyother time driving up North.
Thanks guys for the responses!
Brent
SuperTaz is offline
post #5 of 10 (permalink) Old 11-05-2009, 02:36 PM
Strokethis6.7's Avatar
just so long you are not under hard exel or spinnin out when locking in the 4wheel drive you will be good be good to it it will be good to you
Strokethis6.7 is offline
post #6 of 10 (permalink) Old 11-05-2009, 05:11 PM
Let it all Ride
Eazydeezy's Avatar
I shifted mine all the way up at 110 several times. That being said, if you shift under 110, you're safe! haha
Dominic
Eazydeezy is offline
post #7 of 10 (permalink) Old 11-05-2009, 05:34 PM
Built Not Bought
SOOTBANDIT's Avatar
Images: 9
ya your 6.7 was junk couldnt even survive a little fender bender JK Bud
post #8 of 10 (permalink) Old 11-05-2009, 05:38 PM
ADMIN/MAFIA
neeltburn's Avatar
Umm....I have pics of that at home and wouldn't call it a little fender bender
once again Dom...glad your ok....now put a cummins in the king ranch...
6.7L 68RFE 4wd
Yeah its stock.
Pac Brake Air Bags
On Board Air
Optima Redtop 34Rs
2010 John Deere 2305
9-11-2001 NEVER FORGET
neeltburn is offline
post #9 of 10 (permalink) Old 11-06-2009, 12:50 AM
Images: 3
I've run mine over 100 before on the drag strip but never shifted into 4x4 that fast. I'm sure I've shifted into 4x4 at around 35-40 in emergency conditions. But I never drive faster than that in the snow either. I've seen too many wrecks in the snow at work to make myself go faster.
post #10 of 10 (permalink) Old 11-06-2009, 12:58 AM
I think the manual says you're ok shifting into 4wd HI up to 50mph. Its in there somewhere if you check.
droot is offline
6-speed shift handle bannon_500 2003-2007 6.0L Power Stroke 12 08-03-2010 02:22 PM
SCT User Adjustments (WOT Speed Shift & Shift Pressure) ebusa 2003-2007 6.0 Tuner Forum 1 04-29-2008 03:23 AM
Torque shift or 6 speed Diesel Fanatic 1994-2003 7.3L Power Stroke 7 01-04-2008 10:13 PM
5 speed torque shift+7.3 powerstroke??? Steel 1994-2003 7.3L Power Stroke 6 11-05-2007 09:57 PM
5-speed shift tower Dual K20s General Dodge Discussion 2 07-22-2007 12:27 AM
