Hey 6.7 guys check this out. . .factory fast idle. .. - Diesel Truck Forum - TheDieselGarage.com
Thread Details Posted by M123KT-450, this thread has received 21 replies and been viewed 6888 times.
post #1 of 22 (permalink) Old 11-06-2009, 11:13 PM Thread Starter
M123KT-450's Avatar
6.7-CTD factory fast idle:
check it out. ..
Mike
1953 REO M48 w/w.
1962 GMC C45.
1969 AMC AMX -390.
1971 AMC /Jeep J4K-DRW.
1988 AMC /Jeep Comanche.
1991 Dodge RamCharger.
AMO #9860
B.O.M.B Squad #43
Dually Club #98
M123KT-450 is offline
post #2 of 22 (permalink) Old 11-07-2009, 03:13 AM
Dodgefarmer's Avatar
The owners manual also tells how to use the fast idle.
I use it for warmups and charging battery when jump starting equipment.
singles club # 198
Dodgefarmer is offline
post #3 of 22 (permalink) Old 11-07-2009, 03:30 AM Thread Starter
M123KT-450's Avatar
I see folk's asking how to add or install such a thing, I had no idea it was there tho my turck has an elector/Hydro lift for the dump bed so the fast idle doesn't do much for me but warm it up in the winter n cool it down in the summer. . .
Edit:
so is there others like me who have this option built in and not know about it ?
Mike
1953 REO M48 w/w.
1962 GMC C45.
1969 AMC AMX -390.
AMO #9860
B.O.M.B Squad #43
Dually Club #98
post #4 of 22 (permalink) Old 11-07-2009, 04:46 AM
I want that. My truck doesn't seem to have it. Can't find it in my book either. Can I have the dealer turn it on?
post #5 of 22 (permalink) Old 11-07-2009, 06:16 AM
6.7L Man Van
-lenny-'s Avatar
It takes about 2 minutes to have the dealer enable this with Starscan. Some come already enabled, some you have to go back. Mine came ready to go.
08 MC 3500 68RFE
Mostly Stock
-lenny- is offline
post #6 of 22 (permalink) Old 11-07-2009, 06:10 PM
Thats true, I forgot that the dealer needs to activate it. Most will do it for free.
Sometimes I will also use it if I want to leave the truck running for a while like running the ac while parked. Increasing the idle speed helps get around the issues of long periods of idling and problems/issues that can happen with long idling times.
singles club # 198
post #7 of 22 (permalink) Old 11-07-2009, 07:11 PM Thread Starter
M123KT-450's Avatar
Now is it only the 6.7-CTD's ? or is the same feature installed into the 5.9-CTD's as well just needs activating ?
Mike
1953 REO M48 w/w.
1962 GMC C45.
1969 AMC AMX -390.
AMO #9860
B.O.M.B Squad #43
Dually Club #98
post #8 of 22 (permalink) Old 11-08-2009, 06:05 PM
Built Not Bought
SOOTBANDIT's Avatar
Images: 9
I got that the smarty i had on for a night took care of it. Then i just grounded a wire and boom high idle when i want it. Mine dont go to 2k only 1500 wit the eb on and straight pipe neighbors tend to get a little pissy
Military Quote Of The Year
SOOTBANDIT is offline
post #9 of 22 (permalink) Old 11-08-2009, 09:27 PM
man this forum is falling behind. the high idle has been a known feature for a loonnnngggg time. it is a little different on the g56 though. you need to ground a clutch safety switch wire that is located down on the lower firewall behind the main wire harness. look through my early posts (late '07 probably) and you'll find what you need. let me know if you can't find it. oh yeah, the feature is great for keeping the a/c colder while idling, warming the truck up MUCH faster in combo with the exhaust brake, and most importantly helping prevent wet stacking/cylinder wash while idling.
mastercaster is offline
post #10 of 22 (permalink) Old 11-08-2009, 10:27 PM
I think this had gone around many times! It is stock with all 6.7's
With the truck in park and your foot off of the brake
Turn on the Cruise control
Press set - idle will increase to around 1100
use speed up and down to increase or decrease idle.
08'3500Mega is offline
fast idle? ehopp88ss 6.5L Diesel Engine 11 11-01-2009 01:48 AM
Fast Idle Cincinnati Guy 7.3L and 6.9 IDI (Pre 1994) 20 03-31-2008 09:31 AM
how do I enable the fast idle jmac 5.9L Cummins (2003-2007.5) 6 01-12-2008 08:40 PM
Besides fast idle, what else can be enabled? dwhitney 5.9L Cummins (2003-2007.5) 3 08-15-2007 06:39 PM
