sevice indacator - Diesel Truck Forum - TheDieselGarage.com
Thread Details Posted by Rev., this thread has received 10 replies and been viewed 1731 times.
post #1 of 11 (permalink) Old 11-27-2009, 02:36 AM Thread Starter
sevice indacator
Anyone know how to clear the service indicator that comes on to remind you to clean egr and ccv?
2008 Dually Quad Cab, 6 Speed Auto 3.73, Edge W/Attitude,21/2" Hell bent Leveling Kit, Firestone Airbags, DIY Step Bars,EGR Delete, 4" Turbo Back Exhaust From K-2 Diesel, Cummins Mud Flaps,ATC Topper and Rhino lined rockers front to back
Rev. is offline
post #2 of 11 (permalink) Old 11-27-2009, 03:41 AM
ADMIN/MAFIA
neeltburn's Avatar
to my knowledge you have to use the "Starscan" tool which is the computer that dealers have. Does the Edge not clear it? If you are running sims try unplugging them and cleaning the connection and reinstalling the sims. (this would be dpf related) I also assume this is on the overhead not a CEL?
6.7L 68RFE 4wd
Yeah its stock.
Pac Brake Air Bags
On Board Air
Optima Redtop 34Rs
2010 John Deere 2305
9-11-2001 NEVER FORGET
neeltburn is offline
post #3 of 11 (permalink) Old 11-28-2009, 02:18 AM Thread Starter
yep overhead. edge will not clear it. It does come on after about 65000 miles to remind you to replace ccv. all I can find in the owners manual is "find clearing procedures in appropriate place"
Rev. is offline
post #4 of 11 (permalink) Old 11-28-2009, 04:18 AM
ADMIN/MAFIA
neeltburn's Avatar
hmm...maybe call dodge or cummins?
6.7L 68RFE 4wd
Yeah its stock.
Pac Brake Air Bags
On Board Air
Optima Redtop 34Rs
post #5 of 11 (permalink) Old 11-30-2009, 12:27 AM
Built Not Bought
SOOTBANDIT's Avatar
Images: 9
Buy a XRT!!! I had the same problem before i got smart
Military Quote Of The Year
SOOTBANDIT is offline
post #6 of 11 (permalink) Old 12-07-2009, 02:10 PM
Service indicator code
Turn key on push accelarate to the floor 2 times and then push the brake 2 times then turn key off. This work for me. Need to do this in 30 sec.
Jim A. is offline
post #7 of 11 (permalink) Old 12-08-2009, 08:48 PM
fuzzy's Avatar
Oil Change Indicator System
Your vehicle is equipped with an engine oil change indicator system. This system will alert you when it is time to change your engine oil by displaying the words “Oil Change Required” on your Electronic Vehicle Information Center (EVIC). The engine oil change indicator system is duty cycle based, which means the engine oil change interval may fluctuate depending on your personal driving style. Driving styles such as frequent stop and go type driving can increase the frequency of the engine oil change. This is the result of more frequent regeneration of the exhaust aftertreatment system, which can decrease the life of the engine oil. Failure to change the engine oil per the maintenance schedule can result in internal engine damage.
For information on resetting the Oil Change Indicator message, refer to “Oil Change Required – If Equipped,” under “Personal Settings (Customer Programmable Features)'” in the “Electronic Vehicle Information Center (EVIC)” Section of this manual.
OIL CHANGE INDICATOR - RESET
To reset the “Oil Change Required” indicator (after performing the scheduled maintenance) refer to the following procedure:
1. Turn the ignition switch to the ON position (Do not start engine).
2. Fully depress the accelerator pedal slowly three times within 10 seconds.
3. Turn the ignition switch to the OFF/LOCK position.
NOTE: If the indicator message illumination when you start the vehicle, the “Oil Change Required” indicator did not reset. If necessary repeat this procedure.
