stumble - Diesel Truck Forum - TheDieselGarage.com
Thread Details Posted by jlake, this thread has received 6 replies and been viewed 1115 times.
post #1 of 7 (permalink) Old 11-21-2009, 01:14 PM Thread Starter
jlake's Avatar
Images: 2
stumble
ok got a problem have the smarty 15me software running on 1 with edge juice attitude w/o timing running on 2 dpf deleted 5" turbo back no egr all of a sudden the truck has developed a bad off idle stumble/miss have reloaded smarty turned both tuners off doesent matter finally kicked a code says camshaft position sensor is bad ?? any ideas
2009 3500 dually; FLO-PRO 5' TURBO BACK NO MUFFLER,EDGE ATTITUDE W/JUICE,WEISS EGR DELETE,SMARTY W 15 ME SOFTWARE==
jlake is offline
post #2 of 7 (permalink) Old 11-21-2009, 02:43 PM
ADMIN/MAFIA
neeltburn's Avatar
can you disconnect the edge and run it and see what happens? I don't think its the smarty.
6.7L 68RFE 4wd
Yeah its stock.
Pac Brake Air Bags
On Board Air
Optima Redtop 34Rs
2010 John Deere 2305
9-11-2001 NEVER FORGET
neeltburn is offline
post #3 of 7 (permalink) Old 11-21-2009, 04:24 PM
got diesel
I have never heard of a programmer causing the camshaft position sensor code to flash but who knows. I did have some weird codes when I was running the 15me on the smarty. good luck
mike80433 is offline
post #4 of 7 (permalink) Old 11-21-2009, 05:14 PM
fuzzy's Avatar
I wouldn't reccomend running the edge on 2 even without timing, but that's just me. You might just need a new sensor though.
fuzzy is offline
post #5 of 7 (permalink) Old 11-22-2009, 03:04 PM Thread Starter
jlake's Avatar
Images: 2
took smarty program out ran edge on stock truck runs fine,put smarty in on sw1 all default settings stumble is back,took smarty program to stock on truck edge is on 2 now with and without timing no stumble??????was running edge on 2 with stock timing btw w smarty mileage was great was only reason 18.8 doing the math round town,26-28 on highway empty 65-70 now i'm at 13-15 with just edge after 100 mile trip this am ???????????????
jlake is offline
post #6 of 7 (permalink) Old 11-22-2009, 03:05 PM Thread Starter
jlake's Avatar
Images: 2
are you still running the smarty mike ??
jlake is offline
post #7 of 7 (permalink) Old 11-22-2009, 04:52 PM
got diesel
I updated the smarty to the 17me I used to run the edge but had issues with it. the 15me did give me some random codes. I swear every truck is different with the issues you will have. best of luck with just the smarty I can get up to 23 mpg on the highway empty of course.
strange stumble Zrock 1994-2003 7.3L Power Stroke 10 09-12-2009 02:33 AM
Stumble off idle Michael 1994-2003 7.3L Power Stroke 12 06-29-2007 09:35 PM
Help Stumble and buck dougs03 2003-2007 6.0L Power Stroke 0 03-04-2007 10:33 AM
Stumble? demarest652 Duramax 2004.5-2005(LLY) 4 01-18-2007 01:48 AM
6.0 with a stumble HappyGA 2003-2007 6.0L Power Stroke 8 04-05-2006 03:12 AM
