Perform Service message - Diesel Truck Forum - TheDieselGarage.com
Thread Details Posted by Dodgefarmer, this thread has received 5 replies and been viewed 11311 times.
post #1 of 6 (permalink) Old 12-18-2009, 03:55 AM Thread Starter
Dodgefarmer's Avatar
FYI
Recently at 67500 miles my overhead monitor lit up saying "perform service". According to the manual that means the egr is supposed to be cleaned. In CA, since it is emmision related the dealer is required to perform this service at no charge. I guess it is strictly a mileage issue as to when it shows the warning. I also scanned it for codes, just to be sure and none showed up.
Ask the dealer about it and was told they never do it unless there was an issue, they don't think its worth the risk. They felt since the egr has to be completly removed and opened up for cleaning the risk of causing a leak or other problem was not worth it.
Told to just delete the message. Turn ignition on, step on brake pedal 2 times and then press on throttle 2 times with in 10 seconds and its off.
Sorry for the long post but wanted to let others know.
singles club # 198
Dodgefarmer is offline
todt061458 (12-18-2009)
post #2 of 6 (permalink) Old 01-03-2010, 03:03 AM
mdcody101's Avatar
There is no risk to doing the cleaning as long as you replace the gaskets. we do the cleaning all the time. Even if you do not do the cleaning you need to replace your CCV filter. If you do not replace the filter it can cause a Check engine light and performance issues.
mdcody101 is offline
post #3 of 6 (permalink) Old 01-03-2010, 04:16 AM Thread Starter
So far no check engine light....ever .... with 68,000+ miles
singles club # 198
post #4 of 6 (permalink) Old 01-03-2010, 04:22 AM
mdcody101's Avatar
That just means that you drive it and use it like it is designed to be.
post #5 of 6 (permalink) Old 01-06-2010, 01:18 AM
Hey thanks for the info. I have the same warning and have not had it fixed in 4,ooo miles yet. Was wonderering how to turn it off. Thanks Lee
cowboylee_41 is offline
post #6 of 6 (permalink) Old 01-06-2010, 01:22 AM
mdcody101's Avatar
Turn ignition on engine off step on brake pedal 2 times and then press on throttle fully to the floor 2 times with in 10 seconds then turn the ignition off
Perform Rapid Response 08-036 semlohde 6.7L Cummins (2007.5-2011) 0 05-02-2008 07:16 PM
SEVERE SERVICE service? kenkillsr 2003-2007 6.0L Power Stroke 5 08-19-2007 05:06 AM
Cummins 6.7 L Service Bulliten "Re-Flash" SERVICE BULLETIN 18-033-07 REV.A Myguy 6.7L Cummins (2007.5-2011) 5 07-23-2007 02:00 AM
how doese sct perform 03f250 2003-2007 6.0 Tuner Forum 4 03-22-2007 04:17 PM