Perform Service Indicator
Your vehicle will require emissions maintenance at a set interval. To help remind you when this maintenance is due, the Electronic Vehicle Information Center (EVIC) will display “Perform Service”. When the “Perform Service” message is displayed on the EVIC it is necessary to have the emissions maintenance performed. Emissions maintenance includes replacing the Closed Crankcase Ventilation (CCV) filter element, cleaning or replacement of the EGR Cooler, and cleaning or replacement of the EGR Valve.
See your local authorized dealer to have the “Perform Service” message cleared and reset.
PERFORM SERVICE INDICATOR - RESET
Unless reset the “Perform Service” message will display on the EVIC each time you turn the ignition switch to the ON/RUN position to indicate a emission maintenance is required. To reset the “Perform Service” indicator system (after performing the scheduled maintenance) refer to the following procedure:
2. Press and release the brake pedal two times.
3. Fully depress the accelerator pedal slowly two times within 10 seconds.
4. Turn the ignition switch to the OFF/LOCK position.
NOTE: If the indicator message illumination when you start the vehicle, the “Perform Service” indicator did not reset. If necessary repeat this procedure.
fuzzy is offline
The Following User Says Thank You to fuzzy For this addition to TDG:
Rev. (12-09-2009)
post #8 of 11 (permalink) Old 12-08-2009, 09:59 PM
ADMIN/MAFIA
neeltburn's Avatar
Great post Fuzzy! could a mod put a sticky on the this so others can benefit from it?
6.7L 68RFE 4wd
Yeah its stock.
Pac Brake Air Bags
On Board Air
Optima Redtop 34Rs
Rev. (12-09-2009)
post #9 of 11 (permalink) Old 12-08-2009, 11:37 PM
fuzzy's Avatar
Reposted it in the dtc's sticky for ya.
fuzzy is offline
neeltburn (12-09-2009)
post #10 of 11 (permalink) Old 12-09-2009, 12:32 AM Thread Starter
your vehicle is equipped with an engine oil change indicator system. This system will alert you when it is time to change your engine oil by displaying the words “oil change required” on your electronic vehicle information center (evic). The engine oil change indicator system is duty cycle based, which means the engine oil change interval may fluctuate depending on your personal driving style. Driving styles such as frequent stop and go type driving can increase the frequency of the engine oil change. This is the result of more frequent regeneration of the exhaust aftertreatment system, which can decrease the life of the engine oil. Failure to change the engine oil per the maintenance schedule can result in internal engine damage.
For information on resetting the oil change indicator message, refer to “oil change required – if equipped,” under “personal settings (customer programmable features)'” in the “electronic vehicle information center (evic)” section of this manual.
Oil change indicator - reset
to reset the “oil change required” indicator (after performing the scheduled maintenance) refer to the following procedure:
1. Turn the ignition switch to the on position (do not start engine).
3. Turn the ignition switch to the off/lock position.
Note: If the indicator message illumination when you start the vehicle, the “oil change required” indicator did not reset. If necessary repeat this procedure.
Perform service indicator
your vehicle will require emissions maintenance at a set interval. To help remind you when this maintenance is due, the electronic vehicle information center (evic) will display “perform service”. When the “perform service” message is displayed on the evic it is necessary to have the emissions maintenance performed. Emissions maintenance includes replacing the closed crankcase ventilation (ccv) filter element, cleaning or replacement of the egr cooler, and cleaning or replacement of the egr valve.
See your local authorized dealer to have the “perform service” message cleared and reset.
Perform service indicator - reset
unless reset the “perform service” message will display on the evic each time you turn the ignition switch to the on/run position to indicate a emission maintenance is required. To reset the “perform service” indicator system (after performing the scheduled maintenance) refer to the following procedure:
4. Turn the ignition switch to the off/lock position.
Note: If the indicator message illumination when you start the vehicle, the “perform service” indicator did not reset. If necessary repeat this procedure.
bingo preform service reset that's what i was looking for. Thanks man
Rev. is offline
